Question about Vtech T2453 Cordless Phone
No dialtone ... rings but cannot be answered.
The phone rings but cannot be answered. No dialtone when you turn the phone on. The phone line is operational when checked with another phone.
My phone not taking voice mail
Posted on Jan 26, 2009
SOURCE:
My uniden cordless phone won't allow a dialtone and when you ring the phone with a mobile phone, you can't answer. The 2nd phone in the bedroom also has no dial tone.
This could be external line trouble. If a technician confirms there is dial tone at the interface, your equipment or wiring is at fault.
Mar 15, 2018 | Uniden Lands Phones
Plantronics ct12 phone no dial tone
It is possible that the replacement battery is no good or was installed incorrectly.
Dec 29, 2013 | Plantronics CT 12 Cordless Phone (CT12)
Dect6.0 cs6114
Yeah is the volume is all the way up and you still cant hear anything the only options left are to plug in another phone that you know works to make sure its not the phone line or socket at fault and then take the phone back for a replacement.
Dec 29, 2011 | Televison & Video
Cant get dialtone or answer the phone when it rings.... it says "searching" all the time......
its not getting a signal from the base.check to make sure the antenna is tight.
Mar 25, 2011 | Uniden DECT 6.0 Cordless Phone ID
We have a Merlin System, the phones are MLX-10D, we have to dial outgoing calls 3-4 times before the call will go through. Now we're receiving complaints that incoming calls are just ringing and we don't...
Sounds like one (or more) of your lines are out in your telephone system. Each time you press a 9 for a line the system simulates a dialtone to see what your dialing next so it can check it against the automatic route selection table. After it checks, it pulls a line out of a pool group to complete the call. At this point its grabbing a line that is not working on the system.The best way to figure out which ones arent working is to check the lines on the main console by pressing each line button and seeing if it produces dialtone. More than likely(but not allways) its going to be a line problem from your dialtone provider.
Sep 21, 2010 | Lucent Merlin Legend MLX-10D Phone
I cannot answer the phone. I cannot make a call.
Thanks guys! All I did was unplug the main phone and plug it back in. All 4 of the handsets now work!
Jan 23, 2010 | Panasonic KX-TGA101S Cordless Handset
Can i forward my home phone to cell phone
yes, providing you have that service through your provider. It's typically done by accessing your line and dialing *72 if the service is active you'll recieve a stuttered dialtone. then dial your cell phone number. once you've answered your cell the transfer is established. To deactivate call forwarding, from your home phone dial *73. you should recieve a stuttered dialtone confirming that the foward is off.
Dec 22, 2009 | Lands Phones
The fax will not answer even though I have it set to answer after 2 rings. It is on a dedicated line. Help!
There is a check box that must be checked in order to enable automatic answering.
Also, you have to have the phone line plugged into the Officejet machine
Oct 28, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
No dialtone on handsets, 3 beeps sound
Deregistered 4 handsets, on suggestion from FixYa, by pressing hangup & # sign.
Then reregistered to base.
May 08, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Mitel 5220 IP phone won't ring when the main line is ringing
WOW
Ok this post is OLD, but for anyone else having this issue, this is the solution...
There is a programming feature that states: DELAYED RING on certain lines, meaning you can physically see a call coming in to the system (via line flashing), but it will not ring at your desk till something like the 4th ring(hence the name DELAYED ring).
If your set does not ring, and you pick up the heandset, the phone system doesn't know if you want to answer the call -or- you just want to make an outgoing call...
Therefore the Mitel system picks up internal dialtone and waits for you to make the initial reaction (hit 9 for a line out or hit a line that is flashing on the set).
Too change this option, a Mitel Tech is required...
Jan 23, 2007 | Mitel 5220 IP Phone
Vtech T2453 Cordless Phone Logo
332 people viewed this question
Top Vtech Lands Phones Experts
Marvin
Marvin
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
