Question about LG Dishwashers
LG modèele LDF78105T error code LE - LG Dishwashers
  • Anonymous Feb 17, 2009
    i get le code
  • 3,230 Answers
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
(Just copy and past the above link in your web browser)
Good Luck!!
Posted on Mar 27, 2010
ELE
Do you mean LE? Because a LE code means Overload in Motor.
May 11, 2012 | LG DLE2512W Electric Dryer
Codes deblocage de nokia 1661-2b mon nokia ne reconnait pas les puces francophone on m'as dit qu'il me faut un code pour ca aidez moi slvp
Salut il ya plusieurs fa?ons de d?bloquer le
mobiles, nous pouvons utiliser le logiciel, le c?ble, les codes etc ... parmi les
les codes sont les meilleurs. Aujourd'hui, il existe de nombreux sites en ligne qui fournissent trouv?s
les codes pour d?bloquer le mobile.you pouvez obtenir les codes d'ici l? ils demandent classicunlocking
les d?tails suivants sont mod?le mobile, le pays et le r?seau qui verrouille votre mobile, l'IMEI
num?ro du mobile. Enfin ils vont envoyer les codes pour d?bloquer le mobile.
Sep 26, 2011 | Cell Phones
J'ai pas le cd pour l'instalation
Sur cette page:
http://www.nvidia.fr/Download/index.aspx?lang=fr
Choisir le mod?le et le syst?me d'exploitation et apres vous pouvez t?l?charger le pilote pour votre carte.
Jul 01, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
Code pour debloquer mobil telephone samsung s 5230
Salut, vous pouvez utiliser des codes pour d?bloquer votre mobile. il ya beaucoup de sites en ligne aujourd'hui, de fournir les codes de d?verrouillage. J'ai obtenu les codes de d?verrouillage d'ici
simpleunlocking
pour d?bloquer mon portable.
ici, ils demandent les informations suivantes sur votre mobile
mod?le mobile
pays d'o? vous avez apport? le mobile
fournisseur qui verrouille votre mobile
num?ro IMEI de votre mobile
puis finalement ils vont vous fournir les codes de d?verrouillage d?s que possible.
Jun 26, 2011 | Samsung SGH-S5230 Cell Phone
On me demande d'entré le
Vous pouvez essayer le code de restriction pour le téléphone Nokia 5220 Express Music Modèle mobile à ce site http://www.unlocking4u.com/nokia-5220-xpressmusic/rs6wp9/
Jan 19, 2011 | Nokia 5220 XpressMusic Cellular Phone
F35 error
D?FAILLANCE DU CONTACTEUR MANOM?TRIQUE
If after 30 seconds the control does not detect water
entering machine, the valves will be turned off and the
error code will be displayed. OR If the control has
turned the water valves on and after 8 minutes the flow
sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip,
the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Si apr?s 30 secondes le syst?me de commande n’a pas d?tect? l’entr?e d’eau
dans la machine, le syst?me ferme les ?lectrovannes et commande l’affichage du
code d’erreur. OU Si le syst?me a command? l’ouverture des ?lectrovannes
d’entr?e d’eau et si apr?s 8 minutes le capteur de d?bit a d?tect? le passage de
10,5 gallons d’eau, tandis qu’aucune manoeuvre du manocontacteur n’a ?t?
d?tect?e, le syst?me commande la fermeture des ?lectrovannes et l’affichage du
code d’erreur clignote.
Appuyer deux fois sur la touche PAUSE/CANCEL pour commander l’effacement de
l’affichage.
Possible Causes / Procedure
1. Unplug washer or disconnect power.
2. Check to verify that the pressure switch is
operational.
3. Replace pressure switch.
This is for an F32...there is no F35 fault code on your model according to the service manual....
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Notice d'utilisation
Bonjour KRACOT, s'il vous plaît excuser mon français. Je me rappelle un peu le français d'il ya longtemps ..Vous pouvez télécharger le Manuel de l'utilisateur en anglais sur le site Kitchenaid à: : http://www.kitchenaid.com/flash.cmd?/#/page/home.
Cliquez sur Customer Care>Locate Manuals& Guides> et entrer le numéro de modèle de 6 caractères, dans votre cas K45SSW et sélectionnez le fichier correspondant à votre modèle qui apparaît sous Owners Manual (2 K45SSWH-0.pdf (2730.37 KB) et à sauver cette fichier sur votre PC.
Mai aussi vous voulez télécharger le fichier sous Parts List Manual (1) K45SSWH0.pdf (341.41 Ko). (Cocher Certainement pour voir ce qu'il répond à votre table de mixage).
La liste de pièces manuel fournit une vue éclatée pour le démontage et le remontage de votre console, avec tous les noms et les numéros de partie, au cas où vous souhaitez commander des pièces de rechange pour fixer vous-même la table de mixage.
Bonne chance. J'espère que ce sera utile afin que vous puissiez utiliser votre mixeur KA. Howard, Burke, VA, USA
Si cette solution a été utile, s'il vous plaît notez le, merci! hslincoln
Jan 19, 2010 | KitchenAid K45SS Classic Stand Mixer
Not accepting disc message disc error c13
C13 is usually a motor error, but is dependent upon the model. Can you please post the model number and I'll look it up for you?
Thanks,
Dan
Jul 05, 2009 | Sony Audio Players & Recorders
?AINTENANCE
Salut, normalement la maintenance veut dire ceci : remplacer le Fuser, et les kits de petits rouleaux pour les bacs (Manual feeder et le bac 2, 3 etc) et le "registration roller". Toutes les pièces de maintenance sont faciles à changer normalement. Il faut contacter le fabriquant (ou votre vendeur de pièces informatiques) et commander le kit de maintenance pour le modèle de votre imprimante. Si ils sont gentils, ils vont inclure la marche à suivre dans la boîte pour comment faire chacune des opérations. Bonne chance!
Jun 09, 2009 | IBM Infoprint 1422 Laser Printer
Dishwashers Logo
139 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
