Replaced central ac fan motor but fan will not turn unless pushed into rotation. any answers?
    Problem Solver:
  • 12 Answers
Sounds like there may be a few causes.
1 Check the contactor
2 check the capacitor
3 check the wiring is correct for motor and wiring
4 check voltage to the fan
Posted on May 25, 2011
Compressor/Condensor fan need to be turned by hand to get it started. Do I need a new fan motor or could this be a larger issue.
If the fan does indeed run ok without any bearing noise and the blade spins freely when you push it and then runs ok your motor start capacitor is bad on the motor. This is usually a small metal oval shaped can with two wire leads attached to it to help kick the motor armature into spinning when your ac unit first turns on.
The capacitor is about 4 to 6 uf (microfarads) and at is available at a local electrical supply house and is under $10 and if your handy with small tools this could be replaced by yourself if you are willing. BE SURE TO PULL the OUTSIDE POWER DISCONNET before taking any covers off. 240 volts ac for the compressor motor and fan motor plus even the 110 volt control power will kill you before you can blink! The control relay from the thermostat in your home is 24 volts ac. Get a friend with a voltmeter to verify the circuits are truly dead before you attempt repairs. Good luck and use a voltmeter to make sure the power to the ac unit is off! Regards, Dennis
Aug 16, 2015 | Heating & Cooling
Tip
Replacing a condenser fan in centralized A/C
On of the common problem with centralized A/C unit is a bad condenser fan. I have known people who called an ac technician to fix their ac because of a bad condenser fan and suggested replacing the whole unit! Costing them a lot of money when all it needed was a 50 dollars condenser fan! If the condenser fan do not run or it runs only when you give it a push, it'sbad. You will also notice that it is vey hot. When replacing a condenser fan you may want to replace the starting capacitor too. Replacing a condenser fan is not very hard, just make sure that the power to the ac unit is turned off at the breaker box. Confirm that the wires are not live by using a meter or an ac tester. The fan motor are held with brakets sometimes just screws. Most fan you can buy that has reversible rotation by just reversing the plug. Make sure it is blowing upwards. If not reverse the rotation. So if you notice that the unit is not putting out cold enough air and you went outside and noticed the compressor running but not the fan, turn off the AC right away and do not use it untill the fan is replaced. Running the unit with a defective fan can damage the compressor caused by overheating.
on Jul 10, 2010 | Heating & Cooling
Ac compressor fan running backwards.
Fan motors have rotations, clockwise and counter clockwise, lead end and opposite lead end. If you are looking at the motor from the fan blade side and the wires are on the back (opposite) side of the motor then you are looking at opposite lead end. Then you need to determine the rotation of the blade. It will scoop the air, so turning the blade that direction will give you the rotation. They also sell motors that you can change rotation by changing certain wires they have added.
When you replace a motor you need to notice the rotation and order that rotation. which end of the motor you are looking at to determine it. Then order the same rotation when buying the new one.
May 30, 2014 | Goodman CKL24AR24 Air Conditioner
Central a/c fan will not start after flood
replace the fan motor as the bushes are dry and seized up.
Jun 09, 2013 | Heating & Cooling
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
Fedders 208/230 split system w/ dual cap , compresser runs but fan wont unless you give it a push , compresser won't restart if relay is hot
All kinds of stutt happens when you dont have a condensor fan motor. You need to change the run cap on the motor.
Aug 06, 2011 | Heating & Cooling
Fan will not start. Has been making noise but now will not move unless I push the blades, but feels stiff. Can it be repaired or must it be replaced?
Depending on the age of the unit/Fan there may or may not be oil ports, at the end of the motor, (Little plastic pull out's) Would use mechanical oil 3n1 ect.
Also The capasitor usually goes bad over time, which can be purchased at a local Hvac supplier usually less then $20.
If the Motor will not turn freely, several turns with just hand spining then more then likely you need to replaice the motor. Let us know how it goes. Can follow up with additional simple test for you if you need.
Oct 24, 2009 | Heating & Cooling
A/C not working, outside fan not turning without assistance
is fan spinning fast enough it has to have alot of velocity to cool condensor coils if you haft to push fan to get going its probably shot and get new motor the ac is a sealed system and hardly ever will leak freon!!!Best of Luck to You!!! :)
Jul 02, 2009 | Bryant 462AJC021BA Air Conditioner
Fan blade won't turn, but will slowly turn if given a push. What is the problem? How do I fix it?
Replace the fan motor capacitor. If that does not correct the problem you will have to replace the fan motor.
May 12, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
