Question about Nintendo Wii Console
My wii gets warm when it is powered down
I know that heat is extremely harmful to electronics, as i collect vintage computers. i have an external fan for my wii and the internal fan works and has always worked fine. i unplug it from my surge protector when im done using it so that it stays cool. my wii stays cool when powered up but gets hot when powered down. i have had it for little more than five months and it has always had this problem. i know that it is not normal for the console to get hot when it is off, as i have asked friends that own wii consoles about my problem. can anyone suggest a cheap solution?
  • bnewcomb123 Sep 14, 2008
    I FEEL SO STUPID! a simple solution to 6 months of thinking i needed a repair. thanks a lot.
    Sergeant:
    Champion:
  • 250 Answers
This is because you have it in standby mode. You'll also notice the wii light is orange when off, this is standby mode. If it's off the light will be red. You goto connect24 to turn off standby.
Posted on Sep 13, 2008
Will collecting vintage posters is a hobby?
Collecting Vintage posters is a serious hobby. You don't just buy posters and display them in your home or gallery. You have to give some efforts to care for you pieces. Vintage posters increase in value through time. Consider your collection an investment. Take care of it and give it the appreciation it deserves.
Sep 20, 2015 | Computers & Internet
Overheating
Like all computers and laptops, the electronic components within your HP G60 generate heat during operation.
Due to the cramped nature of laptop cases, this heat can build up quickly, resulting in possible operational and functionality problems with your G60.
Although there is little you can do to reduce the amount of heat the G60 produces as you use it, there are measures that will help prevent overheating and the subsequent damage it can do to your system.
Symptoms
When your G60 overheats, it exposes the delicate internal electronics to higher temperatures than are considered safe by the manufacturer.
Prolonged exposure to high temperatures could cause your components, circuit boards and wires to warp or even melt, as well as increase the number and frequency of system crashes and freezes.
Your G60 eventually will shutdown automatically and without warning to allow the heat inside to dissipate and prevent damage to your system.
Cooling System
Nestled inside your G60 near the component that generates the most heat, the central processing unit (or CPU), are a small fan and heat sink.
These help whisk away the heat as it's produced by passing it out of the laptop through three air vents located on the underside of the laptop.
A fourth air vent, for pulling air into the machine, sits on the back of the laptop, below the LCD monitor hinge.
Thorough Cleaning
Hair, lint and dust are all small enough to slip through or collect on the air vents, to clog the fan, heat sink and other openings.
This collection of dirt and debris greatly impacts the effectiveness of the heat dissipation of your G60 and allows the heat to build.
Use compressed air to clear the debris and dust or have a professional laptop cleaning technician thoroughly clean your laptop to encourage proper airflow.
Stay Cool
External factors can also play a role in your G60 overheating, such as placing your laptop near a heater or fireplace.
Using the machine on a soft surface such as a bedspread or pillow blocks the air vents, preventing the G60's internal fan from moving the heat inside the laptop out.
Stay away from hot environments and use your laptop only on solid surfaces.
Laptop cooling stands can provide extra help to your G60's built-in cooling system by providing an additional fan or two in a sturdy stand.
Clean the Fan on an HP Laptop
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
The fans in your Hewlett Packard laptop computer are important to keeping its processor from overheating and frying.
Over time, dust builds up within the blades of the fan and the copper heat sinks that distribute the air.
This causes the the computer to heat even faster.
To keep this from happening, clean the fans in your laptop regularly so they will cool it down faster.
Don't wipe away the dust with your own hands.
Use a cotton tip or air to remove it.
Unplug the laptop.
Disconnect its AC connector. Remove the battery.
This prevents any electric shocks while working on the computer.
Turn the computer upside down. Unscrew and remove the computer's RAM cover.
That makes sure it isn't in the way.
This is located behind the battery crevice.
Remember each screw and where it was located, then store the screws somewhere safe.
Remove the main plastic cover over the vents.
Remove the ducts and covers that are on the laptop's two fans.
These are the metal covers over the wide cylinder surrounding the fans, and they are held in place by very tiny screws.
You need a number one size screwdriver.
Remove the screws very carefully so as not to lose them, especially anywhere within the laptop's interior.
