Question about Lexmark X7550 InkJet Printer
Cannot print to lexmark x7550 printer. it seems that printer is able to scan but not able to print. already installed the software, but when connecting the printer to the computer with windows 7, it says driver was not installed successfully. thank you.
  • Official Brand Answer
  • 3,344 Answers
Try to use the Windows 7 driver from the Lexmark website. Uninstall the existing driver from your computer first. How to Uninstall Lexmark Printers. Reboot pc when prompted. Then, check if your Windows 7 is running on 32-bit or 64-bit system type by going to the Start menu > right-click on Computer > Properties. Take note of the System Type.
To reinstall the driver, use the following links below: - Lexmark X7550 Driver for Windows 7 32-bit - Lexmark X7550 Driver for Windows 7 64-bit
Posted on Jun 02, 2011
Lexmark x7550 won't communicate with computer to scan
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/ngaKcu. Select your operating system, download and execute the file.
Oct 19, 2011 | Lexmark X7550 InkJet Printer
Can a lexmark x7550 print to a mac?
Yes, the Lexmark X7550 support Mac & Windows too. You have to install the respective drivers versions for your Mac versions.
You can download the Mac OS versions drivers @ http://support.lexmark.com/index?locale=EN&page=product&userlocale=EN_US&productCode=LEXMARK_X7550#2
Make your Mac OS selections "Change OS" to proceed in downloading the correct Mac drivers for your System.
Hope it helps.
Jun 24, 2011 | Lexmark X7550 InkJet Printer
I have a lexmark pro 205 all in one printer. It prints fine but I can't seem to scan a document and put in word. How do I do it and where can I get a manual for this product?
You will need to install the Lexmark OCR scan software to scan documents and edit it. Re-insert the installation disk in your computer to install the Lexmark OCR scan software. If you continue to experience scanning problem or you lost the disk, contact Lexmark technical support. Thank you for choosing Lexmark.
Oct 10, 2010 | Lexmark Prospect Pro205 Wireless...
I have a LexMark x7550 all-in-one printer, model:4429-W22, serial #: 01360113314 2007/09. Printer will not print internet download or regular documents. I unpluged the printer and rechecked connections,...
Please go to run and enter "devmgmt.msc" you will get device manager, Remove all of the Universal Serial Bus from the device manager and click on Scan for hardware changes. It will install all of the USB drivers. After that connect the all in on printer and install the software properly.
Aug 07, 2010 | Lexmark X7550 InkJet Printer
I have a X7550 printer and I can't get it to print
please confirm which OS is on your laptop, and run the driver for that OS, you may read this up
http://www.lexmark.com/publications/eng/x7500/index.html
Mar 16, 2010 | Office Equipment & Supplies
Lexmark x7550 printer jam. I cleared the jam and hit the check mark button as directed, but it keeps looping through the paper jam sequence. It does not seem to register that the jam has cleared. If I...
There will be some form of error clear code that would need to be entered. It would be something like "holding down the print key and powering on the printer at the same time" The manual may tell you.
There are different combos for different manufacturers.
Nov 17, 2009 | Lexmark X7550 InkJet Printer
I have a lexmak x75 printer and it wont print only scans
go to the lexmak website download th newest software for printing do this and send me what happened in my mail www.m-o-m@hotmail.com
Aug 17, 2009 | Lexmark X7550 InkJet Printer
Bold lines on Fax and Scan
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark X7550 InkJet Printer
I can not get my Lexmark X7550 printer to print.
If you already have your printer installed do this:
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Nov 12, 2008 | Lexmark Office Equipment & Supplies
Lexmark X7550 InkJet Printer Logo
155 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
