Question about Frigidaire FAC124 wall/Window Air Conditioner
My frigidaire air conditioners spit dirt all over the floor. My window unit and my through the wall unit in a sleeve both do the same thing. I called Frigidaire two years ago and they told me there were no reported problems. I keep the filters clean and don't know what is causing this. My rugs and furniture are full of dirt particles when I use these units. I have had air conditioners for many, many years and have never experienced a problem like this. Please advise me if this is a problem with this make and what I can do to solve this. The units work fine but dirty my rooms.
    Guru:
  • 1,524 Answers
1. Turn units off
2. Remove Filter
3. Spray a foaming cleaner on the coils (Dow Bathroom Cleaner)
4. Use a spray bottle filled with plain water
5. Replace Filter and Grill
Posted on May 25, 2011
My exist. unit is a very old sears coldspot through the wall mounted in a 12x18 in.exact sleeve. Can i remove unit and replace with FRA052XT7 ?. Exist sleve is vented on both sides & back.This is...
Get rid of the old stuff,too big to be used
Newer unit can't be inside the old sleeve as you call it
Just install the new unit how you see fit, to seal
it up
5000BTU is too small
A 7,200,8,000 or 10,000 BTU is the same size & about
the same price.
Jul 18, 2011 | Frigidaire FRA052XT7 Thru-Wall/Window Air...
My frigidaire wall unit ac is drippijng water inside of apartment. i have used a level when it is out of the wall and it shows ac is tilted correctly to the b ack but when i put it in the wall the level...
The drain holes in the bacl are plugged with dirt...
pull the A/C out and check for the blockage and remove it so that the unit will drain properly.
The drain holes are usually in the back corners...
heatman101
Sep 24, 2010 | Frigidaire FAC124 wall/Window Air...
Need to remove through wall fedder air conditioner
If it has a sleeve, just remove the front cover and give a little yank on the unit and it will start sliding out of the sleeve. Unplug the unit first, and the unit will slide all of the way out of the sleeve and you can just set it on the floor or wherever.
Jul 06, 2010 | Heating & Cooling
Do you need brackets for outside wall installation for the frigidaire 15000 btu air conditioner.
No you do not. Not a bad option, but if wall sleeve nstalled properly this unit will not need brackets.
May 11, 2010 | Frigidaire FAH085N1T Air Conditioner
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Frigidaire window unit spits water into room
To be honest with you this is a good and a bad thing. The bad thing is that it is spitting water into the room. The good thing is that the unit is running Great. The amount of humidity it is removing. is greater and faster than it can run down and off the coil. See if there is any possible way to deflect the water. i would recommend trying to attach a piece of screen door material. It will likely keep the water from going through it.
Dec 17, 2008 | Maytag M7D24E7A Air Conditioner
Using a Wall Air Condtioner in Window
It is called a mounting kit and can be purchased at Home Depot, Lowes, or an appliance store.
Sep 29, 2008 | Frigidaire FAC124 wall/Window Air...
Trru the Wall Oversized
Drop in a Frigidaire 25,000 btu, 230-volt Electronic Control Air Conditioner (Model #FAS256R2A). It is Way More Cooling than you need, but it is a very efficient unit and will provide quiet, nearly instantaneous room temprature reduction! Width 26-1/2... Height 18-5/8... Wall Sleeve Included... about $450.
Jun 23, 2008 | Frigidaire FAC124 wall/Window Air...
Through the wall vs. window installation
I just purchased an alleged "window mount" air conditioner with the closest dimensions to the existing model. Do these mount as through the wall as well? My current opening = 18 x 26" the new purchase is 16 27/32 x 26.
There are 2 different types of window air conditioners – there are the window type of which will fit in a window that opens top to bottom and there is the slide in model of which the actual air conditioner will slide into a metal sleeve which is very common in apartments. In either case you need to measure the inside of the metal sleeve and then give that to the air conditioner dealer and he will know what to do and there is also a POS (point of sale) @ the store of which will also assist you in the measurement of the A/C unit – the window unit you need to measure the opening of the window itself, I hope this was helpful
Apr 09, 2008 | Frigidaire FAC124 wall/Window Air...
Frigidaire air conditioner
remove cover .It might have two screws on the side or just pops off. Pull unit out from cover. if it does't move remove screws in back of unit near condensor
Dec 20, 2007 | Frigidaire FAC124 wall/Window Air...
Frigidaire FAC124 wall/Window Air Conditioner Logo
373 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
