Question about Numark ttUSB Turntable
Happy day! My son is hooking up his turntable to his Apple computer and he can, vaguely hear, from the turntable it is producing sound but the direct USB cable in is not producing sound from his Apple laptop. Can anyone make any suggestions? Thanks! Have a great evening with smiles to share :-)
    Brigadier General:
  • 8,546 Answers
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Numark-TTUSB-manual/id/530ci970/t/2/
Page 2 step 2.
Switch the turntable to Line unless you're using a Phono Preamp.
Posted on May 25, 2011
Too much bass
I didn't know that a turntable had bass control on it. If it has why not turn the bass down? I think it is your receiver not the turntable
Dec 30, 2013 | Audio Technica ATLP120USB Turntable
I have the gemini vinyl 2 mp3 professional usb turntable and it is hooked up to my computer and the software is installed. I can't hear the music through the computer and I can't record the sound. Help?
Look in your control panel on your computer and check the sound settings. For instance I have Sound Max on my PC and the imputs have to be set on to listen to different sound sources. Also there are level controls on it that can be set to zero.
Nov 07, 2010 | Gemini Audio Players & Recorders
Hooking a turntable with it's own pre amp to a computer and/or a home theather system gemcquaid mcquaid@northlink.com .
Check your inbox.
Hook the output to Aux. As for your PC, that would depend on your sound card. Basically, the same.
Mar 01, 2010 | Sony PS-LX250 Turntable
We have a SLDD33 turntable and cannot figure out why there is no sound? The auto function no longer works properly but everything else seems fine. It just stopped producing sound one day. Any ideas? If it...
The most obvious cause is a dead cartridge. The other cause is that the turntable is fine, but your amp is not. The reason being that the turntable input on your amp has a pre-amp just for the deck. So you might hear the tape/cd fine, but not the deck. If it is the amp, that's faulty, you can trace the wires from the socket to the PC board. Some amps have this pre-amp on a seperate PC board. You might find a single IC doing the work, my bet is that has gone.
Feb 11, 2010 | Technics SL-BD22 Turntable
I have a phono preamp hooked up to my Yamaha receiver for a turntable. My tall speaker tipped over and knicked the receiver and now my turntable will not produce any sound. Could this have blown the phon...
Let's figure out which hardware is failing. Connect the phono preamp to the CD or tuner input to see if it works there. It should. If it does, your receiver is at fault. Did the front panel controls get damaged?
How did the turntable fare in this accident? As a basic test of its ability to produce sound, hook it directly to the CD input and raise the volume slowly while playing an LP. If it's alive you'll hear a very weak, tinny sound, but I assume you know that or you wouldn't have a phono preamp in the first place and would probably be asking why the TT sounds so poor. :-)
Jan 19, 2010 | Audio Players & Recorders
Sounds from turntable
There will be some feedback from the turntable, and this is totally normal. Ive actually heard the music from the needle itself, and is nothing to worry about
Dec 28, 2009 | RCA ION-ITTUSB05 Turntable
I hooked up my T.52x turntable to my pioneer vsx-d711 receiver through the RCA input...nothing fancy. I have to turn my receiver volume all the way up in order to hear the records. All the digital media...
The signal produced by a phono cartridge is much smaller than a standard Line Level component produces. That is why the clas of equipment called PREamplifiers existed. Besides PREamplifying it to a level the rest of the circuitry can use it also modifies the frequency curve according to the RIAA standard to produce a sonically flat output. Without either process applied you will have weak, tinny sound from a turntable.
The Pioneer VSX-D711, like most modern AV receivers, is not equipped with a Phono Preamp. If the connector doesn't SAY Phono is won't do Phono.
Dec 28, 2009 | Stanton T.50 Turntable
Tried to hook up turntable to Amp and will not produce any sound. What am I doing wrong?
The most common cause of this is due to the lack of a phono input. The inputs on modern amps/receivers are line level. Turntables produce a lower signal level requiring a phono pre-amp to get to line level. Purchase a phono pre-amp and connect it between the turntable and the amp. That should resolve the problem.
Dan
Dec 03, 2009 | RCA Audio Players & Recorders
Old turntable works but is too quiet to hear
It sound like you may have to hook your turntable up to a phono input. Turntables have low level outputs. The phono input is designed to amplify this low level more than the cd/dvd inputs do. If you do not have a phono input, you can buy an external "phono preamp" online. Hope this helps.
Aug 04, 2009 | Audio Players & Recorders
No sound
Try setting the recordsettings of ur soundcard to "record what you hear". This way it will record ALL the sounds that are produced in windows. Warning: this also means that it could record an windows systemsound as well.
Jan 01, 2009 | ION Audio TTUSB10 Turntable
Numark ttUSB Turntable Logo
119 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Electro Med Services...
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
