Question about Summer Infant Day Night Handheld Color Video Monitor with Night Vision
The camera still works but when its dark in the room nothing shows on the monitor. If we turn the light on it works. It seems like the night vision feature is broken. I covered what looked like the light indicator while the lights were on and the camera never went dark nor did it switch to night vision mode. When the lights are out if i turn a flashlight on I can see it on the camers
    New Friend:
I just had the same issue with 2 of my cameras, no night vision. Here's what I found after a little troubleshooting, in case this helps anyone. I used the diode check option on my volt meter to check each of the IR LEDs. Most measured around 1 volt but two were bad and didn't measure anything. I took two good LEDs from my other camera and replaced the bad ones. Fixed! I plan on buying a few more IR LEDs to fix the second camera. You can view the LEDs through your digital camera or cell camera to see if they are working. Hope this helps.
Posted on Jan 01, 2013
  • 1 more comment
  • egratner
    egratner Feb 10, 2013
    Where can you purchase the IR LEDs? How do you remove them to replace them?
  • dproddy
    dproddy Nov 17, 2013
    I picked some up at Radio Shack. You'll need a soldering iron and solder to remove and replace them.
  • jmccall004
    jmccall004 Feb 15, 2014
    how do you take it apart to get to the bulbs? i took the front off but the bulbs are enclosed in a white plastic piece? thanks
  • 3,018 Answers
  1. It should go to automatic night vision. If this feature is not working then the answer to will a flashlight work the answer is not very well. The light will have to be on the child and a flashlight does not have much light behind it. Perhaps if you put a small lamp on a dresser that shines on the area the child is, this may work enough to keep an eye on him/her. A flashlight not so much. Hope this helps.
Regards, Tony
Posted on May 25, 2011
Why night vision is dark
Had a similar issue. If the cameras have the night vision led lights and it's just one camera, the wire pair that supplies power to the lights may have a short, if all cameras are dark, the main power supply may be out. You can check with a voltage tester. Some cameras use three wires with a common ground, others are 4 wires. One pair for the video and one pair for power.
Aug 11, 2014 | Samsung SDE-120n 4 Channel DVR System
Bunker hill security color camera model 95914 suppose to have night vision, has the led lights that circle around the lens. Should those lights be red or at least light up for night vision? I can't see...
If the LEDS are truly for night vision only, then they are most likely Infra-Red types, invisible to the human eye, but visible to camera sensor. A way to test if they are IR and working is to point another digital camera directly at the front of the security camera at night.
The cell phone or webcam sensor will see IR LED's as white spots.
As for this model coming with night vision, I don't know.
Dec 01, 2017 | Audio Players & Recorders
How do you turn on the night owl nods3
Hello, First, don't turn on this Night Owl NODS3 during the day...Bright lights will destroy the image intensifier tube in mill-seconds. It used on during the dark hours of the night and look at bright city lights on the poles on homes.
You have two button; one with have o/1 (on/off) then the second but would be the IR light and it will have the IR on and some time there will be another button mark A and this button is used to enhance the image.
To turn on the button--all you have to do is to push it. Only in a dark room with IR button on. and only in the dark of the night. If it doesn't work then let me know drawbridge21@q.com send me a message. GB...stewbison
Sep 20, 2011 | Night Owl Optics Discovery™ NODS3...
I need red light phone number of dussledorf
Sep 14, 2011 | Night Owl Optics Optics
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
Can not focus. The lens moves fine from one end to the other but I'm unable to see clear images with or IR while in a dark room.
Don't IR illuminator in the dark room. Turn on a small light in one of the corner; such as, a small light bulb. increase ambient light a little at a time until you can focus. You flooding the dark room with IR illumination which will reflect everywhere in there. This might take care of the fuzziness in the monocular. stewbison
Jan 29, 2011 | Yukon 24021 Monocular
Can I See in Dark Room where light is off. Any device , Camera, Optics are available in market. if available please suggest me. and sent me rates of these.
Hello. only if there are some ambient light source. Very light glow. In the dark room with no light you would be luck see you had. It take light to activate the thin plates in the image tube. Check with Night Owl Optics in El Paso, TX. You can check with the large Optic Lens Companies and see what the have to offer. You'll need to get the diameter of the lens opening, thread size in which it will be in mil-meter mm . stewbison
Jan 28, 2011 | Night Owl Optics PVS-7U Goggles
Where can i use my Optics Explorer NOCX3 at.
Hello, at night! Please don't use your Nigh Owl Optics to look at light, bright lights, street lights, just use it in the DARK!!!. If it to dark to see throught your Night Owl NV turn on the IR illuminator. Then you can see in those dark rooms, and sneak up on your friends. GB...stewbison
Nov 24, 2010 | Night Owl Optics Explorer NOCX3 Monocular
I think my night vision quit working on one of my MobiCamAV cameras. if i use it while the lights are on it works fine. if i turn the lights off then you can't see anything that isn't almost touching the...
Seeing that it still works with light, something on the circuit board more than likely gave out. Look online for an IR illuminator, and mount that next to the camera for night vision.
Aug 13, 2010 | Mobi-Cam Mobi AV Monitor
Want Night vision
It won't work in a room with no light at all. But if you have even a light from your monitor it will work better than most of the webcams. If you need a webcam for complete darkness you may have a look at Security Cameras
Apr 23, 2009 | Logitech QuickCam Pro 9000 Web Cam
Summer Infant Day  Night Handheld Color Video Monitor with Night Vision Logo
4,318 people viewed this question
Top Summer Infant Baby Gear Experts
Colin Stickland
Colin Stickland
Paul Bade
Falling star
Are you a Summer Infant Baby Gear Expert? Answer questions, earn points and help others
