I have a new mp4 about 4GB, but when i tried to copy files from our pc to the mp4 an erro is prompting saying 'parameter not correct'. please help..
  • 436 Answers
With MP3 player connected, right click on the drive it shows in MY COMPUTER.
select "FORMAT" and let the PC format the player.
this should clear up issue
Hope it helps :)
Posted on May 25, 2011
Ipad PNG pictures can't copy to harddrive - parameter is incorrect
you can try using the app "Shareit". it will give you an option to transfer files from ipad to computer.
Sep 05, 2017 | Tablets & eReaders
Hi, we're trying to use PsExex utility to launch 2 .exe files with some parameters on some server from a client application. The server is running Windows server 2003, the client Windows 7 Professional...
psexec in fact does run as the user running the command window that initiated the command. I use this command almost daily to run either command shells, batch or vbscripts, etc on remote computers. I've learned some about its behavior from watching the results.
Basically, psexec copies itself to the ADMIN$ share on the remote computer. It then installs a service on the remote computer, and runs that service, which is the copied file. This then executes the command that you specified in the psexec command line.
So, with that in mind, the user running psexec from the command line needs to have admin rights to the remote computer. You can bypass this requirement by using the "-u" parameter, and specifying a domainname\username. Domainname can be the remote computer's name if you have a local user. By putting in just the -u parameter, you'll then be prompted to type in the hidden password.
Once running on the remote computer, psexec will function in one of three ways:
1 - If no special parameter used, will run in the same user account as the person initiating the psexec command.
2 - If the "-u" parameter is used, it will run as that user.
3 - If the "-s" parameter is used, it will run as a local system account
In either of these 3 cases, you first have to have admin rights to use the ADMIN$ share and install a service.
When domain membership is broken on a computer, I'll frequently use a command line like this:
psexec -u COMPUTERNAME\Administrator \\COMPUTERNAME cmd.exe
This will allow me to have local admin rights by connecting to the remote computer as the local administrator account. It will also run the cmd.exe command as the local admin account.
Aug 30, 2011 | Microsoft PsExec
My daughters Asus eee pc MK90H notebook says windows could not start because system 32 is missing or corrupt. It says to use the original CD Rom, which obviously we dont have. Help what do we do?
To restore a missing or corrupt ntfs.sys file you must have the Windows XP CD and follow the below steps.
Insert the Windows XP CD into the computer and restart the computer.
As the computer is starting make sure to press a key to boot from the CD.
In the Windows XP setup screen press the 'R' key to run the Windows Recovery Console.
If prompted enter the number of Windows installation you're repairing.
At the command prompt type the below command.
copy x:\i386\ntfs.sys c:\windows\system32\drivers
* In the above example you would replace x: with the letter of your CD-ROM drive. Many computers have the CD-ROM drive configured as the D: drive.
If ntfs.sys is still on the computer you'll be prompted if you wish to overwrite the file. If prompted, press the Y key for Yes to overwrite the file.
Once the file has been successfully copied remove the CD and reboot your computer.
Do NOT use an OEM "Recovery Disc". Only a valid Windows XP media will work or a disc from the OEM that says "Operating System" may sometimes work depending on how the manufacturer labeled the CD.
Hope this helps. Let me know if you need more information Thanks
May 11, 2011 | ASUS Eee PC 1000HE Netbook
I can't log in as it keeps coming up user profile can not be loaded, please help
try and log in as administrator, create a new profile under control panel>Users. name it whatever you would like, then manually copy the contents of the old user libraries to the new one. so basically let's say your old user was named 'fail' and your new user is named 'win' after creating win, go into windows explorer, and go to c:/Users/fail/libraries and hit copy. navigate to the same location in win's directory and hit paste. it will ask to replace files that are already there, go ahead and hit yes. if you can't log in as administrator you may be able to tap f8 @ boot until you get to a boot menu and then arrow down to 'repair my computer' once loaded it will probably try and run startup recovery. if this doesn't fix it, you'll be presented with another grey menu. click dos prompt. once dos prompt opens type cd c: then type chkdsk c: /r that should fix the file structure. you can also run sfc /scannow which will check your system files. good luck!!
