Question about Dryers
We have a maytag neptune dryer md-6 and the dryer squeeks and squeels while drying close. Do I need to replace the belt or the drum wheels? Are all three?
  • 594 Answers
I would replace the belt usually over time the belt streaches due to the weight of the clothes. the screaching ou are hearing is probably the belt going aound the drum instead of turning the drum.
Posted on Aug 16, 2008
My dryer will run and dry clothes but as soon as the drum starts to turn it has a constant squeeling noise ( not a squeek like the wheels would cause) what is my problem and how can I fix it?
some dryers has a center bearing on the rear of the drum, once this bearing dries out it will make noise along as the drum turns.
Mar 25, 2015 | Dryers
Dryer making a high pitch squeeling sound when
The idler bearing that keeps tension on the belt is going out due to heat leaching the grease out of it. Have it replaced.
Apr 13, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE3000 electric dryer replacement of belt
The top comes off then the front panel is next.
remove the drum by pulling it out to replace the belt. replace the tensioners pully as well for it has a bearing that wears out then squeals loadly when old and dried up
Mar 27, 2010 | Maytag Neptune MDE4000 Electric Dryer
Dryer is squeaking i can move it around and it stops, why
the front drum seal is dried up and so can the belt around the drum. Check the bearing on the tensioner also for squeeks
Feb 05, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Dryer -5 years old squeeks Now it wont start.
There are four small plastic guide wheels that surround the drum in order to keep it aligned. These will wear after a period of time. The wheels have no bearings, they just ride on a metal shaft. You may either try lubricating the rollers or replacing them. Thank you, Dana
Sep 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Motor Pulley Squeeling - Maytag MDG5500AWW
try spraying wd 40 on the motor ends to see if it will stop if not try the rollers normally they go bad and make the belt squeel.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Gas Dryer MD-6 - Moisture Monitor not lighting
Remove the rear vent and run a load. If it dries correctly, repair the vent blockage.
If not, replace the gas valve coils.
May 24, 2009 | Maytag Neptune MDE4000 Electric Dryer
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
Maytag Dryer squeeling
Drum support rollers. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Squeeling noise
It could be just a dry belt and pulley. You could try the old squeeking car fan belt trick and rub soap on the belt. You can even buy sticks of anti-squeek from automobile outlets.
May 10, 2007 | Maytag Performa PAV2200
Dryers Logo
147 people viewed this question
Top Dryers Experts
