Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Tv turns on but showes no picture.... please help
  • Philips Master
  • 3,459 Answers
Common issue..check www.TvRepairKits.com for a repair kit for your TV.
Posted on Jun 09, 2011
Red light turns on but no picture on tv
HI Ana,
Please check the input connections properly, change the input cord. If it does not help, you need to consult the service center or some qualified technician. Good luck.
Jan 19, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
My sharp LC-40E67UN will not show picture. The tv turns on but no picture checked wires everything ok. Please help!
Connect the TV to any other video source, ie, from a VCR or DVD player. Check whether the working is perfect both with picture and sound. It's needn't to say, that you have to select proper input selecction. If the TV woks fine now, make sure that the RF stage circuit has the fault.
Jun 04, 2013 | Televison & Video
My sony tv turns on thn after a few minutes it turns off by itself, then it turns back on and reapets the same process over and over. please help! thank you
When did you replace lamp in tv last time?
Symptom shows its time of lamp replacement in tv, lamp replacement procedure is easy and would be written in user manual.
Please buy Sony original lamp for good picture in tv.
Thanks.
Jun 03, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
When I try turning on the TV the power/standby light flashes green until I turn the TV off, no picture appears.
If Sony KF-60WE610 does not show any Red blinking light then it is Lamp that need to be replaced because existing lamp has reached to end of its life but still not dead nor broken and causing problem.
If lamp got dead or broken, tv will show you Lamp light blinking.
Replace lamp in tv to solve its problem.
Hope these info will help you.
Let me know if you have any question.
Thanks.
Nov 04, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
I lost my picture I still have sound but no picture.
I have a Philips Magnavox Projection TV.
I had dish satelight install on my TV. It worked well for two days, then the picture started showing in a square box. I ffixed the convergence and it seemed okay. The next day I turned on the tv and it had sound, but no picture. When I press the status button, the picture would come on then go right back out. Now I don't have any sound or picture. Here is the model information:
Brand: Philips Magnavox
Model #: 9P6040 C104
Serial #: 51190366
Chassis # PTV843
Manufactured: Nov. 7, 2000 (3910K071H)
TV Receiver Listed: 347K E10839
Amps: 3.7
HZ: 60
V: 120
Can someone please, please help me!
Nov 15, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
I have a 42 inch vizio VW42L and a few months after I bought it sometimes when I go to turn the set on I get sound but no picture. To the point where the backlight of the tv doesnt even turn on. I usually...
Tell Vizio send out the tech.to replace ur Backlight video inverter board,it dying go to be dead sooner or later.Or take the refurbished tv ur tv will have dead video soon.
Sep 07, 2009 | Vizio VW42LF 42 in. LCD HDTV
My samsung TV won't show any picture/sound.
When the TV is on, need to check the back light is on(go back side & look into through)
If the back light is on -- need to exchange the Main Board
no back light -- exchange the Power Board --- 95%
exchange the LCD panel --- 5%(inverter)
Jan 31, 2009 | Televison & Video
My Insignia NS-LCD37-09 turns on but has no picture
this may just be a connection issue with cables. you should check and make sure all your cables are properly connected.
Jan 08, 2009 | Sony Playstation 3 (PS3) Console
No picture
may I ask first if ur TV has a raster...
Jan 29, 2008 | Proscan 32LA30Q Television
Tv does not turn on
You does not mean about picture clarity before this problem occurs. Former the picture clarity is well and good means picture is not problem. There is a problem in horizontal deflection area.May be flyback transformer failure shows these type of problem. This service should be done by technical persons only.
Aug 27, 2007 | Sony KV-32S42 32" TV
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