Wipe or blow away all dust collected on the fan blades and the fan's copper heat sinks. Compressed air will work best as long as you don't send the dust anywhere else within the laptop's interior.
If you don't have a compressed air blower, wipe away the dust with a cotton swab.
Place and screw the ducts and covers back on the fans.
Re-attach all covers on the laptop and connect the battery.
Check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Hope this helps.
Nov 25, 2012 | HP G60-235DX Notebook
Nintendo wii console overheats when playing and the fan is not working
Yeah for sure you aren't going to want to use it until the cooling fan is operational, you're lucky that you didn't kill it altogether. Try unplugging the fan wire, cleaning the metal contacts, and plugging it back in. If that doesn't do it, replace it. If you can't buy aftermarket cooling fans, try looking for wii parts on ebay. Aside from that, do all you can to keep it cool..... don't stack it in-between other warm electronic components (tv, dvd player, etc.), don't place it on a carpeted floor (the carpet will insulate the heat and keep it warm), etc.
Oct 10, 2012 | Nintendo Wii Console
I have no problem, in fact I want to tell you about the fan we bought in 1987, which was hung in the living room of a mobile home unit. It ran 24/7 till 2007 the fan was moved to the porch area of our new...
I'm a vintage fan collector. I had a fan like that in my collection at one point. It had the same "E89510 C" label. But I ended up parting it out because it was extremely difficult to repair. Do you know where you got it and who it was made by?
Sep 12, 2011 | Hunter Heating & Cooling
Hi. My Presario CQ50 keeps overheating sometimes its to the point it shuts off. It has gotten worse this week. Is there an at home solution to this problem?
Laptop heatup is mainly due the clogged heat sink and fan etc, which requires to be cleaned. It is strongly recommended that you clean the heat sink fan etc yourself or seek help from authorized professional at the earliest to avoid any damages to the PC.
Hope it helps! Do convey your feedback
CreativeTECH
Feb 22, 2011 | Compaq Presario CQ50-215NR Notebook
Mt dimension 3000 gets very noisy when the weather
That's because it heats up more easily and faster, which usually makes the fans spin faster and results in being noisy. Have you ever cleaned out the interior of the computer? If not, or if it's been awhile since it's been done, then buy some canned air for dusting electronics, open the side of the computer case (while it's not powered ON), and blow out the fans and the heat sink. If you get alot of just clogging up the heat sink, then it will not dissipate heat correctly; which results in the fans running more often. It that doesn't help any, then I would try to figure out if one of the fans is making alot of noise because it's going bad. You can find replacement fans on ebay, or at local electronics\computer shops.
Apr 10, 2010 | Dell Dimension 3000 PC Desktop
The wii will play a game for 10 minutes then shut itself off. It is plugged into the wall not a power strip. It seems to be extremely warm on the sides. We have moved it from the cabinet it sits in and...
its overheating. replace the fan inside. if its only new get it done under warranty off nintendo. if not, send it somewhere to get it fixed. max £20.
Aug 21, 2009 | Nintendo Wii Console
Know display anel getting EXTREMELY hot
Laura_kucari
I think you are feeling the heat coming from the oven vent. The fan still runs as it tries to cool down the temp in the compartment housing the electronics.
Regards
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
Wii console
Dear White Nose, Always have an external fan blowing on your game systems while they running, heat kills electronics fast !
Almost all electronics are made cheaply nowadays, in other words they use cheap parts that wont last very long, so the more you use it, the faster it will wear or burn out. They build things so that it will hopefully last a little longer then the warranty, and then break down so that we will have to pay them money to repair it or replace it ! That is the truth and this is a fact !!! One thing we can do is buy an extended warranty when one is available.
If we know were going to be using a product a lot, and we don't want to be spending money any time soon on repairs or replacement, it's only wise to get a "good" extended warranty !
God bless you and I hope this advice helps some !
Jun 05, 2008 | Nintendo Wii Console
Syetem get heat up
please dirll some hold into your system for air ventilation
if the system is in a conjusted place put it in an open place
if still it heats up please insert a external fan... which could be connected to the mother board (refer to manual).. this is because you are living in a warm country
Dec 15, 2007 | Computers & Internet
Nintendo Wii Console Logo
80 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
