Question about GE APN10AA Portable Air Conditioner
GE APE08AK portable AC not draining
I read the posts on this and am confused. We use the small bucket reservoir and it has worked fine until now. Water is not draining into the bucket but within the unit and on the floor. The drain plug in the back is in the up position. The black hose that has been referred to in other posts and can be seen when the bucket is removed is attached at top with a zip tie. The other end is laying on the bottom with a white foam plug in the end and a metal clamp around it. Is the plug end supposed to be laying down and not hooked to anything? I used a Q-tip in both holes that water drips out of down into the bucket and water started draining out so I'm guessing something was plugging it. I'm going to try to use it again but am curious about the plugged end of the black tube.
  • kukuninja Aug 18, 2008
    Yes I have the same problem. Water does not go to the bucket but drains inside the unit and all over the floor . Will appreciate a little help thank you
2 Suggested Answers
SOURCE: APE08AK GE Portable Room Air Conditioner isn't draining
I had the same problem and unscrewed and removed the back cover (AFTER I UNPLUGED THE UNIT) and noticed there is a small black tube that the drain tube connects to. Mine was broken off track and I had to physically remove the small black tube, put it back in it's place and super glued new tabs along the side so it would tilk back and drain the water in the bucket vs. the floor via the unit.
Hope this helps.
Posted on May 27, 2008
No problem..just needing a manual for this product...GE 115 Volt Portable Electronic Room Air Conditioner APE08AK
GE has the manual on the product site: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=APE08AK . See the Literature and Manuals section on the left side of the page below the product pictures. The direct link to the manual is http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-7563.pdf .
I hope this helps.
Sep 02, 2011 | Heating & Cooling
I have a GE dehumidifier that i hooked a garden hose to for direct drain. it will work okay for awhile then will only drain into the drain bucket. is there something i can do to ensure that it will drain...
This seems to be a fairly frequent complaint on these GE dehumidifiers, and none of the solutions I've read here or anywhere else have fixed mine. My hose is clear, straight downhill, tight to the nipple with a good gasket, no plugs visible in the nipple, but has always filled the bucket rather than drained through the hose (and it's always bone dry). After two years of this and emptying the bucket, I'm about ready to disassemble it to see if I can fix it but with all of the other unresolved complaints I've seen GE should step up to the plate and post a solution.
Aug 19, 2010 | Vacuums
My GE portable a/c will cool when I first turn it on. The compressor kicks on and it cools fine, but after it runs a few minutes it kicks off and never cools again. The fan just runs. It does not appear...
I would say that if it starts cooling when it's turned on, then it has freon in it. Sounds more like it's kicking off on high head pressure, meaning the condenser is not getting cooled, head pressure builds up then a safety limit switch shuts it down to save the compressor from burning out.. Is there a condenser fan maybe not operating? or are the condenser coils clogged up with dirt?
Jul 15, 2010 | General Electric APE08AK Portable Air...
Simplicity AC unit, reservoir by pass
sounds like you possibly attached the tube to the wrong spot. why not run the tube outside, you are risking an overflow that will not shut the unit down
Jan 30, 2018 | Heating & Cooling
The water reservoir no longer being emptied by the pump.
I have the same exact problem suddenly. Unit is only 11 months old and not used that often. Bucket fills up and unit will switch to fan only. Drain hose (small black one) is not clogged but bucket keeps filling up. Never had to empty the bucket until yesterday, now I did it four times in one day (so far). Did you ever find a fix?
Aug 05, 2009 | Frigidaire FAP094P1Z Portable Air...
I have a portable air conditioner and the water condensation tank fills in about 4 hours of constant use. Is there any kind of portable water tank that I could attach to my unit that would allow me to...
I would suggest putting a condensate pump in the reservoir, find the tube that empties the water into the reservoir and direct that into the pump. You can run tubing from the pump to a sink or any other drain in the house that is convenient. Putting the pump inside the reservoir is a safe guard in case the pump fails, the water will fill and turn the unit off instead of flooding the floor. It would actually probably trip your breaker once the water hit the voltage on the pump but always better safe then sorry. Check out these pumps at amazon, you don't need anything fancy.
http://www.amazon.com/gp/product/B000UVUW6Q
Good Luck
Jun 11, 2009 | GE APN10AA Portable Air Conditioner
E4 ERROR MESSAGE ON SCREEN OF GE PORTABLE AC MODEL APE08AJM1
WATER BUCKET IS THE FAULT
the switch is more likely the cause try removing bucket and pressing lever manualy by hand then start it up again if it works you know the prob as this was mine the plastic connection aint the best
Sep 26, 2008 | GE APN10AA Portable Air Conditioner
Hope this helps.
May 25, 2008 | GE APH10AA Air Conditioner
GE APN10AA Portable Air Conditioner Logo
315 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Jay Plesset
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
