Question about Gaggia Titanium Espresso Machine
Gaggia Platinum vision (not in product list)returning the following error: Prime Water Circuit - what do I do?
  • Anonymous Jan 03, 2009
    Hi I have the same issue. Have tried the suggestion to get rid of the air but to no avail.
    Have also rinsed the brew unit. The machine will complete a cycle if you select pre-ground and don't have any grounds in the compartment.
  • 515 Answers
You have air in the system.
Try to make a cup of water (tea).
Posted on Aug 16, 2008
I fixed it!!!
Take the brew unit out and remove the grey inlet peice (2 screws) then take out the peice with the perforated disc in it out and remove the disc. Clean the disc so you can see through all the holes and re-assemble.
This sorted my machine out and it now behaves correctly again.
Posted on Jan 03, 2009
  • nedmuz Aug 18, 2011
    hi ive looked to try and take out the grey inlet piece but it all seems to be pot rivots where are the screwwsss help !!!! cheers
SOURCE:
Gaggia platinum vision
Seems that the valve stuck in wrong position. Try to start cleaning mode.
May 20, 2014 | Coffee Makers & Espresso Machines
Prime water circuit error gaggia platinum vision coffee maker
The turbine flow meters contacts are corroded, or the turbine itself is broken.
Apr 10, 2014 | Saeco Odea Giro Plus Coffee Maker
What does wrench on screen of gaggia platinum vision indicate
I found a failing power supply board can cause the 'wrench' error code even in standby. The board is available for about $65 online and works in many Saeco models as well.
Jul 18, 2012 | Gaggia 74845 Platinum vision coffee maker...
Gaggia Platinum vision says dispensing failed
I suggest the spanner is telling you there is a fault, so you will need to get it serviced or repaired. It is doubtful that you can do anything.
May 06, 2012 | Gaggia 74845 Platinum vision coffee maker...
What does Prime water circuit mean for a Gaggia Platinum Vision?
You need to draw hot water from the machine in order to prime the machine after the masage leave you can us the machine normaly. If the masage apears very often then you will need to descale the machine.
Mar 04, 2012 | Krups Coffee Makers & Espresso Machines
My new gaggia platinum vision will not prime. it says "prime water circuit" and makes several loud clicking sounds and then says "restart to solve the problem", but this doesnt solve...
We had the same problem on our machine, and it was fixed by backing the strength setting (the physical dial on the front of the machine) off from the "maximum" setting a small amount. Somehow this was creating too much back pressure, and the useless "will not prime" message appeared.
Dec 29, 2010 | Microwave Ovens
NEW GAGGIA PLATINUM VISION GRINDER NOT WORKING ANY WAY TO FIX THIS?
If it's new send it to a service centre.
These grinders are failing and can also damage the power supply board.
Dec 29, 2009 | Gaggia Platinum Vogue 90800 Espresso...
What does it mean when the red exclamation mark light is flashing?
Either you need to prime the pump, or the brew unit is not in correctly, the steam knob is not in the right position, the tray is missing.
Sep 20, 2009 | Saeco Odea Go
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
1,044 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ekse
Marvin
Marvin
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
