Question about Sport & Outdoor - Others
I have a Fleetwood 2001 Elkhorn 9u truck camper. The running lights do not come on when I turn on my truck lights. I would expect their is a blown fuse as the lights used to work. Where is the fuse box located on the Elkhorn camper?
  • 12 Answers
SOURCE: fuses blown, don't know which ones
there is a fuse box in the engine bay and a fuse box in the vehicle. the one in the engine bay is the upper right side(passenger). the inside of the fuse box cover has a map of the fuses....this is a mirror image of the fuse box, so hold it next to the fuse box to locate the proper fuse. the box in the car is on the left (driver) lower kick panel.behind , behind the hood latch pull handle. it too has a map on it with a mirror image. make sure to replace with the same amperage fuse!
Posted on Oct 28, 2008
  • 3 Answers
SOURCE: Fuse box diagram for a 92 Chevy K1500
On the fuse panel does it say they are on the same fuse?
Posted on Dec 12, 2008
  • 76 Answers
SOURCE: The dashboard lights to my 2001 dodge caravan do not work
there is a fuse/relay panel underhood, also another underdash. check fuses with a testlight if possible. make sure the reostat( little wheel beside the light switch) is in the proper position. The dashlights are a seperate issue from the turn signals, unless it's an underdash wiring issue. check the fuses and reostat and let me know what you find.
Good luck
R
Posted on Feb 27, 2009
motor1258
  • 6674 Answers
SOURCE: 97 dodge dakoata main fuse keeps blowing 140 amp fuse
Regulator in alternator obviously faulty, have it bench tested & fixed or replace alternator, and cure your problem.
Posted on May 19, 2009
  • 225 Answers
SOURCE: blown fuse, i think
pull one fuse at a time check to see if its blown,continue until you find the blown one(hold fuses to a light to see if the wire in fuse is seperated.)
Posted on Jun 13, 2009
Owners manual for 2004 fleetwood terry dakota 829t camper
If you can't find one on Fleetwood's website, most likely you won't find one on the internet. Call around to some RV dealers. You might get lucky.
Oct 01, 2016 | Cars & Trucks
Manual for 2006 FLEETWOOD prowler camper
Even though Fleetwood no longer manufactures Travel Trailers you may still want to call Fleetwood RV Owner Relations at 1-800-322-8216 and see if they can help you out with locating a manual.
You could also try ebay and see if anyone is selling a manual.
You could try facebook for an rv community.
or try this link
http://www.rvingthemidwestconnection.com/manuals1990newer.htm
Oct 23, 2015 | Cars & Trucks
Where do I find manual for fleetwood cheyenne pop up camper
try a service dealer for the van or go on line to the manufacturer for a pdf version
other than that talk to a good van retailer / repairer shop and see what can be done
Jul 23, 2015 | Sport & Outdoor - Others
Owners Manual needed
Here you go
http://www.pulsitemeter.com/fleetwood/-fleetwood-caribou-camper-manual.html
Apr 10, 2013 | Cars & Trucks
Looking for the fuses for marker lights on a 92 fleetwood camper
Exterior lights are power by tow vehicle, or you can hook to 12Volt battery or charge circuit. When your unit is plugged to hydro you should have one tab on tow plug that has +12vdc coming to it from converter circuit in trailer. Find that with a test light or meter, then when your sure you have proper wire in plug for running lights, use a jumper wire from one to the other to power lights temporarily while you find each problem with running lights .
Dec 03, 2012 | Saturn Vue Cars & Trucks
I own a 2002 Fleetwood Southwind Motor Home My bedroom slide out will not retract The livingroom slide out works fine Please help
This is the car and truck section, you may want to repost this in the RV - camper section.
I would expect to find a faulty motor or something binding up in the tracks.
Aug 28, 2012 | Cars & Trucks
How to winterize pop up camper 2007 fleetwood pop up it . this site won't let go any where except this car site so if you know how to winterize a pop up camper let me know
Any place that sells campers can advise you. I would disconnect the water supply line underneath the camper and open all faucets. This will drain the lines. Pour some antifreeze especially designed for this purpose in the toilet and in all sinks. Don't forget to flush the toilet and pour a little in the tank after you turn the water off. This will prevent the traps from freezing.
Oct 18, 2009 | 2004 Chevrolet TrailBlazer
Recently purchased and did not come with owners manual and want to learn the trailers accomidations
You can order a Fleetwood Owner's Manual by sending a check or money order for $8.00 to the address listed below. If you require a chassis manual, you can contact the chassis manufacturer directly.
Fleetwood Service & Training Center
PO BOX 1007
Decatur, IN 46733
May 25, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
2007 Tacoma Tail light problem.
Check the taillamp fuse on the truck. If it is blown, you either have a short in the wiring of the camper, or the 7 pin inverter box on the camper.
Oct 27, 2008 | 2007 Toyota Tacoma
Sport & Outdoor - Others Logo
102 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
