Question about Honda Hmantis Mantis Garden Tiller with Engine
I have a Honda tiller gx25 with a 4 stroke engine . It runs but I can't get it to scream so it digs the way it should.
5 Suggested Answers
SOURCE: Honda GX25 HG110 mini tiller, tines won't turn.
Mine did the same thing....two things to check: 1) air cleaner, make sure that it is clean 2). gas filter in the gas tank. Take a short piece of wire and fish the black line out. On the end is a small fuel filter. After I flushed mine fuel filter out it ran fine.
Mark
Posted on Jun 01, 2009
carlsbiz
  • 1124 Answers
SOURCE: HONDA MOTORS GX25-S3 4-stroke OHC single Vertical
The burning oil for a few minuets is more than likley the valve seals.. They often used plastic ones..
As far as the major leaks - that has to be seals and/or gaskits..
You would have to see exactly whre the leaks(s) is starting from..
Posted on Jul 09, 2009
  • 85 Answers
SOURCE: How do I check the oil on my Mantis Tiller with 4
Tip the unit up with the front on the ground, the dip stick will be on the lower part of the engine & comming out at an angle
Posted on Aug 17, 2009
Tiller wont move forward
If its not self propelled you must push it tynes only dig they dont pull the machine forward a self propelled means it has wheels on the back of unit that is chain or belt driven
Mar 10, 2014 | Honda FG201
TILLER LOPS. WONT RUM SMOOTH WHEN TILLING GARDEN ENGINE GOES UP & DOWN IN SPEED
For a quick and easy fix, try adding some Fuel Treatment to your fuel as it sounds like the carb is dirty. I recommend Berryman Chem Tool B-12. The dose is 1 ounce to a gallon of gas. Double that, or just add a little bit directly to the tiller fuel tank...if this is a 4 stroke engine. If this is a 2 stroke, don't do this as the oil in the mix will be too cut by the solvent in the B-12. Carburetor disassembly and cleaning will be required on a 2 stroke tiller engine. Clean that carb ONLY with WD 40. Don't use any strong solvents on the internal carb as it can swell and/or distort the sensitive check valves and mess up the carburetor permanently.
Jul 20, 2011 | Garden
HOw can I find an owners manual for a GX Honda 4 stroke mantis.
You can check on this site for one, by entering the manufacturer and model number of the tiller. Make sure to enter the tiller manufacturer, not the engine,
http://lawnandgarden.manualsonline.com/manuals/device/tiller.html
May 27, 2011 | Mantis 4-Cycle Tiller
What type of oil does a troy built tiller use? I have lost my book.
This is dependent upon what the engine application on the tiller is. If it's 2-stroke, use a quality synthetic or semi-synthetic 2-stroke oil mixed with the gas. If it has a 4 stroke engine use SAE30 oil, unless you run synthetic (which I highly recommend), then you can use a multi-viscosity oil if you like, say 10W-30.
May 24, 2011 | Troy-Bilt Pony Garden Tiller
MANTIS TILLER WITH HONDA GX25 ENGINE STARTS FINE BUT WHEN GIVEN THROTTLE DIES OUT. ALSO A LITTLE WHILE BACK OIL WAS COMING OUT OF CARB BUT THIS HAS NOW STOPPED. THIS IS A 4 STROKE ENGINE WITH APPROX 4...
I also have Mantis tiller for 2 years. From the very beginning I had a problems. I was referred by Mantis to the repair store and was charged $90.00 for oil drainage. The second time I was waiting for handle replacement for ~ 1 month. This tiller can't handle even little jobs and the warranty doesn't worth a dime. Maybe I will be more successful using it in my living room . I have an equipment with Briggs and Stratton engines and I never had a problem.
To me Mantis mean big advertisement and waste of money.
Feb 20, 2011 | Honda Hmantis Mantis Garden Tiller with...
Viper engine on my earthquake tiller starts fine cold then dies after fifteen minutes and wont restart
You probably need a new coil, if it is a 2 stroke then it will almost certainly be the coil. The defect is very typical and recognizable.
Jun 01, 2010 | Ardisam Inc Earthquake Mini Cultivator
Fg 110 mini tiller by honda
I have had the same problem.
The first time the solution was to replace the rubber membrane underneath the primer bulb. Take off the bulb, then remove the plastic part underneath the bulb. There is a rubber membrane underneath that. The ethanol in the gasoline tends to deteriorate the membrane. The honda dealers sell them for about 14 dollars.
The second time the problem was caused by the gas cap, not properly venting. In this case the engine would start and run, but when I gave it full throttle, it would quit.
It got so bad that it wouldn't even run. I noticed when I loosened the gas cap it ran great.
So I took off the cap, removed the inner parts, and got a diaper in and pushed it though the holes in the plastic part underneath the cap, and through the rubber plug in the center. I did this a few times and check with my mouth to see if I could pull some air through the cap. When it breathed satisfactorily, I put the cap back on the gas tank and it ran great. Now it runs better than new.
Jan 13, 2009 | Honda 25cc 4-cycle Mini Tiller
Honda Hmantis Mantis Garden Tiller with Engine Logo
106 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
