You might try to take the cmos battery out of the motherboard for couple hours if that dont work which it sound like you might have fried your bios chip, then you might have to have another bios chip installed
Well they all differ but what still remains the same on laptops of lots of little screws. what was the model number to your laptop and i will try and send you a disassembly guide
Toshiba Satellite L455D. Thanks so much for the help.
I COULDNT FIND EXACT MODEL BUT THESE MODELS ARE CLOSE ENOUGH AND ALMOST PRETTY MUCH STANDARD AS FAR AS TAKING APART.http://www.irisvista.com/tech/laptops/To...http://www.irisvista.com/tech/laptops/To...
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
then you should be able to load xp
hope it helps
How do I access the motherboard to remove the battery?
