Question about Kitchen Ranges
I have a programmable temparetur controller of Radix EC 96 its power suplly is failed, now problem is this its having 8 pin ic & one cosmo 1010 optp coupler is there, but 8 pin ic # is ereased omited by scratched some body or manufacturur, so i need help to find the ic # power suplly having ( 26v, 22v, 15v, 14.7v, )
cyberclash
  • 6 Answers
SOURCE: Sound missing
helo try to short the spider transistor along ic amplifier. it is in a mute
Posted on Jun 25, 2007
  • 5 Answers
SOURCE: My IBM 6400 comes up with the error 086 Controller
The manual recommends replacing the hammer bank logic cable even if there is no damage to cable seen. You might do the cable shorts test recommended on page 263 of service manual
Posted on Oct 14, 2009
wireguy212
  • 1627 Answers
SOURCE: i have a 96 jeep gand cherokee, 8 cylinder. the
Sounds like the problem is in your radio,unplug it for a few days to confirm.
Posted on Dec 01, 2009
electronios
  • 126 Answers
SOURCE: Panasonic PT-LB10U do not work lamp ok ballast
You have to replace the transistor Q107 on the board ETXM519MBGB
this is pnp type but i can't find it on service manual.So if you don't like to make experiments replace the board.
Posted on Feb 04, 2010
Testimonial: "awesome tech and aset to fixya.com well done"
  • 418 Answers
SOURCE: i have a Tedelex Ec Rp 4389 Rear Projection with a
Pin 10 should be at the positive convergence power voltage. The ICs run on a plus and minus voltage from a power supply. Usually +/- 15V to +/- 30V. (don't know this brand.) (not sure if -570 is replacement for -560; could be.) I'd look through main power supply for these 2 voltages. Ohm to pin 10, etc. Check PS fuses there.
Posted on May 02, 2010
I have a ken wood kr-797 stereo receiver but I can get sound but it's very low and I have to have the volume set at 0db in order to hear anything. It's like this on all inputs
I suspect that the pre-amp stage in you amp has failed. What you are hearing is the power amp on full volume. But with no pre-amp to boost the signal it's to low.
What we do know is that the sound is going into the pre-amp and out for you to hear it. This could mean that the power to the pre-amp stage is low, but still present.
Pre-amps these days mostly consist of a single IC. That could have failed, or it is not getting power. Since it would be possible to test the voltages to the IC, one pin should have something on it to the region of 6 to say 20 volts going into it. If the IC has that going to it, it has failed. If the voltages to all the pins are low, then you have a power problem.
Aug 27, 2015 | Audio Players & Recorders
Where is the eeprom located on le40r74bdx
EEPROMs [Memory ICs] can be located very near to the main system control IC. Will be very small in size, having up to 8 solder terminals.
See pictures
Mar 02, 2013 | Samsung Televison & Video
I have a Tedelex Ec Rp 4389 Rear Projection with a convergence problem i replaced ic(stk392-560)with(stk392-570) and it is still the same i noticed that pin 10 of the ic only gets 4.5v is that normal
May 02, 2010 | Mitsubishi WS-65511 65" Rear Projection...
68.0 permanent storage write fail
Hi, There is a small 8 pin IC (EEPROM) that you must take it off from board and clear it by a programmer
Mar 04, 2010 | HP LaserJet 4600dn Color Printer
My phone turns off.... Then it turns itself back on.. The battery is fully charged, It will continue to do this untill you take the battery out. Can anyone help me? I have a Pantech Slate C530
hi ajit is here some time ur mobile software is not work properly then this problem occur or other reason is ur phone hardware problem just like ur power suplly pins ic diamage
Jan 27, 2010 | Cell Phones
Power led blinking red and green wont turn on
For LG DU-37LZ30 specifically - On the power supply board, look for IC101, an 8-pin DIP IC. There will be three smaller electrolytic capacitors near it (C107, C113 and C125) marked 47uF, 35V. I'm being lazy here, but replace all three (only one is the real culprit). What is happening is that one of these caps is charged by line voltage until the IC (power supply controller) can start running. When this capacitor gets leaky, it cannot reach the proper voltage to start the controller. I used a 47uF, 50V replacement.
I have fixed two LG sets with this same problem. The other was a 26". It's a cheap fix!
Nov 02, 2009 | LG DU-37LZ30 37 in. LCD HDTV
Screen seems to shrink and get a red and blue line on each side of picture then returns to norm size. It only did it for a number of minutes when turned on now does it all the time.
you have a opto isolater on the power deflection board failing its a 8 pin dip pack ic
its on the board at the rear of board on right side there are three ics its the middle one 8 pin
Oct 24, 2009 | Philips 9P5034C 50" Rear Projection...
DELL LCD 1901FP PlZ Find IC Number
The 8 pin IC is UC3843A, SMPS controller. The 14 pin IC is TEA1533AT.
Monitor Mike
Jan 28, 2009 | Dell UltraSharp 1901FP 19" Flat Panel LCD...
Kitchen Ranges Logo
153 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
