Question about Cub Cadet Garden
I have a cub cadet 2000 series model 2146. When I turn the key the motor spins but doesn't start. When I take the air filter off I see gas spit out when I choke it.
The service people replaced a bad coil. The old coil slowly petered out untill the cub would not start.
Posted on Sep 09, 2012
    Novelist:
    Champion:
  • 222 Answers
You could have one or more of several problems. With the gas scenario you mention, you're getting gas INTO the carburetor. But the carb could be grungy and in need of cleaning (90 percent of mower problems in my experience). My question is this: is the thing "Firing"? like do you hear it kick in like it wants to start. If not, then it may not be getting any spark. Take the spark plug out and buy a new one for about $3 (match the numbers up on the side of the plug ceramic). It never hurts to replace it anyway. With the info you have provided here, that is all I can give you right now, but hope it helps. Good Luck.
James
Posted on May 27, 2011
My cub cadet 2146 pto won't turn on, also the key will not shut off the motor. I recently took the motor off to replace a sheared fly wheel key way.
Hi
Sounds like you didnt replace the immobiliser chip or reprogram the new one.
Get a diagnostic test to verify
Apr 24, 2017 | Cars & Trucks
My cub cadet model 12A-18M7010 will not start. It has an automatic choke. No primer. I've changed the gas, checked the plug, cleaned the carbuerator. What could it be?
Also check the air filter. Some times if the paper filter is wet or clogged it will choke out the machine by not allowing air in to the ignition chamber.
Apr 17, 2013 | Cub Cadet Garden
Cub Cadet SRC 621, won't start. New spark plug, cleaned carburetor and air filter, Whiffs of smoke occasionally
Sounds like a sheer flywheel key. Common on the SRC 621. Kawasaki motor, correct. The flywheel key is under the recoil. Pull the flywheel and check the key. A very small key is there. Breaks and puts the engine out of time
Oct 16, 2012 | Cub Cadet Street Sign- tractor lawn riding...
White smoke comeing from front of engine on my 1042 cub cadet lawn tractor.
White smoke is typically an indicator of an oil leak. This could be a leak, broken ring, valve or piston problem etc. I would start with checking your filter to ensure oil has not leaked inside there. Next I would check the spark plugs for oil build up. Doesn't sound like it's getting to the exhaust.
Aug 07, 2012 | Cub Cadet Garden
Cub cadet riding mower wont start... parking brake feels loose wont turn over
see if the rod fell off there is a safety switch on the clutch/brake pedals if the rod doesn't move all the way the switch will not make the connection
Jun 03, 2012 | Cub Cadet 42 And 54 Inch Blade Operator's...
Cub cadet LT-1042 blades spin when motor is turned on, pto lever does not turn on or off blades
sound like you have some wires shorted out follow the wires from the clutch back to the switch
Apr 08, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a cub cadet 2146 riding mower. I've changed the battery and replaced the fuses, still no power. What else could the problem be?
check the battery connections and also the earth cable if no luck their then check the fuses with a test light or similar and look for a feed to the fuses as the connections at the back of the fuses could be corroded
Nov 23, 2011 | Cub Cadet Garden
I have a Cub cadet series 2000 model 2146. When I turn the key the engine turns over but doesn't start. When I take the air filter off gas spits out when I choke it.
you need a carb kit it seems like the little stopper atached to the other end of your float is not stopping gas and is flooding the carb . try pinching the hose wit a pair vise grips gently though just to stop the flow of gas and then crank over if it starts try what i wrote down about repairing the carb.if you look thre is a round bowl held on by a screw or or a spring clip remove and when you get the new kit it will have a little triangle peice with a point somtimes the tip is metal sometimes it is rubber if it is metal there is a tiny rubber peice in the bottom of that hole needs to be replaced with new one also comes in kit . in the screw there are a few tiny holes if you dont have somthing small enough to fit in the holes get a tip cleaning set from home depot or lowes it is in the welding section it costs like 2 to 3 dollars it has tiny wires with ridges on it. clean out all the holes . somtimes the screw you remove to secure the bowl on if you look in the hole you will see a brass flat head screw in the middle of the carb so you are now looking in the stem on the center of carb remove it there are more holes in that as well if you dont have the little flat head dont worry about it it is about 2 inches in length over all . install new seals and put carb together . there should be a screw to adjust the gas mixture if so you should get a new one in kit it is long with a point and should have a spring on it remove old screw tighten new screw in all the way then turn back out two and a half turns and that should be close to the correct idle speed hope this helps
May 25, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
273 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
