Question about Maytag Neptune MDG9700A Gas Dryer
Runs fine low heat - Maytag Neptune MDG9700A Gas Dryer
    Champion:
  • 239 Answers
Low heat is usually caused by intermittent gas coils. They are inexpensive and easily replaced. I have posted a link to order the valves for your convenience. The valves are accessed by removing the front panel and are loctaed on top of the gas valve assembly.
Gas Coil Kit $10.25
Kelly
Posted on May 25, 2011
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Heat pump fan only running air handler fan only running was working fine quit last nite now no heat but both faans running
Compressor must not be running. Possible capacitor, possible low pressure. Check it in cooling mode and listen for sound change out side to see if compressor runs.
Dec 11, 2016 | Heating & Cooling
Why do my all my lights work on my 2001 GMC jimmy except my low beams.
Replace the turn signal switch. All the exterior lights run threw it except the high brake light. There is a small plastic clip/switch in it that controls high and low setting. Because of heat it starts to melt and quits working.
Jul 05, 2015 | 2001 GMC Jimmy
I have a 08 g6 3.5 when I slow down or come to a stop my heat gets cool but when I'm driving it's warm. Temp gauge runs fine no issues with over heating.
Sounds like not enough coolant in your system. Double check your fluid level if low, add premixed antifreeze. If low you may have some coolant system leaks.
Feb 27, 2015 | Cars & Trucks
Hammering sound ptac
heat pump? possible causes: low freon. clogged / dirty coils. blower motor running?
Jan 20, 2014 | Heating & Cooling
I just purchased a used Jewel series spa a couple of weeks ago. Got it hooked up and everything was running fine. Now is seems the pump will not stop running. It is up to temp and keeps running at low
Low speed is your circulation function, all filtration, heating etc is done by the low speed. Check how many filter cycles and duration the spa is set to.
Is the temperature on the control panel correct? Verify it is with in a 3-4 degrees of a floating thermometer.
Jul 26, 2012 | Pool & Spa
It's running fine but not heating at all on any
heatman101--==-
Aug 04, 2011 | Whirlpool Dryers
We live in Texas and temperature is expected to hit low teens the next couple of days. Will I need to engage the emergency heat or should I allow the outside unit to run as normal?
if the temperature is going to be below freezing or near 32 degrees farenheit I would run the aux. heat as the heat pump is not efficent in low ambient outside temps.
Jan 07, 2010 | Heating & Cooling
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Jan 04, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Propane forced air heater
Need to make sure you are supplying a minimum tank supply of 100lb cyclinder. If smaller,you are producing co due to low gas flow
Nov 02, 2008 | Reddy Heater RLP100 Portable Forced Air...
Maytag Neptune MDG9700A Gas Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
