Question about Toys
I have the hd-6838 remote control ferrari car and the remote control doesnt work for the car. the pedals on the car work and it moves around the controller turns on but it doesnt work for the car at all. how can i fix this problem
  • 3 more comments
  • diana May 25, 2011
    yes i did just get it and i was aware that the remote didnt work but i was told i can bring it to someone and it can be fixed however i waned to take it upon myself to fix it
    the batteries on the remote are fine because it does turn on
    the antenna on the remote also works
    the signal from the remote or vise versa isnt picking up for some reason
    ok thanx for ur help
  • 3,018 Answers
  • Did you just get this and the remote does not work?
  • Check the batteries and change as necessary.
  • Check the antenna on the remote and the receive Halo on the car itself. The halo is what receives the signals from the remote.
  • There is not a lot of reasons for the remote not work. They do get dropped and the circuitry starts to malfunction. The batteries and the antenna/Halo.
Regards, Tony
Posted on May 25, 2011
  • Iron
    Iron May 25, 2011
    • If you just got it and it is malfunctioning I would inquire about an exchange for one that works from the dealer or manufacturer. The things I listed are the common problems. It could be some major manufacture defect being new. If it were me looking at it, the way any tech would do it, is to test every single electronical component with a mulit meter and other appropriate meters to see what parts are failing.
    Tony
  • Iron
    Iron May 25, 2011
    • Your welcome.
    Tony
Pedal is not working
the variable switch is the pedal, if its not working its either damaged worn or disconnected, i dont know if they have parts for this but if you remove the switch and check it, using a meter to see if its damaged, you may even be able to replace the switch by looking for a switch on line using the one you have.
Jul 12, 2017 | TrendTimes.com Toys & Hobbies Remote...
Hi, i have a kids remote control eletric car model no HD 6838. one of the wires has come off and the motor wont turn. the wire is a single wire which is pink in color but i cant find were it goes to....
See the damages that cause to this type of toys cannot be fixed.But in sum case's it can be fixed.For that you should go to a near by toy store.They will find out what is the problem that cause to your toy.And if they can they will fix it for you.
Apr 07, 2011 | Electric Eyeware Remote Control Power...
Can't get thrustmaster f1 ferrari wheel to work with PS3 Nascar 2011. Wheel hooks up to system but once game is launched does not function (neither do pedals)
Same problem. I called Thrustmaster yesterday and they said that they're working with Nascar to fix the problem. They couldn't give me any guarantees that it would be fixed, though.
Apr 01, 2011 | Guillemot Thrustmaster 2960697 FERRARI GT...
I HAVE JUST RECEIVED A TOY RIDE ON CAR HD-6838 HOW DO I ASSEMBLE THE TIRES THE MANUAL ISNT VERY GOOD AT GIVING DIRECTIONS
One of my tires cracked into a million pieces is there anywhere place ect I can get a replacement tire for the no. Hd-6838
Mar 10, 2011 | Toys
I bought the battery operated with remote control ferrari f430. My battery died. I received a new battery from the manufacturer and when I went to switch them out, the wires are welded to the existing...
hi, easy operation but first if the car is fairly new, call the company and ask their advise, cutting wires will probably void the warranty.
1.cut the wires and strip between the old battery and the car.
2. strip and connect the new battery by twisting together and securing with wire nuts available at any hardware store on the planet, like these
dpurlee_0.jpg 3. test the car, if it doesnt work correctly or at all, the + and - are probably reversed, switch and try again.
4. its a good idea to reenforce the wire nuts with duct or electrical tape after they are tightened.
good luck!
Feb 08, 2011 | Ferrari F430 Battery Operated 6 Volt Kids...
I have a 94 ferrari 348 spider and everytime I press my clutch pedal down my brake pedal moves down alittle also, where when I am trying to leave at a light it feels like something is holding me back,...
Check the pedal assembly bolts they may be loose or a weld has broken under dash . Check under hood have some one depress pedals watch for movement that may not be normal .
Nov 03, 2010 | Ferrari 348 Cars & Trucks
Problema with thrustmaster racing whell
this is because the 2 pedals are acting as buttons. so wen u press them then computer thinks ur pressing a button all way down instead of rotating an axis. you have to somehow find a way to tell computer that you have pedals and that the axis have to be callibrated in control panel. i have no idea how this is done though.
Feb 06, 2010 | Guillemot Thrustmaster Ferrari Force...
I am a transcriptionist who is remotely accessing a work computer
I looked a the Infinity IN-USB-1 foot pedal, thanks. I would go out and buy a second foot pedal for home then you can remote your work pc by using the foot pedal from home. Make sure you install the drivers for the foot pedal at your home pc. If this doesnt work, you can always take the pedal back to the store. I figure that If you took away your mouse from your home pc, you could not move your mouse on the work pc. It maybe the same with the pedal. Let me know if it works.
WBTech
Jan 19, 2010 | Computers & Internet
Toys Logo
170 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
