Question about HP Compaq d530 SFF PC Desktop
920-fan command 2 pin connector from power supply not connected. I am getting this error. please let me know what to do !!! Its HP d530 SFF
5 Suggested Answers
SOURCE: 920-fan command 2 pin connector from power supply
Well thats not good, however if you can identify the Positive, usually RED, and Negative, usually BLACK. on the Fan, You can actually carefully insert the bared wire into a spare drive power connector, fans are all 12 V. You can use the YELLOW.. +12V & the alongside BLACK - 0V. This will power your fan. BE CAREFUL doing this. Once inserted use a piece of tape to secure the wires and fold them back against the Plug and secure. You may be able to buy a converter that plugs into that power connector & the fan?
Posted on Feb 22, 2010
SOURCE: need a d520 sff motherboard layout
mine was do- the same. pin 2 is next to the dim slots its white. i con-ed a 12 fan to it. the fan dont spin i dont get the mess any more i am look for the book to get the jumper set- as well. so i can take the fan off. small 12 v fan
Posted on Feb 04, 2009
  • 69 Answers
SOURCE: 920-fan command 2 pin connector from power supply not connected
then connect the fan to a 2-pin connecter if you cant do it take it to a computer place to do it for you
Posted on Sep 24, 2009
Kuwagata
  • 181 Answers
SOURCE: Hp D 530 - DK907T
Maybe you put the wrong jumper of the power jumper for the front panel.
Explanation:
You can see the switch to turn on the PC right, then make sure that switch correctly installed on the right jumper on the board. Follow the cable to attach to the mother board.
Posted on Aug 22, 2011
HP d530 920 & 162 Error And Parity Check 2 Hold On
Try installing the original RAM and see if the computer boots up.
If it does then the other RAM modules maybe incompatible or faulty.
Try using additional or new of the same make and speed as your original RAM.
Apr 16, 2013 | HP Compaq d530 SFF PC Desktop
Hp D 530 - DK907T 902-FAN COMMAND 2 PIN CONNECTOR FROM POWER SUPPLY NOT CONNECTED NB i've changed the chassis it was SFF ans i 've changed in Tower with a standard power supply
Explanation:
Aug 22, 2011 | HP Compaq Business Desktop d330 Slim Tower
Hp disktop erreur 920-fan command 2 pin connector
The CPU Fan is not working. Contact Compaq or go on Ebay and see if you can find a replacement fan. If you continue using your PC without the CPU fan operating, you will burn out the CPU. I hope this helps. Good luck and have a pleasent day.
Apr 30, 2011 | HP Compaq d530 SFF PC Desktop
920-fan command 2 pin connector from power supply not connected I have replace my power supply..but my new power supply didnt have the 2 pin..
Feb 22, 2010 | HP Compaq d530 SFF PC Desktop
Sep 22, 2009 | HP Compaq Business Desktop d330 Slim Tower
Hi, my mother board is HP d530 SFF ...i installed the correct audio drivers and its shows no problem in software ...but still i m not getting sound from my back pannel.can any one help me how to connect...
There is "Front Panel Audio" connector on mb. If you don't use orginal connector from orginal case you must short pins on mb.
2 o o o x o 10
1 o o o o o 9
If you short pins 5&6 and 9&10 you should have sound at rear audio panel of mb.
I have run into this on a different compaq model in a different case. It maywork for you but must find small jumpers if they are not supplied. No guarantee but worked on my compaq d530
Aug 05, 2009 | HP D530 PC Desktop
920-fan command 2 pin connector not connected
It is a 2 lead wire (red/white and black) that connect right next to the memory slot. you have to connect the red/white wire to the 5v+ side of the 4 pin peripheral and the black lead to the com (black) on the same 4 pin peripheral. i can't really think of any way better to explain at the moment. but any questions. email @ forwardyourletter@gmail.com
Apr 07, 2009 | HP Compaq Business Desktop d330 Slim Tower
HP D530 SFF CHASIS FAN NOT DETECTED
tell me the wright way to remove 512 chassis fan error i am very depressed on this
Mar 17, 2009 | HP Compaq d530 SFF PC Desktop
Need a d520 sff motherboard layout
Jan 04, 2009 | HP Compaq d530 SFF PC Desktop
HP D530 SFF desktop
it is depend up on the power supply connector and it will give the output according to the smps you can do one thing try with installing other fan and see is it in perfect rotation. bye
Oct 09, 2007 | HP Compaq Business d530 Ultra-Slim PC...
HP Compaq d530 SFF PC Desktop Logo
1,303 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
