Question about GE AJCQ08ACB Air Conditioner
I cleaned my window unit air conditioner over the weekend. I used a hose and sprayed it to get all dirt out. When I was done I turned the air condtioner on and it ran for about 30 seconds and shut off. It will not turn back on. HELP!!! GE Window Unit Model and Serian Number is 52EX2752/502TAKK04021
  • Robert Moller
    Robert Moller May 25, 2011
    did you cover the controls ? Try using a hair dryer
CompuGuy44
  • 432 Answers
SOURCE: Broken air conditioner?
Try another wall outlet. You may need an extenion cord.
Posted on Jun 25, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Air Conditioner unit won't switch on outdoors
can you give us some model numbers and a make? Get both the inside and outdoor unit numbers please. Thanks.
Posted on Oct 10, 2007
koolbreezes
  • 540 Answers
SOURCE: window unit air conditioner
Sounds like a full cleanning job or the drain line is plugging up. First , check for A 10* lean toward the back of the unit for proper drainnage, 2- check for good air flow thru the front coils--(dirty filter --dirty coil and last ,add some clorox bleach all across the front coil while off>)
Posted on Sep 02, 2008
  • 227 Answers
SOURCE: GE AEW10AJS1 Window Unit A/C Shuts Off and Trips Reset.
The condenser coils may be dirty. You can wash them out with a hose or compressed air.
Posted on Jul 20, 2009
SOURCE: E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Posted on Jul 27, 2010
Whats with norpole 12000 btu window air conditioners w/FO CODE,now all i have is a expensive fan!
they eventually do need serviced by a good repairman .freon leaks out .control boards fail etc .
Jul 18, 2016 | Filter Heating & Cooling
Tip
Window Air Conditioners - Clean them every year
The Window Air Conditioner that you bought last year is not performing like it did when it was new. What can you do to get the slightly cool to cold again? Cleaning the air conditioner may be the answer. I will go over the best ways that I have found to do that.
First off let me tell you that you should never try to clean your window air conditioner while it is still in the window. If it is a large unit, then pull the chassis out of the tin box and take it outside or someplace where you can put the water to it with out hurting anything. If it is a small unit, then the whole thing will need to be removed and carried to a location where you can wash it out.
Now that you have the window air conditioner out of the window, you can get to work. On small units you may need to remove some screws to get the cover off. You need to be able to get to the coil with all those fins both inside and out. The outside coil is the most important. The inside coil usually can only be accessed from the one side. Remove the filter and was it or replace it. This is a very critical part of the unit. It will help to keep the indoor coil clean. If it is very dirty it will also hinder the air flow through it and reduce the capacity of the unit.
Get a good degreaser or coil cleaner. Most any good quality household detergent will work also. A garden sprayer will work very well for both spraying on the cleaner and also to wash the coils after they are cleaned. I usually stay away from using a garden hose. The pressure from many houses is strong enough the bend the fragile fins in of the coils. If this happens you will need to straighten them. This can become very time consuming. Wet the coils with plain water first. The spray on the coil cleaner and let it soak for awhile. Then wash off the dirt by spray water from both sides. try to wash as much of the dirt as possible from the coils. Air is constantly going through the coils when the unit is running which deposits and traps dirt in the coils. It can take some time to get the dirt to release and wash away. Your patience with cleaning will be worth the time and effort. A soft brush can also be used, but take care not to bend the fins.
After the coils are cleaned, check the motor for oil holes. These are usually on the top at each end of the motor. The holes have little passages down to the motor bearings. Add just a couple of drops of oil to each hole. The oil will work flow down to the bearings to lubricate them and prolong the life of your motor. Oil for small motors can be found in many hardware stores. If you can find the oil that has a long pull out spout on the bottle, that works best.
Now you just need to put everything back together the way it came apart. Sometimes that is easier said than done. Hopefully you have good notes and a good memory! Replace the filter with the wash one or a new one. Place the unit or the unit chassis back in the window and you are goods to go! Give the unit a few hours to dry before plugging it in. Water and electricity do not get along well. You can speed the drying process up with a hair dryer if you are in a hurry.
