Question about Microwave Ovens
Bamix M122 circuit diagram required - Microwave Ovens
  • daveorr May 25, 2011
    Hardly expert assistance
    Guru, thanks for trying hard, but a reference to another site and have to pay again for the information required does not seem to live up to the "manuals and expert advice" (and even better service if you pay more, which I did) advertised on the "FixYa' site.
    Maybe I expected too much. Dave
  • 3,083 Answers
Unfortunately, these units' schematics are not available on the web, from my searches. You will have to contact Bamix to try to get a schematic for the unit, or go to the trouble of re-engineering the diagram, which is a most difficult task. Refer to your manual that came with the unit to find contact information for them. Sometimes they have them, but sometimes they don't supply them, and other times they will charge for them. Too many products these days are made to be "throwaways", and therefore not supported.
Good luck, and hope this helps.
Posted on May 25, 2011
  • 517 Answers
Good day!
Please try this link:
http://www.pdfqueen.com/bamix-m122-diagram
Thank you
    Guru:
  • 1,833 Answers
Sorry, but Bamix M122 circuit diagram is not available right now. In that case if you have your manual, you can check that.
Replacing underneath lights
If the owner's manual does not address it, then some disassembly may be required.
You didn't mention your model number or even your brand, but since you posted it under Whirlpool, maybe it's a Whirlpool.
You can download Whirlpool owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Always be sure to unplug the oven or turn off its breaker before removing or installing the bulbs.
Failure to do so may result in damage that could require circuit board repair.
Oct 27, 2013 | Whirlpool GH8155XJ Microwave Oven
Circuit Diagram required for HYS60-12-KD V-O 130C
Not getting any clear idea about your product. Please mention the proper Make and Model Number as given in the product.
Sep 15, 2011 | Microwave Ovens
How can I get a bamix manual, I have a bamix but have lost the manual that came with it
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
May 02, 2011 | Microwave Ovens
Blowing main breaker
I have a hard time believing that the home's main breaker is tripping instead of the branch circuit breaker that feeds the microwave. I suspect it is really just a difference in terms. You should disconnect it and try using in another outlet - preferably one on a different circuit if possible. If the breaker continues to trip; this appliance should be disconnected and either be discarded, repaired or replaced before using again.
If the microwave works as expected (on a different circuit), it may indicate the original circuit is overloaded. Microwave overs are supposed to be installed on a dedicated circuit. This means only one outlet is on the circuit - no other loads (lights, appliances, etc.) are permitted on this circuit. A microwave typically requires 10 Amps or more when on "high" and will require a significant portion of the power supplied by a 15 or 20 amp circuit breaker. There is little unused to power much of anything else. If other appliances go out when the microwave trips the circuit breaker, you should contact an electrician to have a dedicated outlet installed for the microwave.
I hope this helps!
Sep 23, 2010 | Maytag Microwave Ovens
Short circuited, can't find the manual.
Try the web and type www.partselect.com or www.applianceaid.com and enter your model number then scroll down to your part. Click to enlarge and you will be able to view the entire diagram for exact assembly. I'm not sure about where to find the specialty screw driver. A small pair of needle nose plyers might be able to grip the sides of the screws. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 29, 2009 | Microwave Ovens
GE Microwave
I repair GE circuit boards, but the problem is not your circuit board.
This is due to a defective or loose magnetron causing electrical interference and disruption in the control circuit board.
If your magnetron was recently replaced, it may have loose mounting nuts or bolts or maybe the wire mesh RF gasket was not installed or got pinched.
It may also need a new high-voltage diode and stirrer, and the cavity may be affected.
Details are in their bulletin here. Even if your model is not on the list, the same problem can occur, requiring a kit. The parts kit is similar to this one.
(Your model may use a different kit - this is shown for illustration purposes only).
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 13, 2008 | GE XL1800 1100 Watts Microwave Oven
The digital display is very dim and hard to read even in the dark. Is there a way to adjust the brightness?
I have a Sharp Carousel 1.5kW microwave oven with model number R-310F(W)C. The LCD dispaly on my unit recently became very dim. After check the small circuit board on the front panel, I found that the problem is caused by the LCD backlight driver which drives three surface mount LEDs. As the LED driver is inside a chip built on a small daughter card, it requires a replacement daughter card, or the entire circuit board for display and keyboard. A simple alternative solution is to cut the link between the three LEDs and their driver, then build a small circuit to drive the LEDs. I can provide the circuit diagram if interested.
Apr 13, 2008 | Microwave Ovens
Microwave Ovens Logo
377 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
