Question about Nikon Coolpix L110 Digital Camera
The camera ran out of battery and I put in 4 new alkaline batteries. Now the camera won't turn on at all.
    President:
  • 1,654 Answers
Unless the batteries are in wrong they must be dead. try to use new ones and check for the instalation some of these cameras use wierd configurations on which is positive and what is negative.
Posted on May 25, 2011
Testimonial: "What can I say. It was the most obvious solution but did I think of it? No. Thanks heaps."
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 116 Answers
Cameras **** alkaline batteries dry pretty quickly. If you check with the manufacturer, they will probably tell you that you are only supposed to use lithium batteries or rechargeables.
Posted on Oct 03, 2012
Please,what batteries do I use for my Nikon CoolpixL22. Thanks for your help
The L22 takes two standard AA batteries. You may use disposable alkalines or lithiums, or rechargeable NiMHs. Don't mix them, that is, use two of the same kind. If you use rechargeables, you must charge them separately; the camera is not a battery charger. You can use any brand, though I'd stick with the major brands.
Lithiums will last longer than alkalines but cost more. Rechargeable batteries cost more and won't hold a charge as long as alkalines, but can be reused.
Jul 27, 2011 | Nikon COOLPIX L20 Digital Camera
I have a Kodak DC290 which has not been used for a while. Put new AA's in it but it won't turn on. Camera belonged to my husband, who recently passed away. Also can't find the manual. Can you...
If it sat a long time with old batteries, make sure they did not leak and corrode the contacts in the camera. Look at them and clean if necessary.
Jul 24, 2011 | Kodak DC290 Zoom Digital Camera
My canon powershot a495 has a problem. it always
Alkaline batteries just don't have the power for more than a few pictures in today's power hungry digital cameras. Some batteries may also have reached their shelf life at the store, and though brand-new right out of the package may even have problems just powering startup of the camera. The one's that came with your camera are just to show you that the camera works, but as you've discovered, they'll only last for a few pictures. Digital cameras that use AA's for the most part should only be used with modern rechargeable batteries. If you read the camera's instruction manual concerning batteries, you should see the same recommendation.
Modern rechargeable batteries have over 5 times the power density of alkaline batteries (that's right, they last up to 5 times longer than an alkaline battery. And you can recharge them over and over!). Keep in mind rechargeable batteries will save you much money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Jul 04, 2011 | Canon PowerShot A495 Digital Camera
I got the kodak easy share 143 model camera coming brand new off of ebay yesterday,,,but it keeps saying my batteries are half drained, then dead after a couple of photos. Then if they're dead it...
Jun 26, 2011 | Kodak Cameras
I use some new alkaline batteries but the camera (Nikon 5600 coolpix) doesn't go on
Things to check first for a camera that won't turn on are battery contact points, and micro switches that are located on the battery and memory card doors. Troubleshooting tips on other things that need to be checked may be seen here. These tips won't work for every case, but they're worth a try.
Jun 11, 2011 | Nikon Coolpix 5600 Digital Camera
Cannon Speedlite 270EX doesn't turn on and I put new batteries in
Try cleaning out the contacts where the batteries touch. Make sure the battery door is completely flush with the body and see if you've inserted everything correctly. The type of battery you use also effects the flash recycle time and how it operates too. Have you tried using different types of batteries? Try using NI-MH instead of Alkaline and see if the speedlite will power. There's a test button on the flash and also an off-on switch you can try toggling around. The flash itself is very simple so if it still won't power on after all of that, you should contact customer support.
  • http://www.usa.canon.com/cusa/consumer/products/cameras/speedlite_flash_lineup/speedlite_270ex#ServiceAndSupport
May 17, 2011 | Canon Cameras
How do you get the camera to charge? I put in new batteries and it still says battery low and shuts off. I have plugged it into the computer and it still won't charge. It won't even turn on.
Some camera will not turn on (Turn on but not take pictures etc) when you plug it in USB, it will only communicate with the camera PC suite software to transfer pictures.
Regarding the battery, if your camera has mobile phones type lithium ion batteries then you can either charge these batteries outside if you have a charger for them or put the battery in camera and plug the camera with its charger that came with it. Its just like charging mobile phone.
If your camera uses AA size (pencil cell) batteries then you will need to either buy Duracell batteries (or any other good Alkaline battery, Duracell is good) and throw them when they stop working or
Buy rechargeable AA size Ni-MH or Li-Ion batteries with charger. Charge the battery with its charger for at least 12 hours before first use or follow the instruction written on battery pack.
I think you are either using normal carbon AA size batteries that are used in clocks or toys, these will not work in digital camera.
May 15, 2011 | Cameras
Camera turns off itself
This is likely because:
  1. You are using the wrong types of batteries (Alkaline, Ni-Cd or Ni-MH batteries are recommended for digital cameras) NOTE: don't mix different types.
  2. The battery is out of charging cycles and won't retain charge. (Most rechargeable batteries can be charged only about 1000 times after which they won't hold charge)
  3. The batteries aren't 'powerful' enough. (low quality rechargeable batteries with low capacity shouldn't be used on digital cameras, Always buy batteries specialized for cameras (from camera stores or studios))
  4. The wrong battery type is selected in the camera's settings. (Most cameras let you select the type of battery you are using from it's settings. Browse through the settings and see if this is the problem)
Hope that fixed it. Good luck.
Apr 28, 2011 | Nikon COOLPIX L4 Digital Camera
No pwer
What type of battery are you using? Do you have the right battery setting?
The camera's battery setting is set to "Coolpix" as the default (the original batteries it came with). If you're using regular alkalines, be sure to change this setting in the camera (Menu > set up > battery type > alkaline).
When the batteries ran out for the first time, I bought cheap dollar store batteries, and when I put them in my camera, it shut off immediately when I tried to turn it on, despite them being brand new. I found out this was because the batteries didn't have enough juice to power my camera. I replaced them with Duracell, and it worked fine after that (Panasonic, another dollar store battery works okay too).
Hope that helps.
Feb 08, 2008 | Nikon Coolpix L11 Digital Camera
Nikon Coolpix L110 Digital Camera Logo
143 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
