Question about Western Digital Passport 320GB External USB 2.0 Hard Drive
When I try to remove my Portable Drive, it tells me I can't because "Generic volume" device is in use. I can't figure out what I have running that needs to be shut down.
  • 739 Answers
This sometimes happens when a file hasn't shut down properly. The data may be on the drive OK but the drive hasn't reported that the job is done. YTou'll just have to see what apps are still running and close them down one at a time until you can rem,ove the drive.
You may end up shutting down the computer in order to do it.
Posted on May 25, 2011
SD CARD reader error: Insert removable disk into drive F:/
One of two I was say is the issue.
  • When you improperly ejected the card you messed up the MFT (master file table) on the card. You will want to format the card.
  • You could have hosed the drivers. In Device manager look under the driver details there should be some files listed. You will probably need to delete these and replace them. Since they may be system files you would need to replace them in a live boot environment such as a linux live boot cd (ubuntu.com) would be the easiest. Get the drivers it has listed copy them to a thumb drive. Boot the computer to the live CD, delete the driver files and replace with the new ones.
Dec 18, 2012 | Electronics - Others
My transcend MP330 is not gettin recognized by the computer..
1) Turn on your mp3
2) go 2 settings>MTP thn select MTP
3) connect 2 a pc
then you'll see it as a portable device
4) FORMAT IT
5) go 2 settings>MTP thn select USB [on ur mp330]
Jul 06, 2012 | Transcend T.sonic MP330 MP3 Player
When i plugged my external hard drive, there's a
Hello there,
1. Is your Seagate portable external drive new? 2. Pug your external hard drive.
If it is follow instructions below. Guide is based on a Window7 operating system, you wont be having trouble if you're using Windows XP or Vista there will be a slight difference.
Note: you must be logged as an admin
a. Click start menu, right click-on Computer b. Left click on Manage. c. On Computer Management window. d. Left pane, Click Storage, Disk Management. you will see all available volume. e. If your Seagate is a new drive, it will appear as Un-allocated volume. f. Format the drive using NTFS file system before you can use it. you can also partition your new hard drive and assign a drive letter to the partition before you can use it.
Hopefully this guide helped. If you have questions feel free to ask me.
Thank you for using FixYa.
Aug 15, 2011 | Seagate 320GB Portable External Drive ...
I connected the hard drive to my laptop, selected "open folder to view files", and I set up the iomega encryption utility. Now, when I try and actually put anything on the hard drive, it says...
It sounds like a couple of possible issues. One issue could be that the partition for the drive was accidentally set too low. You can check the drive partitions by going to:
Control Panel > System and Maintenance > Administrative Tools > Computer Management
Once you're in there, you can click on "Disk Management" located on the left. If you click on one of the drives, you'll be able to see the partitions of the drives at the bottom, represented by blue bars and the hard drive's name. If you right click on one of the drives, you might be able to click "Extend volume" to extend the drive. If not, try uninstalling the program that you recently installed onto the drive, and if even that does not work, try to format the drive.
May 06, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
I did not install the software of WM "My Passport Essential" external drive. Therefore the WM logo does not appear on the task bar at the bottom right hand corner of the PC screen. I tried to...
It is indeed safe. When trying to disconnect while the computer is on, make sure all windows related to files/folders on the drive are closed, and check that antivirus software isn't scanning the drive.
Mar 24, 2011 | Computers & Internet
Trying to Safely Remove Hardware, my portable external hard drive and I keep getting the error message "the generic volume cannot stop, try again later"
Hi. I also have one doing this all the time. Never been able to remove it safely like we always should do. I remove it anyways when the light is not blinking and I never had any problems.
Feb 13, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
The device Generic volume cannot be stopped right now. Try stopping the device again later
why not try to use a separate program to safely remove the drive.
download here
what is it?
USB Safely Remove is a USB device manager. It saves time and extends user abilities on active work with flash-drives, portable drives, card readers and other gadgets.
post back and let us know.
Feb 09, 2009 | Seagate Maxtor 750GB One Touch 4 Plus...
I can't power down my passport. When I right click on the safely remove hardward icon, click on the drive to close and click stop, it tells me: "The device 'Generic volume' cannot be stopped right...
This should be simple. It seems as though your PC is still communicating to your passport in the background. Make sure you are not copying/cutting and pasting anything to or from your passport.
Personally, I remove my thumbdrive without going through the proccess of: "Safely Removing Hardware". But this only because I know that my computer is no longer communicating to it, and because it not a matter of life and death to me if my data is erased.
But don't get me wrong, I do not reccomend pulling your device out "Unsafely". What I'm trying to say is, as a last resort, I would personally pull it out.
Anyway, completely shut down or disable all programs that may be communicating to this passport.
Then try "Safely Removing Hardware".
Aug 01, 2008 | Computers & Internet
WD Passport Portable Hard Drive 120 GB Problem saftly removing hardware. Receive the message 'h device ' Generic volume' canot be stopped right now. Try stoping the device again later.
well i cannot actually figure out your problem well all windowsxp and windows vista allows you to safely remove your usb device well wats the error like diid you check microsoft for lates updates and patches !!try it oderwise tell me the exact error or problem!!thanx
Jan 31, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
Western Digital Passport 320GB External USB 2.0 Hard Drive Logo
118 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