Now you have a clean window air conditioner that should perform just like it did the day you got in out of the box. Regular cleanings and oiling will help your window air conditioner to give you many trouble free years of service. This cleaning should be done at least once per year. In very warm or dirty environments you will find that it may be helpful to do this more often. You will also find that the more times you do this the easier it gets. Have fun with this and good luck! Work should always be fun!
on Dec 12, 2009 | Heating & Cooling
Ac unit in the house keeps freezing up, not a window unit, central unit. The entire part inside keep freezing up, making knocking noise, and not blowing cool air. The out side part is fine, no problems...
There is a coil out side in the unit , it needs cleaning, there is an acid that is used to clean it. Its an easy job, pull the top open and use a stick or something to keep it up so you can spray the coil, with the unit off let soak 10 mins then spray wash with water hose. done
Sep 29, 2013 | Heating & Cooling
My frigidaire air conditioners spit dirt all over the floor. My window unit and my through the wall unit in a sleeve both do the same thing. I called Frigidaire two years ago and they told me there were no...
1. Turn units off
2. Remove Filter
3. Spray a foaming cleaner on the coils (Dow Bathroom Cleaner)
4. Use a spray bottle filled with plain water
5. Replace Filter and Grill
May 25, 2011 | Frigidaire FAC124 wall/Window Air...
The air that it throws is not that cold, i wanted to know which part do i have to change?
the best cure is to take the unit outside use your garden hose to clean the coils ..remove the front cover/ cover switches with tape ..spray coils on both sides real good to remove dirt ..let the unit dry good ..clean filter and it should work like new again..let me know ..good luck/joe/
Aug 26, 2010 | Quasar HQ2051TH Air Conditioner
What maintance do goldstar conditions need? My cooler is not working as well and I cleaned the front filter. I'm not sure what window conditioner I have.
these units need to be cleaned every few years. so take it outside, get your garden hose; and clean the coils on both sides. front an back coils need to be clean. a coil cleaner should be used but good water presure should do fine. try not to get switches to wet. or cover them first. spray coils clean. let dry in the sun. tilt unit to get most water out then blow dry with a fan or just wait till its dry it will work like new after your done.good luck
Aug 23, 2010 | LG Goldstar GWHD5000 wall/window Air...
A/c unit not cooling house weatherking model #12AJA3601
I use a spray nozzel on my water hose to clean out the oustide coil. You can go to a local Hvac parts store and get a cleaning gun and foam to clean the coil. I just use my water hose and sprayer with arm and hammer baking soda.
Jun 03, 2010 | Weather King 12AJA4201AH Air Conditioner
The unit simply goes off (one of the leds would blink) then you have to restart it again and again several times per day
You can try to clean the filter and also the outdoor side condenser fins which may have dust and dirt. The indoor filter simply slides out of the front panel. The outdoor side can be sprayed (while unit is off) with a hose.
Nov 06, 2009 | LG Electronic Window Air Conditioner
Ac not working like it used to
Storing the Unit is important -it should be up-right NOT on it side, this will cause the iol to clog the lines, NOT COOLING properly could be it need a good cleaning ( with a cleaning agent and a hose ) . to do this you have to remove the case or from the sleeve, BE CAREFUL NOT TO WATER "ELECTRICAL PARTS, clean drain line ( condensation "water" will cool off the ouside coil ( candenser) the inside coil can frost up if dirty or filter is clogged.
take the Unit out and clean well. you can purchase a spray that will remove all the grease and dirt - be careful not to bend tubing. use a light spray and let it dry in the sun. When putin Unit back in the window or wall WATER MAYBE SPRAYED OUT -DON'T STAND IN FRONT OF THE UNIT - IF you can't do this, call a serice company - this job can be done in a back yard.
EM
Aug 19, 2008 | Kenmore 72055 Air Conditioner
Air conditioner cleaning procedure
If its a window air conditioner, take it our of the window, then take it outside unplugged. Spray the coils with a garden hose at low water pressure. You don't want too much water pressure cause it can bend the fins. Also try not to get the electrical components wet. Spray the water strait into the coils at a 90 degree angles to push the dirt free on the inside of the condensor( outside coil).
Jan 24, 2008 | Heating & Cooling
GE AJCQ08ACB Air Conditioner Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
