Question about Cub Cadet Street Sign- tractor lawn riding mower parts
I have a Cub cadet series 2000 model 2146. When I turn the key the engine turns over but doesn't start. When I take the air filter off gas spits out when I choke it.
    Scholar:
  • 143 Answers
You need a carb kit it seems like the little stopper atached to the other end of your float is not stopping gas and is flooding the carb . try pinching the hose wit a pair vise grips gently though just to stop the flow of gas and then crank over if it starts try what i wrote down about repairing the carb.if you look thre is a round bowl held on by a screw or or a spring clip remove and when you get the new kit it will have a little triangle peice with a point somtimes the tip is metal sometimes it is rubber if it is metal there is a tiny rubber peice in the bottom of that hole needs to be replaced with new one also comes in kit . in the screw there are a few tiny holes if you dont have somthing small enough to fit in the holes get a tip cleaning set from home depot or lowes it is in the welding section it costs like 2 to 3 dollars it has tiny wires with ridges on it. clean out all the holes . somtimes the screw you remove to secure the bowl on if you look in the hole you will see a brass flat head screw in the middle of the carb so you are now looking in the stem on the center of carb remove it there are more holes in that as well if you dont have the little flat head dont worry about it it is about 2 inches in length over all . install new seals and put carb together . there should be a screw to adjust the gas mixture if so you should get a new one in kit it is long with a point and should have a spring on it remove old screw tighten new screw in all the way then turn back out two and a half turns and that should be close to the correct idle speed hope this helps
Posted on May 25, 2011
My cub cadet model 12A-18M7010 will not start. It has an automatic choke. No primer. I've changed the gas, checked the plug, cleaned the carbuerator. What could it be?
Also check the air filter. Some times if the paper filter is wet or clogged it will choke out the machine by not allowing air in to the ignition chamber.
Apr 17, 2013 | Cub Cadet Garden
Cub Cadet SRC 621, won't start. New spark plug, cleaned carburetor and air filter, Whiffs of smoke occasionally
Sounds like a sheer flywheel key. Common on the SRC 621. Kawasaki motor, correct. The flywheel key is under the recoil. Pull the flywheel and check the key. A very small key is there. Breaks and puts the engine out of time
Oct 16, 2012 | Cub Cadet Street Sign- tractor lawn riding...
White smoke comeing from front of engine on my 1042 cub cadet lawn tractor.
White smoke is typically an indicator of an oil leak. This could be a leak, broken ring, valve or piston problem etc. I would start with checking your filter to ensure oil has not leaked inside there. Next I would check the spark plugs for oil build up. Doesn't sound like it's getting to the exhaust.
Aug 07, 2012 | Cub Cadet Garden
Cub cadet riding mower wont start... parking brake feels loose wont turn over
see if the rod fell off there is a safety switch on the clutch/brake pedals if the rod doesn't move all the way the switch will not make the connection
Jun 03, 2012 | Cub Cadet 42 And 54 Inch Blade Operator's...
I have a cub cadet 2146 riding mower. I've changed the battery and replaced the fuses, still no power. What else could the problem be?
check the battery connections and also the earth cable if no luck their then check the fuses with a test light or similar and look for a feed to the fuses as the connections at the back of the fuses could be corroded
Nov 23, 2011 | Cub Cadet Garden
I have a cub cadet 2000 series model 2146. When I turn the key the motor spins but doesn't start. When I take the air filter off I see gas spit out when I choke it.
You could have one or more of several problems. With the gas scenario you mention, you're getting gas INTO the carburetor. But the carb could be grungy and in need of cleaning (90 percent of mower problems in my experience). My question is this: is the thing "Firing"? like do you hear it kick in like it wants to start. If not, then it may not be getting any spark. Take the spark plug out and buy a new one for about $3 (match the numbers up on the side of the plug ceramic). It never hurts to replace it anyway. With the info you have provided here, that is all I can give you right now, but hope it helps. Good Luck.
James
May 25, 2011 | Cub Cadet Garden
I have a cub cadet rzt 50 with a kawasaki 22hp engine it cranks and runs fine for a while and then sounds like its running out of gas, I shut the pto off and it eventually quits running, I pull the choke...
PDF]OPERATORLS MANUAL - Cub Cadet
https://www.cubcadet.com/.../CubCadetCatalogAssetStore/.../own...Cub CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline ...
cubcadet.custhelp.com/.../basic-troubleshooting---zero-turn-riding-mowe...
Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
May 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
552 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
