Hi i have a electrolux EWF 1481 the wash program stopped with 15mins to go the stop/pulse button keeps flashing and the door is locked
  • 49 Answers
SOURCE: electrolux ewf 1435 washing machine
i can not find e50 in any of my servive manuals, are you sure it is e50 ?
Posted on Feb 19, 2008
SOURCE: Electrolux EWF 1087 error code E60
user manual tells you what faults are
could be blocked inlet valve not filling in correct time or pump blocked
not draining in correct time
Posted on Mar 15, 2008
  • 3 Answers
SOURCE: Hi i have a electrolux ewf 1074 front loader. it
Press and hold the 'Delay' and 'Extra Rinse' buttons together and it will 'unlock' your control panel (this is a tamper proof feature for the kiddies)
Posted on Jun 11, 2009
  • 4 Answers
SOURCE: unusual display on panel (padlock) machine can't be programmed door is not locked however
i just went through the same thing.......you need to hold the option and extra rinse buttons simultaneously for 6 seconds, this will unlock it.....so turn the machine on and press the two icons, dont worry about the beeping and flashing after 6 seconds the padlock symbol will go and you can use the machine as usual.....i wish they put that 'minor detail' in the manual...cheers!!
Posted on Aug 19, 2009
  • 4 Answers
SOURCE: Electrolux EWF 1074 get a lock icon
you need to hold the option and extra rinse buttons simultaneously for 6 seconds...you will see the padlock symbol go and then use your machine as usual
I have a Electrolux EWF 1481. The start/pause is flashing and the machine don't start
Good Morning JeanPierre, thank you for allowing me to assist you!
Let's try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn the washer on. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potentialwiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Sep 29, 2013 | Electrolux EW1000i Front Load Washer
My electrolux ewf 1481 front loader wont spin
Open the flap, bottom right of the front panel and check the filter is clear. Most machines will not spin until they have expelled all the water. You may want to check the hose is not block and any connections to the sink if it's not on a standpipe.
Most new machines have quite sensitive out of balance detection so if it an odd load try again but add a few extra items to allow the machine to distribute the load evenly prior to spin. Hope this helps
Jul 07, 2010 | Electrolux Washing Machines
How can I reset my electrolux washing machine afer an E20 error?
turn the dial to off. Press and hold the start pause and the nearest option button. While you're holding them down, turn the dial one notch clockwise.
The machine will beep or flash, let go of the buttons. Release the buttons, then turn the dial slowly, stopping at each click until you get to "off". Now, turn to any setting, then turn to off.
Now, try the machine. If it works, I'm very happy. If not, perhaps someone else can help.
Good Luck
Apr 20, 2010 | Electrolux Washing Machines
Aug 08, 2009 | Electrolux EW1000i Front Load Washer
I have a ectrolux ewf 1074 with the padlock symbol
you need to turn machine on and hold the option and extra rinse buttons simultaneously for 6 seconds, the symbol will go and you'll be able to use your machine again as usual
Aug 02, 2009 | Electrolux EW1000i Front Load Washer
Unusual display on panel (padlock) machine can't be programmed door is not locked however
May 31, 2009 | Electrolux EW1000i Front Load Washer
Machine stops and the Start light is blinking
It might be teh same problem I have. in my case, teh machine works for a few seconds and then stops i.e. nothing else happens. no alarms go off either. In my case it appears that teh door interlocking device is faulty. You can by this spare part for around 22 euro. Replacing it is a bit tricky because you need to take off the locking device(the slot where the door locks into) and redo wiring. DONT mess up teh wiring becasue then you will need an engineer. Before you go looking for a spare part, you can take off teh interlock adn manual try to operate it. do this by turning on a wash and pressing teh two metal parts together on the lock.
May 18, 2009 | Electrolux Washing Machines
Washing Machines Logo
157 people viewed this question
Top Washing Machines Experts
