Question about Sony DCR-SR47 Camcorder
The batt will not work the camera. It only works with powercord pluged in. Even will full batt.
  • 3 Answers
Might be, bad conection inside dc hole on camera, when you unplug the dc plug from camera a metal contact inside that hole might not be making a good contact.
Posted on May 25, 2011
On screen saying re attach power source, no function.
Does it have the battery in it? If so, plug the powercord in to charge. If not, put the battery in it. If it still doesn't work with battery and power cord: I would think either the battery or the powercord is not working properly. Most likely the powercord.
May 02, 2011 | Sony Handycam DCR-TRV280 Digital Camcorder
My camera lense won't close even when i turn it off & on. i have tried to turn it off and on the screen only goes on & immediately turns off. the green light in the corner flashes so i know that...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 23, 2009 | Kodak EasyShare V1003 Digital Camera
The lens wont go in and when i turn on the camera, it dies within seconds. how do i get it to work again?
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Nov 11, 2009 | Kodak EasyShare M1033 Digital Camera
Red light blinking then turns off new batteries
In order to clearly determine the fault the model of your KODAK camera is needed
However hope this will help:
If your cam use AA batt.:
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
If your cam use manufactors rechargeble batt.:
Remove the battery
Contact KODAK:
Nov 01, 2009 | Kodak EasyShare C360 Digital Camera
Ready light keeps flashing red. Replaced with a new battery from Kodak today but did not fix problem. No picture in LCD.
If the correct recommended batt supplied from KODAK didn't solve the problem Then a repair is recommended.
Info on batt:
Remove the battery
Contact KODAK:
Oct 30, 2009 | Kodak EasyShare LS443 Digital Camera
Power light blinks, lens door won't close
may be it got stuck try to move it by ur finger cuz mine one opens half some times so move it by finger ..... try it it might work for u ....
Aug 14, 2009 | Konica Minolta DiMAGE X1 Digital Camera
At Dell screen the d600 shuts off
GO INTO THE BIOS AND RESET TO DEFAULT SET UP SETTING.RICHARDM69
Dec 15, 2008 | Dell Latitude D600 Notebook
Battery pack
I don't know if this will work but it worked for my PowerShot A300.
Take a pencil eraser and clean the battery connections inside your camera. Just be sure not to let any eraser flakes inside the camera.
The Canon rep indicated it would work for the A300 ... Not sure why it wouldn't work with yours as well.
Good luck.
Aug 29, 2008 | Canon PowerShot SD870 IS Digital Camera
Kodak m863 camera will not turn on
Remove the battery
Contact KODAK:
Aug 19, 2008 | Cameras
My sony DSC-W55 will not switch on, even though the battery has a full charge.
for this you can try taking out the batt ,wait for 1 minute ,put it back , turn the power "on" and see.
it should work.
Aug 13, 2008 | Cameras
Sony DCR-SR47 Camcorder Logo
47 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
