You may download a copy of the manual at http://www.singerco.com/uploads/download/1272_6268-_-6268_6267-wholeas-of-6_23_05-special.pdf
SOURCE: don't know how to use
first if you have a manual then fine you can read it but if you don't try threading it and try it out. see what it does at the setting it is at. then change one thing at a time and note the positon everything is at now. probably easier than you think and remember you can't break metal?? can you?? don't be afaid to try it. not being mean or anything but until you see what it does you really can't figure anything out. YOu maight try cleaning out the old lint with canned air and change the needle if you find it burred on end or even bent slightly. good luck
SOURCE: Stitch length control knob broken on my Necchi Supernova Julia
Contact Necchi directly (800-525-9987) and speak with the Service manager who may be able to get the part for you if they are available anywhere.
sewman7
SOURCE: Singer Touch Tronic 2001 Sewing Machine Stuck on Sewing Straight Stitch Only
I had a similar problem a couple of years ago. I finally figured out that I had the straight stitch needle plate (the one with the single hole), rather than the zig zag needle plate (the one with the curved hole). When I changed plates, it worked fine.
SOURCE: I'm trying to do a blind stitch with the Singer
check needle is correct and in machine correct.
SOURCE: Viking Husqvarna Model 6020 stitch selector will not turn.
look at the cam gear. This is the unit that the cam connects to. It could have a crack or be split completely. If there is a crack the cam stack will have to be replaced. The parts are hard to get and a good technician is needed.
