Question about HP DesignJet Z2100 InkJet Photo Printer
We use hp T770 HDD, error massage 79.03 when loading, after show preparing print system massage in a few minutes. ask for restart but after restarted the problem persist. please kindly help us if there any sollution. thank you so
  • HP Master
  • 1,915 Answers
79 errors are often linked to firmware. Unplug the printer from power as well as any network or USB cables you may have plugged in. If the printer will restart without an interface cable connected then it is likely a bad print job. Clear all jobs from the print queues and then plug in the interface cable. If printer continues to stay at ready, download the current firmware and install it. This should resolve the problem.
Posted on May 25, 2011
When i switch on my hp probook 4420s it cannot load the operating system but keeps restarting
Try going to bios by pressing del while starting. Check the boot sequence if your HDD is on the list and selected as primary. You can also try HP recovery by pressing F11 key as soon as you power on the laptop.
Apr 19, 2014 | HEWLETT-PACKARD HP ProBook 4420s Notebook...
79:03 error code t770
my ploter problrm t610 printer ready but carriage left side stucking and error showing on display 79:04 than replaced 3 no print head but not tready ploter why? i have replaced tralling cable .timing belt; formatter card , encoder strip , carriage block with carriage pcb but same problem .pls shuotout my issu.
Feb 11, 2012 | HP DESIGNJET T770 Printer
I have compaq presario CQ35.i installed vista. After few months getting some errors on Blue screen. And computer restart, getting same error many times.now when i m installing or upgrading OS, but its not...
old Cq35 (the numbers at the end are missing)
CQ35-nnnnnn what?
what OS??? VISTA sure.
What DISK no disc presented by you , 1000s it can be.
what VISTA DISK.
http://www.pcdied.com/HP-OS-GET.html
Jul 17, 2017 | Compaq Presario 1692 Notebook
My pc wont boot up normally, it has a blue screen show up but then it goes away before i can read it
The blue screen of death BSOD is set to auto-restart after an error you can change the registry to prevent this not sure if you can do this in safe mode but its worth a try you will at least be able to see the error.
Its a good idea to use MemTest on a boot CD to check your RAM for errors first then restore from an old image.
Feb 07, 2010 | Acer Aspire One PC Notebook
My hp officejet 4315 all-in-one printer is showing a cartridge error message I have changed both cartridges and still reads the same what is going on with my printer.?
Please reset your Printer and restart again . The go printer properties and start the printer diagnosis & start test print. If that function going well then your printer ready for further printing with out showing that massage.
Thanks.
Feb 02, 2010 | HP OfficeJet 4315 All-In-One InkJet...
My dell inspiron 1525 has a black screen with a white cursor showing
First, I want to know if you sees the Dell logo after turning on the laptop? If yes then this is no boot issue.
1. Immediately run the PSA. Make sure laptop is off. Press and hold down the Fn key, while holding down Fn key press the power button at the same time just once. Once the Dell screen loaded you can now let go of the Fn key. Check if the PSA will run short test for the LCD, RAM and HDD. When full color displays on the screen just press Y. PSA will continue. Just take note of any error code will appear on the screen such as 0141, 0142 and 0146 these are HDD failure errors which means HDD needs replacement. If the test says no errors found then proceed to step 2;
2. Try restarting the laptop once you see dell logo then keep tapping F8. Select last known good configuration. Press enter key. Just wait and check if laptop will load Windows. If not then, restart laptop keep tapping F8 try to select safe mode check if it will load Windows. If not then prepare the Windows OS disc the one came with your laptop.
3. While laptop is on insert the Windows OS disc. Restart the computer. On the Dell screen keep tapping on F12 to show boot menu. In the boot menu select CD/DVD ROM Drive. Press enter then keep tapping on space bar until it will say Windows loading files, please wait.
4. In the User Interface it will show you some options to select. Once the Install screen comes up look on the lower part select Repair Your Computer. If will ask you to do Startup Repair, please do start up repair. If fails try the System Restore. If fails then step 5;
5. If you have important files in your HDD then back up your files first. After backing up of files you can now install the Windows OS. Here is the process in installing the Windows OS. Insert the Windows OS disc, restart the laptop, keep tapping F12 on Dell screen, on boot menu select CD/DVD ROM Drive.Install the Windows OS. Just complete the installation.After the installation install the laptop drivers.
Dec 10, 2009 | Dell Inspiron 1525 Notebook
No print catridge error showing on display
plz remove the catridge and reinstall the catridge properly then uninstall the printer driver and restart the system then after restarting the system then reinstall the printer driver and restart the system again then after restarting the system check
Jun 01, 2009 | HP LaserJet 3050 All-In-One Printer
Hp 3325 printer printing test page and not printing other pages
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Apr 06, 2009 | HP DeskJet 3325 InkJet Printer
HP DesignJet Z2100 InkJet Photo Printer Logo
664 people viewed this question
Seeker5211
Seeker5211
