Question about Diesel Compact Tractor 4x4 20hp Machine Tool
My recently purchased used MT180HD tractor will not move. I replaced all hydraulic oil,checked the clutch,and adjusted linkage. What next??? Are my hydraulic pumps bad?? Can a mechanical transmission be swapped into this hydraulic model easily?
  • 252 Answers
Hi there joedorava
is there input to pumps , are there any leaks in the system either oil / air
have you purged all the air from the hydro units and wheel motors
if air is entraineed in oil , you may get alot of noise from caviatation in the pumps and wheel motors also heat , and vibration and no movement until all the air is gone
top up oil to correct level
caviatation can be quite destructive on pumps etc
i assume you used the correct hydraulic fluid for the unit in question
have you checked changed hydraulic filters when changed hydraulic fluid ?
other than that cant give any more info
cheers pauly46
Posted on May 25, 2011
TS6.140 New Holland tractor clutch appears to be slipping how do I adjust it 2013 year model
There a lever clutch petal hooked to. Unhook linkage, move lever toward back of tractor. Screw linkage to aleign with lever.
Jan 04, 2015 | Garden
My 1989 nissan maxima needs clutch linkage adjusted. how do u fix tht ?
This car uses a hydraulic clutch where brake fluid moves the clutch disc instead of a cable or linkage.
You might have a fluid or cylinder problem, or the clutch may be worn out depending on the symptom.
Jul 08, 2012 | Cars & Trucks
PtO will not engage on cub cadet 1000
It would be helpful if I knew whether it was working and quit or has never worked. At any rate it has of course a live PTO on it (not dependent on the clutch to engage-disengage it). Check your linkage, make sure nothing has come loose and not moving the travel rod. Secondly some models have a hydraulic fluid compartment that is used for the PTO alone, check to see if this is the case and if so check fluid levels. Back to linkage, the engage mechanism is usually a lever of some type that moves a valve body and lets hydraulic flow under extreme and engage s set of input and output clutches together. If your engage mechanism is a magnetic clutch, check for bad wiring and burnt fuses. If it is a fuse replace with the same value as already in the harness. If the new fuse flows don't do like me and put a larger fuse in it, though that will show what wires are involved with the clutch engagement it also shows the wires to be replaced. Check wiring for ***** wires or wires worn and touching metal parts and grounding out.Back to Hydraulics again, unless you've loaded the PTO hard enough to burn the clutches out (which I doubt very much) it can only be that fluid is not getting to the clutches. Chances that there is a problem inside the tractor with the valve body are slim but possible. Most PTO that just quit are caused by linkage problems or low Hydraulic fluid. Check all the above, I believe you will find your problem lies somewhere in what I have explained. I farmed for 30 years and we ran from 140 -250 HP tractors and if a PTO went out it was usually linkage or low Hydraulic Fluid. Hope this helps, don't want to miss a crop over a PTO!Col. Dana Gillespie TSM
Apr 15, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I just replaced the clutch and pressure plate. Now when i press the clutch the oil light on the dashboard comes on and when I release the clutch, it goes off. Can you please assist?
Check your clutch linkage from the pedal to the bell housing. if you have a hydraulic clutch check the hyd. line and the slave cylinder---anything that moves when you work the clutch.
Check for loose wires hanging down or making contact with the clutch assy.---sounds like you have a rub somewhere that is grounding out or pinching a wire to the oil sending unit when the clutch is depressed. This will trigger the oil light. Hope this helps.
Jul 12, 2011 | Toyota Corolla Cars & Trucks
The gearbox will not select 5th gear (5 speed manual)
Without knowing what kind of car , engine, or year or mileage.... try these one at a time and recheck if problem still exists. Bleed clutch if it is a hydraulic unit or adjust clutch pedal if it is a mechanical clutch first. Next check linkage for missing or worn out bushings causing excess play. Next, Change fluid. Everything after this gets expensive.. used tranny or rebuild with a new clutch. Good Luck.
Jun 07, 2011 | Renault 18I Cars & Trucks
Is hydraulic fluid really used for both the transmission and hydraulics in the international 460 also where do you fill it?
caseih hytran fluid is used for hydraulics and transmission fill through plate on top of deck next to shifter check plug is located on left side of transmission housing next to clutch linkage rod probably square headed pipe plug
Jan 15, 2011 | Farmall IH Tractor 460, 560, 660, 2606...
Stuggle to get get gears(1-4and reverse) in a 1995 vw chico.Is the clutch gone?
The clutch may be fine but need adjusting or bleeding (if it's a hydraulic clutch). This can also be caused by a failing throwout bearing, pressure plate, clutch fork, low fluid in a hydraulic clutch or a mechanical linkage that's out of adjustment.
Check for low fluid first because it's an easy solution. If the clutch uses a cable or linkage check the adjustment, it may need tightening.
It's important to address this soon because when you have to force a transmission into gear you're wearing out the synchronizers and you'll miss them when they're gone.
lp
Dec 26, 2010 | 2004 Volkswagen Golf
Mt180d hrdraulic problem
Since you are not saying which hydraulic oil you want to change I will give you a site where you can log in and they can help you with the oil and any problems you have had since you didn't say what the problem was. You will have to become a member but costs nothing except your e-mail address’s go to http://www.tractorbynet.com/forums/mitsubishi-satoh/101519-welcome-hydraulics-forum.html and you can find what you need.
Jun 19, 2009 | Mitsubishi MT160, MT160D, MT180, MT180D,...
I just purchased a 2440 john deere tractor it was outside for some time so there was H2O in the hydraulic fluid. I changed fluid but I get very little movement from the tractor when I release the clutch. I...
would say that your variable displacement pump has rust or other on/inside, it.
Are you using hydralic fluid (not eng oil) in her?
Can you let it run on blocks for a bit - drain and re-fill transmission?
Apr 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Diesel Compact Tractor 4x4  20hp Machine  Tool Logo
349 people viewed this question
Top Diesel Garden Experts
Dennis Key
Dennis Key
john h
Ted Maxwell
Are you a Diesel Garden Expert? Answer questions, earn points and help others
