Question about Microwave Ovens
Turntable does not fit on coupler
I have contacted GE for a coupler for my microwave, received it but turntable does not fit. Contacted GE again sent free coupler but it is same model number and still turntable doesn't fit. the couplers have JVm 1630 on them. The table has L38 on the underside.
Can you help
  • 2 more comments
  • jaj4fun Aug 23, 2008
    Microwave model number is JVM1840WD001
    Thanks
    jaj4fun
  • jaj4fun Sep 04, 2008
    That is the part I received, but does not fit.
    Thank you for your reply te part does fit the end of the turn table motor. The plate (turntable) does not fit the coupler.
  • William Miller
    William Miller May 11, 2010
    Please reply back with your full microwave model number so we can help you.
  • Microwave Ovens Master
  • 9,174 Answers
The correct part number is WB06X10144. Was that the number on the plastic bag it came in?
You can order it here for $7.37 and see a photo of it here:
Posted on Aug 24, 2008
  • William Miller
    William Miller Sep 04, 2008
    Okay, does it look like the end of your turntable motor is damaged?
    That may be why it doesn't fit.
SOURCE:
GE Profile Spacemaker XL1800 microwave turntable
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
On some, you have to cut the motor cover off with snips, then use a screw when reassembling it.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Oct 28, 2013 | GE WB26X10037 Microwave Stirrer Motor
Turntable not working
The actual m# is JNM1851SMSS 01.
The problem most likely is with the turntable motor or coupler. The coupler is the part that the glass plate sits on that is driven by the motor. You will need to gently pry the coupler off and see if it is damaged. To test the motor, find a straw or something hollow that will fit snugly over the motor shaft. Turn on the unit to see if it spins. If it doesn't, then the motor needs to be replaced. You can get it at Sears Parts or other appliance parts websites. To replace the motor, make sure the unit is unplugged before you begin. Remove the bottom base where the motor is located. Remove the motor and install the new one. Re-install the base. Install the coupler on the motor shaft and you should be good to go.It is rare that the controller which turns on the motor goes bad, but it is a possibility. If you feel uncomfortable performing the above instructions, you should call an appliance tech.
I have attached a picture of the coupler as well as a link to your model. The #42 on the drawing is the motor.
Good luck
Don't forget to vote and please leave any comments you wish
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Microwave-Parts/Model-JNM1851SMSS01/0432/0123370/G1010188/00001?blt=06&prst=&shdMod=
Dec 20, 2010 | GE JNM1851SMSS Convection/Microwave Oven
The turntable on my microwave does not work. I have a GE Spacemaker, Model JVM1640wb 004.
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
May 15, 2010 | GE Microwave Ovens
GE Spacemaker MV Turntable Not Turning
yes pry out with either 2 flat knives or screwdrivers. It will lift out Make sure you replace with the exact one as they are not all the same.
Sep 16, 2009 | GE JVM1650 1000 Watts Microwave Oven
Turntable not rotating
HI, the turntable motor is weak and failing at this point, simply replace this damaged motor. this will eliminate this distraction.
Jul 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable in GE microwave stopped turning.
On some GE models, the turntable motor and stirrer motor are powered off a tap on the internal cooling fan motor and in such cases they will be marked "21V AC".
When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
I'm instead talking about the internal fan which comes on automatically whenever you microwave.
It is vital that the cooling fan runs, or the turntable and stirrer won't work, and magnetron will soon be destroyed.
A quick test is to remove the stirrer cover in the ceiling of the oven. The owner's manual tells you how, and you can download that here.
Then run the oven for several seconds with a cup of water inside while watching the stirrer blade in the top. It should turn very slowly.
If it does not turn or is jerky, it or the cooling fan is not working.
Also, we have a sound clip of what a microwave should sound like when the cooling fan and everything else is working here. The cooling fan's absence will be notable after you hear the clip.
The turntable system otherwise consists of the motor, the coupler, the turntable support with rollers, and the tray.
If the cooling fan is good, but yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing some parts may require you to pull the oven from thew wall and remove the cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
Jan 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave TURNTABLE slow-erratic and noisy JVM 1860 SD 002
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
Jan 03, 2009 | GE XL1800 1100 Watts Microwave Oven
My turntable stopped running
If you didn't buy the turntable motor then I assume you purchased the coupler ( white plastic/nylon piece that fits into the turntable motor collar and rotates the platen? Is that what you purchased?
Sep 13, 2008 | GE JES1384SF Microwave Oven
My ge profile spacemaker xl1800 turntable stopped it turns once in a while. What do I need to replace. Where can I find the part number?
It's probably a bad turntable motor or coupler.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
UPDATE: GE Spacemaker XL1800 Microwave
JVM1850BD002 is a correct model number. This is a GE made by Samsung. It sounds like the motor or coupler is bad. More likely the motor. If you grab the motor shaft and try to gently turn it, it may grind or slip a lot. That's a sign of a bad motor. If the coupler is bad, it will be cracked or broken, causing it to slip on the motor shaft or the turntable itself. The coupler is reference 40, and the motor is reference 43 on this handy exploded view drawing: http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00016500/00016593.p01.pdf (copy & paste whole URL) Here is the GE part price info on these two parts: DESCRIPTION DRAWING PART NO. PRICE MOTOR-SYNCHRONOUS 43 WB26X10038 $46.00 COUPLER 40 WB06X10144 $8.75 If the motor is bad, you might be able to find the Samsung part number printed on the motor label and look it up at http://www.samsungparts.com They often have parts for far less than the expensive GE parts.
Dec 01, 2006 | Samsung MW1030WA Microwave Oven
Microwave Ovens Logo
129 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
