Question about Nuova Simonelli Yacht Club Espresso Machine
Hi How do you clean out the Nouvo Seminelli Yacht Club coffee machine. Someone tried to use the machine whilst off and it sucked in milk. Is there a way to fix this
    President:
  • 1,618 Answers
Easiest way is to descale the boiler and make sure the steam valves get flushed also.
Posted on May 25, 2011
I have a coffee to cup Neff CV7760N coffee machine (the type that sucks milk through a frother, rather then a wand). After 4 years excellent service the frother is now quite erratic - usually froths one...
Clean the frother by using detrergent or coffee clean tab.
just half liter water take add 1 coffee clean tab in one pot.insert the milk suck shner pipe in that pot .start the machine and press for milk sucking.
Jan 28, 2015 | Coffee Makers & Espresso Machines
My Nespresso machine does not suck up milk from the container and only hot water comes out, plus the small cup button flashes orange, is there any way to fix that?
Espresso machines sometimes come with a milk steamer wand. If your wand is producing water instead of steam, your machine is not heating properly.
But no machine draws milk into itself. If would be near impossible to clean.
Do you still have the Nespresso instructions ?
Jan 17, 2015 | Nespresso Coffee Makers & Espresso...
Milk does not come out of the milk spout
Do you have any errors is the spout clean try runing some hot water to open block channel see inside for seloniod
Jun 26, 2014 | DeLonghi Magnifica Coffee Makers &...
Hi, I am having trouble getting the milk to froth without bubbling. Ihave cleaned it really well and hoping you have the solution. Cheers Denis Stevenson
sounds like the milk jug has not been inserted correctly
give it a wobble whilst using
check the o ring on machine wher the jug plugs in as there could be dried milk around it letting air into the system or faulty o ring
Jun 05, 2011 | DeLonghi Prima Donna Avante ESAM6700...
Our PrimaDonna coffee machine doesnt appear to be takeing in any milk from the jug to make latte's or cappuciono's, is there any way of sorting this out ?
Most common cause of this problem is a blockage in the milk jug. First thing you should try is soaking the complete jug top in a quality milk line cleaner (available from specialist coffee machine retailers) for at least an hour and then rinse thoroughly. Then try running a fresh cleaning solution through the jug instaed of milk. Good luck and post again if this doesnt work.
Nov 25, 2010 | DeLonghi Prima Donna Avante ESAM6700...
Steam smells odd and affects milk taste.
The boiler is contaminated with milk and needs to be descaled and cleaned.
Jul 31, 2010 | Astoria Argenta SAE-2 Espresso Machine
Milk frothing problem on a Magnifica 3500
Had the same prolem replaced the coupling where the jug clips in. Item 111 - part number 5532123200 coupling. If your not technically experienced then you may need to take it to a service agent. Had to fairly well dismantle machine to complete repair.
Apr 07, 2010 | DeLonghi EAM3500 Espresso Machine/Coffee...
Cappuccinatore doesn't ****
Did you clean it, gets clogged with hardened milk fat quite easily. Dismantle and wash, run hot tap water through or blow into flexible hose if you're still not getting any flow, then reassemble.
Lifting the small black plug (air intake) and raising the reservoir of milk can help to get the flow going.
Oct 29, 2008 | Gaggia Titanium Espresso Machine
Nuova Simonelli Yacht Club Espresso Machine Logo
111 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
