Question about Goodman CKL60AR60 Air Conditioner
Outside compressor dosent turn on - Goodman CKL60AR60 Air Conditioner
    Problem Solver:
  • 12 Answers
Is the fan running? If it is check the capacitor.
Posted on May 25, 2011
My Pontiac 2005 has an ad problem the blower dosent work the fan dosent and the compressor what can I do
blower dosent work the fan dosent ????? 2005 pontiac what ???? The heater blower motor isn't blowing any air , What fan doesn't work ? Need better info .
Jan 29, 2017 | Pontiac Cars & Trucks
Fridge dosen't seem to click off as much when it gets to temperature like it used to do, what can I do?
Try verifying the temperature range with a thermometer. For most fridge's you should see something like a low of 32 and a high of 40. Those would represent the turn off/turn on points for the compressor - that part that actually makes the fridge cold.
If it's swinging much outside those rages, the thermostat in your fridge is suspect. For most fridge's the thermostat is the know you turn to adjust the temperature. It usually has an attached wire/temperature probe that runs down behind a panel in the fridge and senses the temperature so the thermostat can command the compressor to turn on or off.
If it seems like the compressor might be at fault check with the manufacturer's website and you might find a parts diagram and identify the part. Then you can either call a repair technician or try replacing it yourself. You can purchase replacement appliance parts at many places on the Internet such as this site: Search Over 2 1 Million Appliance Parts
Good lcuk.
Mar 10, 2015 | Refrigerators
On my honeywell thermostat cool on keeps on flashing but ac dosent come on
On a Honeywell thermostat the flashing means that the system is in a delay to turn on the compressor. This is used to protect the compressor from coming on and off too often. The normal delay is about 5 minutes. After that the system should come on. If not there is s problem.
In order to help us help you we will need a little more information. What happens either at the inside unit or at the outside unit after the thermostat stops flashing "Cool"? Any fans come on? Do you hear a "KLUNK"? Any sparks? Please let us know so we can help.
Nov 20, 2011 | Honeywell Heating & Cooling
Air conditioner dosent work,the compressor dosent come on,fuse is good
The compressor clutch will not engage if the system is low on refrigerant. You may just need a recharge.
Jun 14, 2011 | 1994 Chevrolet Suburban
I can't get the compressor to run. As a test poured some gas in the carb. It ran 'til gas gone. Changed plug and inline gas filter still no go any ideas?
float stuck in the bottom of carb turn off petrol unscrew 10mmbolt on bowel remove it and clean out turn on petrol and c if it runs out wit bowel offif dosent take out float and blow out that should sort it
Jul 23, 2010 | Honda Powermate Contractor Pontoon Air...
AC compressor wiil not turn on
You will have to find the contactor which is located in the outside unit. And check the voltage at the contactor, 26 v as this is the thermostat calling for the compressor to come on. You can also push in the contactor and see if the fan and compressor start. There should be an outside fuse box close to your condensing unit. Good luck
Jul 23, 2010 | Samsung AW1203B Air Conditioner
How do I know if compressor of my house air conditioner is turning on when I start my air conditioner? When I start my air conditioner the fan outside the house turns on, the air is blowing from the vents...
if the compressor is starting there will be a very small dimming in the house lights,if you go outside to the unit and start it from the outside disconnect when the compressor starts you will hear a whine type noise coming from the outside condenser unit that is the hermetic compressor motor operating,no cold air can be a number of issues,low on refrigerant(not likely on the new sealed systems) a bad motor start/run capacitor(quite likely) a bad contactor on the outside unit that supplies power to the compressor,one leg of the 240volts that supplies the compressor power,the fan will run on 120 volts,but the compressor needs 240 volts check the fuses.breaker in the power panel
Apr 02, 2010 | Heating & Cooling
Works dosent cool compressor still works maybe recharge
Make sure filter and inside and outside coils are clean
May 12, 2009 | Sharp Heating & Cooling
Goodman CKL60AR60 Air Conditioner Logo
52 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