Jan 16, 2011 | Acer Aspire 5535-5050 Notebook
How come when I put my SanDisk 2gig memory chip into my phone, when I try to send pictures to the card it says "cannot rename" and will not work? I have the LG dare
a cannon rename erro means there is a file or folder on the sand disk witch the camera is trying to wrtie to with the same name or file,
1. Move/copy the files off the sand diisk
2. Format the memory with your pc or camera.
This should work let me know ether way if you have questions.
please do rate before you leave, thanks for using fixya.com
Aug 25, 2010 | SanDisk 2GB microSD Memory Card
Eee PC 1000H/XP - my wireless connection stopped functioning
1) Try to check your connections. Follow the guide from Microsoft, here: http://support.microsoft.com/kb/314067
2) You could try reseting your TCP/IP stack. Try this:
  1. To open a command prompt, click Start and then click Run. Copy and paste (or type) the following command in the Open box and then press ENTER: cmd
  2. At the command prompt, copy and paste (or type) the following command and then press ENTER: netsh int ip reset c:\resetlog.txtNote If you do not want to specify a directory path for the log file, use the following command: netsh int ip reset resetlog.txt
When you run the reset command, it rewrites two registry keys that are used by TCP/IP. This has the same result as removing and reinstalling the protocol. The reset command rewrites the following two registry keys: SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\
SYSTEM\CurrentControlSet\Services\DHCP\Parameters\
Mar 17, 2009 | ASUS Eee PC 1000H Laptop
Cannot open or copy - parameter is incorrect?
Are you using the same card reader for both memory cards? It's probably just your card reader. I had this problem before and it turned out to be my usb cable for my psp.
Mar 15, 2009 | Sony PlayStation Portable (PSP) Console
Problem: "Error. Cannot copy file. The parameter is incorrect". Help!
If you have a memory card in the camera, take it out before turning the camera on
Jun 26, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Error with Vista
If you are using any other operating system than Vista please see this article: http://www.rebrandsoftware.com/admin/supportEdit.asp?article_id=53
This error indicates that a file is not correctly installed on your system. In some cases it may be correctly installed for all standard users but not for the "Administrator" account, and you may only see this error when selecting "Run as Administrator".
The built in Administrator account is not intended to be used as a user account. It is very secure and will not allow program components to be registered. Instead you should create an account with administrative rights, and use it instead of the built in Administrative account. This will help solve runtime error 339/429 on our software, and lots of other software that you may install in the future. If you do not want to create a standard user account (not recommended) you can follow the instructions below:
If the problem started suddenly then a reinstall may fix it. If not, follow the directions below to register each file that is producing the error. You generally will only have to repeat the instructions 3 or 4 times:
Click start
In the search box type "cmd" without the quotes
When CMD.exe appears above the search box right click it and select "Run As Administrator". This will open a command prompt with admin rights.
Repeat the following for each file that is causing this error, replacing [filename] with the actual name of the file that is causing problems:
    -Type "regsvr32 [filename] /u" without the quotes
    -You will receive a prompt saying the file has been unregistered. Click OK.
    -Type "regsvr32 [filename]" (shortcut: press your UP ARROW and delete /u)
    -You will receive a prompt saying the file has been successfully registered.
    try this
    Go to Start
    click Run
type in cmd
press enter
type in the black screen
regsvr32 MSWINSCK.OCX
Press enter
it will come back the c: prompt
then
Restart your PC
Jun 02, 2008 | Microsoft Windows Vista Ultimate Edition
..wel, i solved mine.. im copying music files into a memory card like micro SD.. when im copying music.. it says.. cannot copy file.. the parameter is incorrect... then go into My Computer then Right Click the external hrd drive(micro SD),, then go to properties....then tools.. then click the Check now.. - it will check for some errors and automatically fix the errors.. :D thats it..
Oct 17, 2007 | Vivitar ViviCam 5385 Digital Camera
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
