Question about Black & Decker String Trimmer Cordless 12" 18V
I have the PA6-GF30 Grass Hog. The tread holder will not hold the tread tight enough for it to stay in place so the spool rewinds itself. Will I need to replace the spool cover? If so what part number do I need?
  • 313 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
the problem is the white lever may be broken. its located at the bakc of the spool line,
Posted on Jun 01, 2008
  • 3 Answers
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
SOURCE: weed whacker
I was unable to get that ring off also... I was able to pull plastic side apart far enough to pull motor out and "rewire" it. Even fit back in when I was done... just barely. and was very gentle...
I do not know how to get the ring apart, though.
Posted on May 12, 2009
  • 133 Answers
SOURCE: My grass hog xp starts but the spool won't spin
This unit is supposedly the same as the GH700 drive system. There is a 5:1 plastic reduction gear inside the housing driven by a steel gear from the motor. It easily strips, melts, or simply breaks. The part is difficult to find. I have not found one yet for my situation.
Posted on Apr 20, 2010
  • 133 Answers
SOURCE: have a grass hog that has two lines in the spool.
wind in direction of arrow on spool. Use 2 separate pieces. 1 at top and 1 at bottom. Feed 1 through each opening in hub when done.
How do I change disk/blade in my Makita PA6 - GF 30.
Thats a material code of Polyamide many products are based on this PA6-GF30 code. like to see here for example
Polyamide PA6 GF30 Jacob moeren metrisch WKK Nederland
Search on the pictures in Google for the right saw model
Feb 05, 2017 | Makita Saws
What replacement line is used for the BLACK & DECKER Grasshog. 5,063,673 5,620,336 6,443,753 6,443,762
For the cordless Grass Hog, the replacement spool is AF-100. You can purchase these spool heads online or maybe find them at your local hardware store, but they may be hard to find because the Grass Hog is not made any more.
Jul 13, 2010 | Black & Decker 14" Grass Hog Xp...
How to put together the CST2000 and install a battery
Which part of the Grass Hog did you take apart? If you mean the spool head, that is easy to reassemble. The actual spool (the round part with the line coming out) goes into the cavity on the bottom of the trimmer, with the line poking out of the hole in the side several inches (not enough to hit the plastic guard). Then the cover (orange with the spring on it) fits on top of the spool so that the spring pushes on the spool and the two tabs on the side snap into the holes in the trimmer.
Unless you took another part off, that should be all you need to do to reassemble the Grass Hog. Turn it right-side up and turn it on to make sure everything works.
Jun 01, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
String problem
Donna, take the spool that holds the string off. Look to see which wat the string is supposed to be wound onto the spool. If the string in on correctly, check to see if one or more of the turns of the string is overlaying itself. If there is overlap, clear it out by unwinding enough to unlap it. If the string is going the wrong way when you check it, remove and save the string from the spool, rewind it in the correct direction, put it back onto the machine and see if that corrects the problem. Woman or not, you are smart enough to ask, you are smart enough...Good luck...Lee
May 28, 2010 | Black & Decker 14" Grass Hog Xp...
;How do you lengthen the string? (Have the grass
To lengthen the string:
- Turn the Grass Hog upside down
- Push in on the two release buttons on either side of the spool (they're orange)
- Pull the spool head off and spin it to release more string while you pull the string with your hand (make sure it is still fed out through the hole in the base)
- Pop the spool head back into place
Test the Grass Hog to make sure the string is not too long. If it is you'll hear it cracking against the plastic guard on the base.
May 02, 2010 | Black & Decker Cst2000 12 - Volt Cordless...
How to restring back and decker grass hog
For Black and Deckers: Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit. Replace empty spool with new full one or wind on aftermarket string. Wind in direction of arrow on spool. Make sure spool is seated on rachet firmly.
Apr 11, 2010 | Black & Decker 14" Grass Hog Xp...
Have a grass hog that has two lines in the spool. How do I restring the spool
Apr 10, 2010 | Black & Decker 14" Grass Hog Xp...
Pull string for Weed Eater Featherlite Plus came out
If you have the starter spool out (the one the rope goes in)...Here is what to do. Take the starter spool and change the rope out putting it back exactly as it was. Leave the rope hanging. Hold the spool and set it down on the rewind spring. Turn the spool on the rewind spring until you feel it is tight enough. While turning, hold the rope in the little slot in the spool so it can go around without hanging up. Once it is tight, get the rope in line with the spool opening and SLOWLY let the rope rewind. Put on the handle and put the unit back together.Good luck...Lee
Sep 06, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Black & Decker String Trimmer Cordless 12" 18V Logo
1,209 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
