Question about Goodman Heating & Cooling
To whom may concern, my a goodman central air unit has stop working. The unit will come on in the inside but the outside want. The unit is not kicking on and the fan on the unit appears to be a little warmer than usual. I click the breaker but to know change! Any suggestion?
  • 123 Answers
Its likely a start up capacitor. You will need an A/C repair person to come change it. I shouldn't be too expensive.
Posted on May 25, 2011
  • Goodman Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
I have a Goodman CPE30-1AB (Outside heat exchanger), with a Goodman (air blower) as well. Air blows inside, but not cold. Outside unit is not turning on at all. Can you please assist?
check your breaker or fuses at outside unit. verify you have 24 volts feeding outside unit replace outside unit contactor if you have the 24 volts and not starting.
Aug 08, 2015 | Goodman Heating & Cooling
My goodman central air unit quit working after a storm. The circuit breaker is not blown. The furnace fan kicks on when ac is turned on at the thermostat but unit outside does not operate. Is there an...
1 posible cause.the thermostat supplies 24 volts to the outside unit to control the contactor if you hear a ligth huming on the outside unit this is the being activated. if this is the case then
check to see if any ants are in or around the unit see video, they will usually climb to dry areas before during or after a storm and for some reason they like the contactor if this is the case cut all power to the unit and clean contactor spray the area around the unit with an insecticide ( not the contactor) replace cover and test unit. Best of Luck. raypena_4.jpg
May 30, 2011 | Goodman Heating & Cooling
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
I have a Goodman A/C unit. When I turn on the therostat the outside fan does not turn though there is a mild buzz sound. The blower blows warm air inside of my house. What could the problem be?
Does the cpompressor come on if not the sound you here maybe the contactor. Check float switch inside. It is underneath the unit or in front of the air handler. Drain stopped up need to blow out drain. Check outside breakers. possible bad capacitor on unit. Need service tech. Rusty
Jun 13, 2009 | Goodman CKL42AR42 Air Conditioner
Central air unit two part system, inside and outside. Freezes
If coils are clean and blower is working properly,
then you're probably low on freon.
Jun 09, 2009 | Goodman GMS90703BXA Heater
Bryant central air unit fan doesn't stop.
This is a condenser fan and as long as the A/c unit is in cool mode, this fan will run. The only time it should shut off is when temperature setting is satified and the unit shuts off.
Jun 03, 2009 | Heating & Cooling
Goodman CK60-1C model central AC unit blwing hot air
Clicking sound is the contactor engaging to start the outside unit. Check for a burnt off wire at the contactor. For some reason you are not getting power to the outside unit. If you find a burnt off wire shut off all power to it then remake the connection at the point of the circuit break.
Jun 26, 2008 | Goodman CKL60AR60 Air Conditioner
Central heat unit not blowing
Is your unit a Split system where one unit is inside (attic, garage, utility room) and another outside?? Is the outside unit unit running?? Is your thermostat electronic or the regular slide mechanical type??
Jan 17, 2008 | Heating & Cooling
Heating & Cooling Logo
182 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
