Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
There is a light on the #3 panel lit up & when i push any button a letter L shows up on the display?but does not do anything else.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 239 Answers
You have the child lock on the control. Press and hold the Energy Saver Dry or Air Dry button until it unlocks.
Kelly
Posted on May 25, 2011
How do I reset control panel after changing water filter. Both freezer and refrigerator temps show OF
If this is a samsung with a front display touch pad refer to your user manual if you have it, theres usually a button depending on model on the front user interface that you hold for 3-5 seconds that will make the light go from purple back to blue. its usually in small lettering right on the touch pad too even if the touch pad is in the door. If it's a whirlpool side by side, you push the door switch in 3 times really fast. Every model has its own way and with out more information, I can only give you advice as opposed to a definite answer.
Jan 31, 2015 | Samsung Refrigerators
What is trouble code 55pt6 on harley davidson 2011 fxdc
It's NOT an error code.
When you first go into diagnosis mode, the display shows "DIAG"
When you push the odometer reset button the display changes to "PSSPtb" (Not 55PT6...you're missing the flashing "P" in the front).
These are the different modules (sectors) that the display can show, with the flashing one being the one ready to show the error codes in THAT ONE SECTOR!
The correct procedure for displaying error codes is:
1 - Turn the ignition switch to off & run/stop switch is to run .
2 - Push odometer reset button in & HOLD .
3 - Turn the ignition switch on and then release odometer reset button . The background lighting should illuminate & the speedometer needle should sweep it's full range & indicator lamps ( battery , security , low fuel , check engine and cruise ) should illuminate . The word "DIAG" should then appear .
4 - Push the odometer reset button once and you will see the selection menu "PSSPtb" (this is what you are misreading as "55PT6", without accounting for the flashing "P") with the first P flashing .
5 - Each letter represents a area of the diagnostics module . The module that is flashing is the one you are going to check . To move from one letter to the next you must push the odometer reset button one time . ( from P to S to SP to t to b and back to P , ect ect )
P = ECM (main computer "brain")
S = TSM/TSSM/HFSM (turn signal/security, etc)
SP = speedometer
t = tachometer
b = ABS codes (anti-lock brakes)
6 - To get the DTC code in a area of diagnostics you should PUSH & HOLD the odometer reset button in for 5 seconds and the release . If there are any DTC's the code will be displayed or the word " none " will appear if there are no DTC's. Push the odometer reset button again to view any additional codes if they exist.
7 - Record the codes .
8 - If DTC's are NOT to be cleared , press and release the odometer reset button . Part # of module will be displayed. This number IS NOT an error code!
9 - If DTC's are to be cleared for that module , PRESS & HOLD the odometer reset button until " clear " is displayed .
10 - Press and release the odometer reset button to continue to the next module .
11 - Turn the ignition switch off to exit the diagnostic mode .
12 - If the run/stop switch is in the "OFF" position, No RSP (no response) will display. Also in the modules (sectors) where there is no component to give a signal/reading (such as if you have no tach, No RSP will show in the tach sector. Same with the "b" sector if you do not have ABS brakes).
Aug 30, 2014 | 2010 Harley Davidson FXD Dyna Super Glide
Clutch cable rubbed a hole in the rear brake line. ABS light still on after repair. How do I reset it?
The ABS light should stay on until you reach a speed of about 3 MPH or higher.
Did you check for error codes?
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted)
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC's the code will be displayed or the word "none" will appear if there are no DTC's. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTC's are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC's again by repeating steps 1 to 9. If the code is current it will reappear.
9 - Press and release the odometer reset button to continue to the next module.
10 - Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
Also if the code set is a historic code (not a constant light) after 50 start and run cycles of at least 30 seconds each in duration, the light will extinguish itself as long as the error hasn't occurred again.
If it were a current code, the light would remain lit while running.
If you clear the error code (step #8), the light SHOULD reset.
Mar 24, 2014 | 2000 Harley Davidson FLHR-FLHRI Road king
How to retrieve fault codes 05 flstni Harley Davidson
3- Turn ignition switchto Ignition and release odometer reset button. Background lighting should illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word "diag" should then appear.
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module[Carbureted)
SP = speedometer
T = tachometer
10 - Turn Ignition switchto OFF.
Dec 11, 2013 | Harley Davidson Motorcycles
How can you set the Caixing CX-2158 to 12 hr time instead of the military time?
for clock settings
Clock buttons from the left.
[1] Set
[2] Shift
[3] Modify
[4] Alarm
[5] End
[6] Reset - (use paperclip to push button in hole.)
Light indicators
[A] A.M.
[C] P.M.
[B] Alarm(s) active.
[D] Hour Notice
To set time and date
1.Push SET, push SHIFT to transfer from YEAR to MONTH to DAY to HOUR to MINUTE
2. Push MODIFY to change to desired value in every field (blinking)
3. Press SET or END to save.
To change from 24 - 12 hour format
1. Press MODIFY continously for about 3 to 5 seconds
NOTE: in 24-hour format, both the A.M and P.M light is OFF
TO SET ALARM
1. Push ALARM, and alarm setting number 1 will show, push ALARM again to show alarms up to 8 or 9 (depending on model)
2. When desired alarm number is chosen, Press SET
3. Push SHIFT to transfer from HOUR to MINUTE
4. Push MODIFY to change desired value in every field( blinking)
5. Push END to save, (Please note Red ALARM light will lit)
TO CANCEL ALARM
1. Push ALARM until the desired alarm to cancel is shown.
2. Press MODIFY ( the dispaly will show --:--)
3. Press END (NOTE: Alarm light would only turn off only if all alarm is cancelled)
TO SET HOURLY NOTIFICATION OFF AND ON
1. Push MODIFY button once (hour notice light would lit) - hourly notice is turned ON
2. Push MODIFY button again (hour notice light is off) - hourly notice is OFF
Oct 01, 2011 | Vacuums
I have a living solution modelA17G0510/ATC-510 universal remote control.i have a JVC television dont have the code and dont remember how to reprogram...please help
Try this for a quick fix. If this doesnt work repost and we will dig deeper lol
Make sure you have device turned on.
Hold the device button you want to program for 3 seconds & release.
Push & release the power button & the red light will remain lit.
Push the CHANNEL UP button over & over slowly until the device turns off.
When device turns off press OK button
Oct 17, 2010 | JVC Televison & Video
Control Locked
Locking controls
The Control Lock prevents unintended use of the washer. You
can also use the control lock feature to prevent unintended cycle
or option changes during a cycle. When CONTROL LOCKED is
lit, all buttons are disabled. You can lock the washer while it is
operating.
To lock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds.
The CONTROL LOCKED status light glows.
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Oct 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Zone 2 issues
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there
Aug 03, 2008 | Yamaha RX-V659 Receiver
Volume fix problem
FIX ZONE @ SOUND - STUCK ON "ZONE 2 - FIX" 1. Press "Amp" button (right side of remote - 1/3 way down) 2. Press "Menu" button (center of remote - 1/2 way down) 3. Press "TV VOL" button (green letters) until "Manual Setup" is displayed on receiver 4. Press "Enter" button (green letters) 5. Press "TV VOL" button (green letters) until "3 Option Menu" is displayed on receiver 6. Press "Enter" button (green letters) 7. Press "TV VOL" button (green letters) until "D Multi Zone" is displayed on receiver 8. Navigate from there Good Luck! This worked for me.
Aug 02, 2008 | Yamaha RX-V659 Receiver
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
251 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
