Question about Singer 3116 Simple
Bobbin keeps jamming while I am sewing - Singer 3116 Simple
  • 415 Answers
Check these two things first.. Pull the bobbin out and look at how it is wound. Is it evenly wound across the bobbin ? Is the bobbin moving with the thread coming out the right way? ie not put in the bobbin casing backwards.
Try a different bobbin to make sure it is not the above problems. If it sews ok then there's something with the way the bobbin is wound or inserted. Also make sure when you put the bobbin back in the machine you feel/hear it click into place.
If that's ok then check your needle to see if it is bent, or in wrong or the wrong type of needle for the machine (tho most new machines all can use regular needles...older machines sometimes required specific needles made for that brand). Try changing needles.
Posted on May 25, 2011
It keeps getting tangled up here the bobbin is underneath and keeps getting jammed
try changing the needle--make sure it's the correct one for the fabric
being sewed
rethread the machine ---using every thread guide
try using a different bobbin
try turning the bobbin over the other direction
clean under the needle plate and in the bobbin area for lint
also could be a timing problem and the machine would need to be
checked at a sewing machine repair shop
Apr 12, 2013 | Singer 3116 Simple
When sewing, it jams up right off the bat.
try rethreading the machine top and bobbin
try turning the bobbin the opposite direction
clean under the needle plate and in the bobbin area for lint or loose
threads
make sure the top thread has not come off the thread take up lever
Jan 22, 2013 | Sewing Machines
Sewing then beeing then jamming up
The Beep is an alarm telling you to stop sewing and find the problem. Since it is jamming in the bobbin area, you should start there. Remove the fabric, then remove the bobbin and bobbin carrier... clean and remove any stray bits of thread from the bobbin area. You also should examine the needle or change it as a matter of course.
Aug 18, 2012 | Singer 8763 Curvy
I have a Singer Touch and sew 600e, the bobbin thread is all bunched up and machine jams up with thread. How can I fix this? Is there a simple setting that I am missing.
rethread the machine top & bobbin
make sure the bobbin is inserted correctly in the bobbin case
make sure the top thread is not coming off the thread take up lever
make sure the bobbin is wound correctly
if these suggestions don't work, I suggest that you take the machine
to a sewing machine shop to have it checked
Aug 06, 2012 | Singer Sewing Machines
Out of nowhere, after working fine for weeks, the bobbin thread started breaking, and then stopped "wrapping" properly around the outside of the bobbin while I sewed. It keeps jamming to where I...
Change needle
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& bobbin is threaded correctly & inserted in the bobbin case or shuttle correctly
Check tension 3 or 4 is usually good
after you try all this & it keeps jamming then it may need to be serviced
Nov 24, 2010 | Husqvarna Huskystar 215 Sewing Machine
Keeps getting jammed
Give these solutions a try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin as there could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting jammed in your machine.
I hope this helps.
Dec 29, 2009 | Sewing Machines
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
caught in your machine.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Singer 7470 jams and buzzes
To learn how to solve bobbin jam and select the correct needle, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Dec 22, 2008 | SINGER 7470 Sewing Machine
Bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Apr 02, 2008 | Singer 2662
Singer 3116 Simple Logo
400 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
