Question about Dishwashers
Timer will not advance, stuck on "Clean" blinking light, will not do anything else
    Champion:
  • 239 Answers
Your control has detected an issue with the heater circuit. You may be able to reset it by performing the following "button dance." Press the buttons in order within 5 seconds to reset the control.
Hi Temp Wash Air Dry Hi Temp Wash Air Dry
You may have Energy Saver Dry, but it is the same thing. If it does the blinking clean light again, look closely at the heater for burn marks or breakage.
Kelly
Posted on May 25, 2011
The machine appears to be stuck in a wash cycle. After unplugging the machine & plugging it back into an outlet you have no indicator lights. The only button that has a response when pressed is the...
this machine sounds to have a computer board problem I have a calypso washer also and i had the same problem so I ordered both computer boards and replaced them and everything was working like new , I haven't had any further problems since
Jul 31, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
I have 4 zones can run them manually; but they will not come on the automatic setting. Springs are strong; timer itself keeps accurate time. I did read inside the box about a "Silver Pin"...
If zones are not advancing, then 1) Clock motor is not rotating dial > replace clock motor, 2) on-off trippers are worn down > replace trippers, 3) or the day skipper is set to skip all days and all skipper pins are pushed down, 4) or sprinkler valve is bad.
The sprinkler timer dial rotates each 24 hours. The trippers cause sprinkler head to turn on zone 1 for example. Zone 1 waters until the dial rotates to part of dial with no tripper. Without a tripper on the dial, the timer turns off circuit to sprinkler. At this point, the sprinkler valve mechanically advances to zone 2 and waits for timer to turn off again. The timer does not advance sprinkler to next zone > the sprinkler valve is designed to advance each time circuit turns off. The timer just turns on and off. When next tripper rotates around, the timer turn on the circuit and zone 2 begins to water.
http://waterheatertimer.org/pdf/How-to-Set-and-Troubleshoot-Intermatic-sprinkler-timer.pdf
The silver pin inserted at 12midnight position is for advancing the day skipper wheel.
Open following link for parts and resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Jul 27, 2011 | Intermatic R8806P101C -...
Dishwasher started up....didn't notice it quit running overnight...dishes seem only half clean. The "clean" green light is blinking. Tried opening and closing and then re-starting it. Can't get...
Greetings,
there is a temp related problem..this could be in the wash cycle not letting water get hot enough or a heater failure....remove your kickplate..there is a tech sheet..it explains how to reset this blinking light.....Bruce Denton
Jan 18, 2011 | Whirlpool Dishwashers
While watching tv I touch something on the remote to make the tv go into "on timer" The red light is blinking. I have removed power then on again the remote and tv controls work but after 4...
Check the remote carefully for a stuck button. You may have pressed a button and it went a bit crooked getting stuck.
Also, remove the batteries of the remote and try operating the TV manually. If the remote is the cause, the TV will work correctly once you remove the batteries.
Another way to check is by using a digital camera, like the one in a cell phone. Turn on the camera and point it at the remote. If you see a white light coming from the transmitter, the remote is sending a signal. Look for a stuck button.
Jan 04, 2011 | JVC AV-27920 27" TV
My intermatic time HB51R flashes on and off when on the timer position (2,4,6, hours) it keeps the lights lit on the "on" position and "off" on the off position
I think the timer's photoelectric eye is getting too much light from the Load it turns on.
To check this, set timer at 2 hours, and then put black tape over the photoelectric eye so timer senses that it is dark and turns ON.
If timer does not blink with black tape, then problem is too much light with will cause on-off cycling of the timer.
If timer blinks with black tape over the eye, then timer is suspect. Exchange timer for another one.
Dec 05, 2010 | Intermatic Outdoor Timer/Photo Control...
TV turns off and the standing timer light blinks.
There is a timer option programmed into your set. Check the timer setting in menu, under advanced settings
Sep 16, 2009 | Televison & Video
MY whirlpool dish washer is stuck on "clean" status and light is juts blibking on and off
See this thread:
http://www.fixya.com/support/t157405-clean_light_dishwasher_stop_flashing
Sep 06, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwasher Timer won't advance
my timer has stopped functioning altogether. it was first an intermittent problem, but is now 100%.
Feb 18, 2008 | Dishwashers
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
