Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
I HAVE A DEERE LT166 48'' DECK THAT THROWS BELTS CONSTANTLY. I HAVE ADJUSTED EVERY THING I CAN NO MATTER WHAT I TRY I TRASH BELTS 3 OR 4 TIMES A YEAR. PLEASE SUGGEST A SOLUTION
5 Suggested Answers
agent91
  • 2100 Answers
SOURCE: Electric Clutch want engage the mower deck on my l120 john deere
They wear out. How old is the mower? Mine just gave out this week in the peak of hay season. (my grass) The wire can be unhooked from the PTO clutch and a 12 volt jumper can test it, if it jumps, it is good, if not, it is shorted out, they are expensive, I found 3 of them all the wrong size for mine. Try to find the same one. Ebay has a couple on there right now. Check it out.
Posted on Jun 10, 2010
  • 6 Answers
SOURCE: How to change the Belt on a John Deere L130 with
Try the John Deere parts website https://jdparts.deere.com or give sullivans a call they are a john deere dealer and are garden machinery experts they will be able to explain to you what to do. you can find their contact info on their website http://www.sullivansgardenmachinery.co.uk
Posted on Sep 19, 2010
  • 5370 Answers
SOURCE: john deere lt166 riding mower
Find the brake caliper, it will be behind the right tire. Tighten the nut in the center to adjust the brakes.If brake arm cannot be adjusted to touch belt when PTO lever is completely rearward, then it has to be checked and replaced by John Deere dealer.
Click this link directly to manually adjust the brake and its settings:----=
http://technoanswers.blogspot.com/2011/02/brake-adjustments-on-john-deere-riding.html
Also if you require service repair manual,then its available.Click this link directly and you can order the service /repair manual.
http://www.ssbtractor.com/tractor_manual_display.cgi?m=John%20Deere&o=LT166
This should help.Thanks.Helpmech.
Posted on Feb 11, 2011
  • 24 Answers
SOURCE: need belt routing for 48 inch john deere mower
Go to john deer dealer they should be able to print u of that diagram for you.
Posted on Sep 14, 2011
John Deere 8330 PTP 524271.05
Try adjusting the linkage on the shifter the shifter may not be adjusted properly so the gears are not being fully engaged ,extend the linkage at least an inch or two (lengthen it)
Jun 23, 2015 | John Deere 2006 8330 69141
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
My JD L110 motor still turns the blade/belt when I turn the blade lever to the off position. It then throws off the belt from its pulleys... very not good!
Sounds like you may have a stretched belt for one thing. When was the last time it was replaced? As far as the blades continuing to spin, there should be blade brake shoes that rub against the tops of the pulleys when the deck is retracted to the disengage height. Those msy need to be adjusted or replaced.
Sep 13, 2013 | John Deere Garden
I have a 190d john deere 54in deck and the blades won't engage
With the machine off, check to see if anything is jammed underneath the deck, or around belts, clean everything off. try to manual turn the blades with you hand (tractor off and key out of the ignition) if blades don't remove, take off deck belt and then try and move each blade individually, see it any bearings are seized. Check to see if any one of your safety switches were disconnected, and test out the pto switch for power.
Aug 26, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Toro 17-44 can't keep deck belt from coming off
is the deck adjusted level?is it the right belt?
Apr 23, 2012 | Garden
Why dose my john deere ltr 180 have smoke near currung deck when i put the cutting deck down
the only thing other than a frozen pulley it could be check the routing of the belt it is rubbing somewhere.
Sep 08, 2017 | John Deere Garden
Can i have a belt diagram for a john deere stx38 please , thanks pete
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Click on the above link then do a "model search"
click on which model (either yellow deck or black deck)
alphabetically pick which belt,
a diagram should appear in the right hand corner.
Or you can try the link below.You will need to sign up(free I think)
http://www.pdfph.com/pdf/john-deere-1999-stx38-hydro-deck-belt-diagram/
The link below has a picture of the belts on a yellow deck.
http://www.askmehelpdesk.com/tools-power-equipment/installing-belt-jd-stx38-hydro-385391.html
May 16, 2011 | John Deere Garden
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
49 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
