Question about Dell Inspiron 5150 Notebook
Mouse problem when running on ac power
I replace the battery and ac power charger a couple of weeks ago , since then when i run the laptop (inspiron 5150) on battery everything is fine . When i put the charger on the mouse its freeze ? ? any ideas ?
    Genius:
  • 2,028 Answers
Might be a driver glitch. Try uninstalling the drivers for the touch pad, some times refered to as synaptic pointing device, from the devic manager, then plug the power supply in and reboot. The machine will find the touch pad, and reinstall the drivers. Try this and let me know.
Posted on Aug 15, 2008
Our year old Dell Inspiron 1545 currently won't turn on anymore, for the past week it would not charge so we were just keeping it plugged in. It claimed the ac adapter was unknown, even though we had been...
You have a bad or loose DC connector on the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Dell Inspiron 1545 Notebook
Dell Inspiron 6000 won't charge
Since you have already replaced the battery and the laptop works with the AC charger, then probably the charge circuit in the system board (mother board) is bad. I have rarely seen an AC charger that will power the laptop but not charge the battery. 99% of the time, if it is not the battery, it is the system board.
May 05, 2010 | Dell Inspiron 6000 Notebook
It turns on for a few seconds then shuts off
Since you have already replaced the ac adapter. The problem is still there. the most likely cause of the failure is bad motherboard. Remove the battery from the laptop and disconnect the ac adapter . Press the power button for 10 seconds. Reconnect the ac adapter and try powering on the system. If the same doesnot work
Try the steps in the link
http://tinyurl.com/yd842up
Thanks for using Fixya
proton
Mar 15, 2010 | Dell Inspiron 1318 Laptop Computer PC...
Dell 1525 won't run on ac but will on generic battery
Dell systems will not charge the battery without a Dell Branded AC adapter connected to the system (The BIOS looks for the adapter ID and disables the battery charger if not ID'd)
It appears, that since the system will not power on with either AC adapter, that there is a problem with the power connection of the system. You can replace the power board
http://cgi.ebay.com/DeLL-Inspiron-1525-1526-Power-Jack-Board-48-4W006-011_W0QQitemZ380212346664QQcmdZViewItemQQptZMotherboards?hash=item58866bff28#ht_953wt_1165
if that fails to resolve next is the motherboard
http://shop.ebay.com/i.html?_nkw=dell+inspiron+1525+motherboard&_sacat=0&_dmpt=Laptop_Adapters_Chargers&_odkw=dell+inspiron+1525+charger+board&_osacat=0&_trksid=p3286.c0.m270.l1311
Mar 14, 2010 | Dell Inspiron 1525 Notebook
My 1501 Dell Inspiron wont turn on. The charger
The ac power jack needs to be either resoldered or replaced.
Dec 09, 2009 | Dell Inspiron 1501 Notebook
Battery Not Charging
Sounds like the power supply has gone bad. You should get a new power supply. You will get this message when he power supply goes bad
Feb 12, 2009 | Dell Inspiron 640m PC Notebook
Dell inspiron 6400-runs slow on AC power but not on battery
uninstall any energy management software provided by dell and then check.if the issue is not resolved then the issue is with the converter board as it is heating up.
Jan 29, 2009 | Dell Inspiron 6400 Notebook
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
Laptop freeze when in ac charger
You really should have a cheap multimeter to help in this case.
There are three possible failures; the new battery pack has a shorted cell, the charger is defective or a regulator internal to the laptop is failing.
With meter, you can check two of the three areas; the battery pack and the charger. Depending on which kind of batteries are used in the pack, if it is charged, you can determine if it is completely functional by checking contacts on the case of the pack. The most common type of battery used is the nickle-metal hydride type (NiMH) which has a nominal voltage of ~1.2 volts.  If the pack is rated 6 volts, you could measure either 4.8, 6 or 7.2 volts with the last one the most likely. If it measures 4.8 or 6 volts, it probably has one or two cells shorted, making it useless.
The charger could measure all over the map; many of them are unregulated and if they are rated at (for example) 9 volts, they could easily put out 14-20 volts when they do not have a load on them.
If those two items seem to check out OK, then the regulator in the system has gone bad. This might be on a separate board inside but to check it out, you really need some technical experience, otherwise you don't really know what you are seeing or looking for.
Sep 23, 2008 | Dell Inspiron 5150 Notebook
Dell Inspiron 6000: even when I plugged in, it still appears to be running on battery
Possibly. To tell if it's just a battery issue, take the battery out and try starting it on AC only. If your machine starts and works properly then the battery is the only problem and replacement will cure it. If it won't start or doesn't work properly, then I'm afraid the failing battery has shorted the power managment chip on the motherboard. So, give it a try, and let me know. If you have any other questions feel free to ask.
Jul 22, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 5150 Notebook Logo
53 people viewed this question
Alun Cox
