Question about Kenmore Dishwashers
Hello, the "clean" light continues
  • Kenmore Master
  • 2,605 Answers
Hello, Welcome to FixYa.
Based on your description, "clean light is still on" this is actually an error code as you may or may not know, associated with the heating process. What typically happens is poor water circulation preventing the water from heating properly.
To resolve this, I'd start with the following...the wash pump area. You`ll need to follow these steps to clean it.
1 ) Remove the turbo wash tube if applicable to your model, it pulls off, i.e.
the
2 ) Spray arm removal. hold the center nut and spin the arm.
3 ) Now you can remove the upper spray arm supply tub or referred to sometimes as "rear feed cap".
a ) lift to depress the rearHello, the "clean" light continues - 87fb0d6.jpg/i>
b )Hello, the "clean" light continues - 5f19a61.jpg the feeder to the right ( clockwise ), i.e.
5f19a6Hello,
the
4 ) Now you can remove the center nut...
Then remove the four # 20 torx head screws holding the filter in place, and lift the filter out.
Below the filter you`ll find food debris, undissolved detergent etc, but also a cover with a single #10 torx head screw to remove and the cover will pull straight up and out. the arrows from left to right in the image indicate...
1) screw location
2) tab to pull up on
3) the latch you may need to twist to the left to remove the coveri.e.
Now you should see the chopper and screen assembly, it too can be clogged up pretty bad, clean it best you can...you don`t really want to remove this part. Make sure there is no debris present where I've indicated here with the arrow below.
If my explanation is not clear enough, here`s a link which provides a pretty good video of how to do this, these guys aren`t pro`s but the "how to" video is pretty thorough nonetheless.
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Once these actions have been performed you'll need to clear the error code. to do so is as followsPress the following buttons in this sequence...
HEATED DRY - NORMAL, HEATED DRY - NORMAL, HEATED DRY - NORMAL
This diagnostic cycle may take approx. 15-20 minutes to complete. Let it proceed through to completion and you should be good to go...unless the heater itself is at fault or a wire has vibrated loose from the heater...those are steps to follow if OR when necessary.
Let me know how you make out, please keep me informed if you need further assistance or anything is unclear. Please take a moment to rate me assistance and a short testimony is appreciated as well.
Thank you for choosing FixYa and good luck.
Regards,
Macmarkus :)
Posted on May 25, 2011
  • 1 more comment
  • tecurtis Jun 11, 2011
    Macmarkus, any idea what the clearing code is for a Kenmore Elite model 16592200? The touch screen reads from left to right: Smart Wash, Anti Bacterial, Pots Pans, Normal Wash, China Gentle, Quick Rinse, Hi Temp Scrub, Sani Rinse, Air Dry? Thanks.
  • Mark MacDonald
    Mark MacDonald Jun 11, 2011
    TECURTIS,
    This is to address your question about the cleaning code...I'm presuming you want the sequence to "reset" the clean light error. If you have cleaned out the pump and insure there is no component issue causing the error you can try this and let me know. Hi temp Scrub-Air Dry, Hi temp Scrub-Air Dry, Hi temp Scrub-Air Dry. That should initiate a short test cycle which once finished allow the control to reset (if a fault or failure does exist the error code will return). I'll watch for your report. Good luck.
    Regards,
    Macmarkus :)
  • tecurtis Jun 13, 2011
    Macmarkus, the code you provided worked, but my clean-out job didn't (or wasn't the problem). The machine cleared the diagnostic cycle so I ran a cycle with an empty dishwasher to be sure it would work...it didn't. At this point, I think I need to call the professionals. Thanks for you tips.
Danby portable Dishwasher advances from pre-rinse to dry and then beeps continuously and dry light continues to blink. Doesn't proceed, reset or stop cycle. Just continues to blink.
I actually found out (one of) the solution to this by accident. It could be the water source is not providing enough pressure
I purchased a Danby DDW1899W-1 and, using the connector screwed into my utility sink in the basement, I connected the water. When I tried to run a cycle, I had the same results (filled/emptied 4-5 times, beeped and went to dry cycle).
My alternate, long term plan was to put a Y-splitter (with shutoffs) on the hot water line for my washer, and have one hose go to the dishwasher when needed. I purchased a washer line hose from Home Depot and a 3/4" to Quick Connect fitting from Ace Hardware and then connected the dishwasher to this.
And, Voila! Problem solved!!!
To confirm this was the solution, after the first completed cycle, I connected back to the faucet and, once again had the fill/empty/beep/dry problem. Reverting to the split washer water feed, it was able to run the cycles properly (again!!!)
So you may just need a line that will supply more water pressure to the dishwasher.
Good luck and, hopefully, this solves the problem.
MP
Oct 18, 2014 | Danby Dishwashers
Status light blinking
Please do a full clean up of the machine after checking in all the connections to the mains panel.Please check this link for tips to go about:http://www.espares.co.uk/advice/dishwashers/a/3/174/cleaning-your-dishwasher.html
Mar 12, 2012 | KitchenAid KUDS01IJ - Multiple Color...
My quiet partner 111 whirlpool dishwasher is flashing clean
Hello.
Manufactured by Whirlpool, Kenmore dishwashers have an electronic control panel that must be unlocked in order to set or make changes to your dishwashing cycle. If an error light is blinking on your dishwasher's control panel, the panel must be reset before you can gain access. Blinking lights on your dishwasher control panel may signal a mechanical problem that needs to be repaired. If the lights continue to blink after you've reset the control panel, contact Sears to service your Kenmore dishwasher or consider troubleshooting the appliance yourself.
1Press and hold the "Heated Dry" button on your Kenmore dishwasher for four seconds to unlock the dishwasher control panel.
2 Press the "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" buttons one after the other, in fairly quick succession.
3 Wait for the dishwasher to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the end of the diagnostic test cycle. This should reset the control panel on your Kenmore dishwasher.
Thanks.
Nov 04, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
The clean light keeps blinking and the dishwasher will not turn on. have tried to push cancel which makes the clean light blink faster.
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
Kevin
Apr 16, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Green light is blinking over "start & resume"
It sounds like he didn't run it completely through try holding the cancel button down for a few secs.
Mar 22, 2011 | Magic Chef DU6500 Dishwasher
The green light for "clean" is blinking green and
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwasher started up....didn't notice it quit running overnight...dishes seem only half clean. The "clean" green light is blinking. Tried opening and closing and then re-starting it. Can't get...
Greetings,
there is a temp related problem..this could be in the wash cycle not letting water get hot enough or a heater failure....remove your kickplate..there is a tech sheet..it explains how to reset this blinking light.....Bruce Denton
Jan 18, 2011 | Whirlpool Dishwashers
Clean light continuously blinks, dishwasher will not run.
Hello
Clean light issue can be resolved by pressing the HIGH TEMP WASH- HEATED DRY buttons for 3-4 times. Please get back to me if you have any other questions.
Kevin
Nov 14, 2010 | Kenmore 15899 Built-in Dishwasher
Electronics problem with Maytag Dishwasher
the outlet pump may have become clogged, try removing and cleaning it.
Mar 26, 2008 | Maytag 24 in. MDB9150A Built-in Dishwasher
Dishwashers Logo
191 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
