Question about Acer V193W 19 inch LCD Monitor
My acer monitor displays the acer background, makes a noise like a buzzing sound and goes black, and then after all my settings and background picture and information are complete and up, the monitar displays that on the screen for a second and makes the same buzz noise and goes black and never comes back...could you please tell me what this may be?
  • 281 Answers
It sounds like a backlight or inverter problem. You can verify this by using a bright light to shine on the screen surface. If you can see the picture (but it will be very dark) that means that the backlight which illuminates the screen from behind. You would have to replace the inverter to test it, but there is good news: These are pretty difficult to find parts for, and not an easy repair for an amateur; acer products usually have a 3 year warranty on the backlight/inverter system, so I would start there.
Posted on May 25, 2011
When the monitor is turned on the screen goes on but there is a buzzing noise coming from the power supply board, then after 3 seconds the monitor goes black but the green power light is still on and the...
Sounds like the common Bad Capacitor story! If your monitor is not under warranty and you have any soldering skills this is only a 10 dollar fix. There are dozens of tutorials on youtube that will walk you through this. Search "Monitor capacitor replacement".
Aug 05, 2011 | HP L1740 17" LCD Monitor
Acer lcd screen p191w makes a buzzing noise when turning on and the screen is very dim. then it shuts off. can this be fixed at home
Not safely and not unless you are confident and competent with electronics. I would put the dimming down to a failing display circuit, but the buzzing sounds as though a short is developing. I would take it to a tv repair shop who can advise better and maybe replace or repair the components
Jan 08, 2011 | Acer Brand ACER P191W 19" LCD Monitor
Screen is trying to black out on me, accompanied by a loud buzzing noise. This buzzing noise has been growing over the past few weeks, and now, today, my monitor has blacked out several times, at which...
well mine came with a three year warrintee, so iv sent mine back twice already, worst moniter, try finding your receipt and then going on to acer's online support
Dec 15, 2010 | Acer X233H 23" Monitor
Monitor Acer Al 1914, no signal
Check your connections to the PC. Make sure that they are nice and secure. If there is a resolution problem setting it should display the boot process and then go blank after starting the operating system.
Oct 28, 2009 | Acer AL1914 19" LCD Monitor
My acer al1916w displays the image for 3 seconds then goes black
Sounds like your video card. Check to make sure it's connected properly. If so, check to make sure it's properly seated to *********** board. The possible issue could be the card is connected enough to display the picture, but not enough to communicate with the monitor to stay on because it has an active feed. Best of luck fixing it
Oct 14, 2009 | Acer AL1916W 19" LCD Monitor
I have connected my old dell laptop to this TV with VGA cable and audio cable and it worked with no problem. Have new Acer Aspire one netbook- connected to computer with same cables - can see windows...
First, you want to make sure the laptop's internal/external display mode is set properly. On Acer netbooks, this is usually changed by holding the "Fn" key, and pressing "F5". Either the TV or the computer display should flicker when you do this. There are 3 modes:
1 Computer only
2 TV Only
3 Computer and TV
If changing between thos emodes doens't work, continue on.
I am going to assume you are running Windows XP. Please correct me if I am wrong.
To display your desktop on an external monitor, you'll need to change/check some settings. Your netbook is most likely attempting to set it's display settings automatically, but it is expecting a computer display, not a television, so the resolutions and refresh rates are conflicting. That's why it will only display on one and not the other. Before Windows loads, the netbook is using a very low resolution,so it displays on the TV. Once Windows loads, it switches to some non-standard resolution that your TV cannot display and defaults back to your netbook screen.
The solution is to find a resolution that your television will display:
1.Right-click the desktop, and then click Properties.
2.In the DisplayProperties dialog box, click the Settings tab.
3.Click the Display list and select your external monitor (..the TV. It will most likely be display #2).
4.Select the Extend my Windows desktop onto this monitor option.
5.Select 640x480 in the "Screen Reolution" section for Display #2.
6.Click Apply or OK.
Note: If you see the background change on your television, mmove your mous there to make sure it's working. If it DOES work, go back to the "Screen resolution" section for Display #2 and find the highest resolution your television will display
Sep 19, 2009 | Westinghouse SK-32H540S 32 in. LCD TV
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Monitor Buzz on start -up
Try a different monitor or this monitor on a different computer. If it makes same noise on different machine or new monitor makes no noise on your machine you need a new one.
Dec 24, 2008 | Computers & Internet
NEC 77F CRT monitor - displays alternating black \ white crosses
Sounds like its stuck in test mode. Make sure that none of the buttons are stuck in place and does it make any noise while its turned on?
Jul 19, 2007 | NEC MultiSync 77F 17 in.CRT Conventional...
Acer V193W 19 inch LCD Monitor Logo
310 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
