Dishwashers Logo
HAYLIE SCHUSTER Posted on May 25, 2011
The normal button keeps flashing on my gold series that is a few years old
Smitty
Level 1:
Champion:
  • Contributor 240 Answers
  • Posted on May 25, 2011
Smitty
Contributor
Level 1:
Champion:
Answers
240
Questions
0
Helped
66253
Points
50
You can try disconnecting the power for a few minutes and see if it clears, but I doubt this will help. You will likely need to replace the touch panel. If you can provide the model number and colr, I can get you the part information and availability.
Kelly
2answers
The Control Lock light on my Maytag 5000 Series dryer is flashing, and the dryer makes an error beep when I try to start it.
Make sure there is nothing in the way of the door closing good. Sounds like something keeping it from closing good.
Normal wash light continually flashing
There is a trouble shooting document behind the kick panel at the bottom of the machine. Follow the steps to determine which component is at fault. It may be corrosion in the low voltage connector.
My whirlpool dishwasher gold GU2475XTVQ0 had rapid blinking lights that started with the "4 Hour Delay" LED and changed to others when other buttons were pressed. The machine would not run. I followed the instructions located behind the kick panel and verified the keypad was the issue and not the control circuit by elimination.
The big surprise for me was that when I used a straight pin to resistance check all of the buttons, they checked out OK. I reconnected the 14 pin connector (P1) to the control and found that the buttons/LEDs were behaving correctly! I believe that pushing the straight pin into the 14 pin connector removed any corrosion in the 10 year old device and permitted the keypad to communicate with the control again.
I reassembled the dishwasher door and it ran with no problems. I was ready to replace the keypad for $150, but didn't have to!
Have a Kenmore Elite HE3T washer. Put appropriate detergent, fabric softener in, selected NORMAL cycle, spin speed, etc. Just sits there. Pressed START button several times. Nothing. Little cycle lights...
I own a 18-year-old Kenmore front-load washer so I'm not sure this will apply, but here goes... My washer requires me to press and HOLD the start button for a few seconds before it will start. At that point the door will lock and the washer goes through its startup phase. I think that is a "safety feature' to keep from accidentally bumping the button and starting the washer. See if that help. Good luck!
2helpful
Started to get a clicking noise from the electic panel of my Frigidare PLDB998 dishwasher for a few loads and then it went dead. Its only a few years old
Did you ever find a solution? I have what sounds like the same problem. The time keeps ticking down but it flashes between CL and the time while the clicking sound is going, and it sometimes make a clunking sound while this is happening as well.
Dishwasher does not complete cyele
Sounds like you might need a new Start button.
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
