Question about True GDM-23 Refrigerator
My True refrigerator turns on, the fans work, but will not blow cold air. There is a clicking sound but it does not seem to make it blow refrigerated air.
    Director Badge:
    Uploaded 100 video answers.
  • True Master
  • 489 Answers
Change Start Relay For Compressor, if it will not help, most likely you will need compressor itself
Posted on Jun 10, 2015
  • Robert Moller
    Robert Moller Jun 14, 2015
    Only a "Trained Certified" Technician can change a Compressor
  • Marat Brikov Jun 14, 2015
    sure, thats true. need EPA license to do change out!
    Guru:
  • 1,524 Answers
Change compressor starting components
Posted on May 25, 2011
  • Robert Moller
    Unless you're a "Trained, Certified Technican"you cannot change your Compressor
Why is it that my refrigerator does not get cold and my freezer is not making ice
SOUNDS LIKE YOU EVAPORATOR FAN HAS EITHER SEIZED----REPLACE; OR WAS BANGING ON ICE AND FINALLY STOPPED ---DEFROST
May 15, 2014 | Refrigerators
My freezer is working, but there is no cold air blowing into the refrigerator. It seems like in could be a problem with the refrigerator thermostat or defrost-timer. Do you have any suggestions?
I had the exact same problem with my Frigidare. The fan motor went out and cold air could not be forced into the refrigerator compartment. The fan is located in the back of the freezer compartment. Not too tough of a fix.
Sep 14, 2011 | Frigidaire FRT21H8 Top Freezer...
I have a model GDM-26. It's was blowing really cold, 30 degrees, then warm, 50 degrees, alternating between the two. Now it's not blowing cold at all and the coils on top do not get cool/cold. Both...
The way you described the problem, I would be looking for a refrigerant leak... I think that it was low on charge and now it is so low that it will not cool at all...
Have a tech. find/fix the leak and recharge the unit...
heatman101
Jun 29, 2011 | True GDM-26 Refrigerator
Not getting cold enough to freeze, How to check Freon
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 05, 2010 | Kenmore 53082 / 53084 Side by Side...
My freezer is not working properly with clicking sound.
The clicking sound is probably the compressor relay trying to start the compressor. When the lights dim, the compressor is trying to start and hence, pulling power from the rest of the unit. If the compressor has a start capacitor, that could possibly be the problem. If not, the compressor itself should be replaced.
Mar 26, 2010 | Maytag MSD2454G Side by Side Refrigerator
After cleaning coils my refrigerator is still blowing warm air yet the freezer is cold what can I do myself to make the refrigerator cold?
There is a small fan which moves the cold air from the freezer to the refrigerator part. Make sure that this fan is working. If it is not turning, the cold air will not reach the refrigerator.
These fans are easily replaceable; however, you probably will have to remove the interior panels from the refrigerator to gain access.
Oct 09, 2009 | Amana ABB1927DE Bottom Freezer...
When i turn ac on air blows hot. the fan is
sounds to me u need to have it recharrged
Oct 03, 2009 | 2004 Infiniti G35 Sport Coupe
Amana ARB2214CB refrigerator fan not working?
the fan is locted in the freezer and it blows up to the ref and it sounds like the fan quit working and needs replace to check it the be for sure take the back panel off and with the ref running test the leads to the motor and make sure you have 110 volts if you do it is a bad motor
Jul 07, 2009 | Amana ARB1905C Bottom Freezer Refrigerator
Hi, We have a whirlpool eb22dkxfw01 bottom-freezer refrigerator. The freezer part is working OK, compressor is running, but the refrigerator part is getting rather close to room temperature, and...
need to check for ice build up in air vent. if not make sure you hear your evap fan blowing in the freezer section. this blows your cold air into the fresh food side. do you have ice build up on rear wall of freezer section?
Jun 21, 2009 | Refrigerators
Bottom of freezer/fridge only getting cold.
Thre is a fan inside the freezer which circulates the cold air around both the fridge and the freezer compartments.
You should be able to feel cold air blowing around the inside, particularly at the top of the freezer.
If the defrost thermostat fails open, the internal fan (depending on freezer) will stop and this can be the cause of the freezer being warm at the top and no ice.
You say the bottom of the freezer is blowing cold, but are you sure its blowing, as it can feel like a cold blow. Of course the fan could have failed or may be the defrost heater itself.
Have a look at this site for some useful trouble shooting
And a good site for troubleshooting and general info
Refrigeration Help Section, Fridges, refrigerators, not cold enough, frost free problems and how to test, noisy fan motors, clicking on and off compressors, door gaskets
Nige
Sep 26, 2008 | Amana 22.6 cu. ft. Side-By-Side...
True GDM-23 Refrigerator Logo
427 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
