Question about Yamaha RX-V461 AV Receiver
Yamaha rx-v461 turns on then off - Yamaha RX-V461 AV Receiver
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for ntermittent shutdown.
Posted on May 25, 2011
What are the surround sound settings for a yamaha rx-v461?
It has many, depending on the your speaker configuration, the source hardware and the source material...
Read the manuals...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Yamaha-RX-V461-Receivers-manual/id/2526ci760/t/2/
May 07, 2011 | Yamaha RX-V461 AV Receiver
RX-V461 Yahama Receiver is hooked up to TV with optical THX cable but can't get sound. Tuner on receiver plays and all speakers work perfectly for radio listening.
double check input used on amp and make sure u use the auto format decoder fuction on your amp ok if it has none than turn it on optical digital ok that should work for you :)
Feb 10, 2011 | Yamaha RX-V461 AV Receiver
I own a Yamaha RX-V461 and since making a few changes, new Bravia TV and BLu-Ray DVD player, I no longer jhave sub woofer output. I bought a new sub woofer cable and even bought a new Polk 8" 300watt sub....
You can reset the settings to factory defaults via the Advanced menu - it should be in your manual (I have RX-V465).
Do it from the standby mode.
Press the STANDBY button on front panel (not remote) together with STRAIGHT button on the front panel. Now you are in the Advanced Setup. Scroll to the INIT menu and select ALL.
Now you will have all settings in the default.
Jan 24, 2010 | Yamaha RX-V461 AV Receiver
Need remote control code for Samsung BD-P1600 on a yamaha RX-V461 remote
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V461_U_en.pdf
this web page has complete manuel for your yamaha RX-V461 home theater system they list code for samsung tv as 30739
press dtv button
press code set button
enter five diget code any questions refer to online manuel good luck ron
Dec 12, 2009 | Televison & Video
Need a hookup diagram for yamaha rx-v461 plus yamaha yst-sw216 please
Here you can find the manual for your subwoofer. Looking at its back side, it has 2 RCA plug input for stereo. Receiver has just mono sub output, but as low frequencies are not easily locatable, mono is perfectly OK.
Just connect receiver SUB-OUTPUT with RCA cable to your subwoofer's RCA LEFT input. Then adjust volume to match rest of your speakers.
Feb 21, 2009 | Yamaha RX-V461 AV Receiver
I can't seem to hook up my DVR and VCR.
Hi..
Go to the site:
http://www.yamaha.com/yec/home.html?VNM=LIVE
Look up your model number.
You might need to register for a free password thing
Dec 18, 2008 | Yamaha RX-V461 AV Receiver
Hi all, I've just bought a yamaha rx-v461 amplifier. I'd like to know, with regards to Speakers A & B, if I can have both running together. I can't seem to work it out ?
Hi - You can download the manual by clicking the link underlined in blue below:
rx-v461
See page 30:
So no you can't run both A & B speakers together.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 09, 2008 | Yamaha Audio Players & Recorders
Rx-v461
but does it sound normal in all other sources?
Feb 18, 2008 | Yamaha RX-V661 Receiver
Yamaha RX-V461 AV Receiver Logo
127 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
