Question about Dryers
Electic dryer will run, but does not heat and does not shut off.
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on May 26, 2011
My whirlpool thin twin washer stopped working. The dryer still runs but the washer does not.
Shut elect breaker off and back on. At elect panel . Sometimes braker trips one side and stays on the other hard to tell the diff.
220. One must be on and the other off. Although they are attached . Make sure door is making contact with switch
Feb 16, 2015 | Whirlpool Washing Machines
Estate Mod# TEDS740PQ1 elect dryer: have no heat & timer will not shut off?
Probably the heating element. My home movie of a heat problem with a dryer just like yours:
Aug 26, 2012 | Estate Dryers
Roper Electic Dryer EL4030V - comes on - runs good - just no heat?Would like to try to fix myself? Where to find good instructions with pictures?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 21, 2010 | Roper Dryers
The dryer runs about 10 seconds then shut off. It
Maytag gas dryer , runs for about 15 sec. heats up , then completly shuts off , Checked thermal fuse & it was blown , replaced & it ran for about 15 sec again & blew fuse again ....help .
Apr 26, 2010 | Maytag PYE3300 Dryer
Dryer rotates/runs, but does not heat up; I've checked both circuit breakers - both are "on".
if the dryer is elect. check the heating coil see iff burned out -if gas check your pilet
Dec 22, 2009 | Washing Machines
Kenmore dryer turns on and operates without heat?
Is this an electic dryer? If so, the heating elements run on 220 volts and the dryer motor runs on 110. Check your fuse panel and make sure the fuses have not blown. Then check the outlet at the dryer and make certain you have 220 volts at the receptical.
If that checks out OK, you may have to check the circuit to the heating coils in the back as well as the coils them selves. There are also heat sensors located near the coils that will prevent them from coming on if it get too hot or the sensor is bad.
You can go to the Sears parts web site and get the parts diagram using your dryer diagram. There is an electrical schematic on the back of the dryer that will help you track down the circuit.
Good luck, let me know.
Regards,
Jun 30, 2009 | Kenmore Dryers
There is only cold air in my kenmore elect dryer
The motor runs on 120VAC. The heating element requires 208/240VAC. Cycle the dryer circuit breaker. Other than a simple issue like that, the problem could be a bad heating element, thermostat, high limit control, thermal fuse, motor centrifugal switch, timer or electronic control. It can also be a wiring issue.
Apr 27, 2009 | Kenmore 62602 Electric Dryer
Heat goes off after a min. in use. Whirlpool Model # LGR4634JQ2. Took apart back and cleaned exhaust.
if it's gas it could be that the pilot is not close enough to the gas sensor and when the drier is in motion the extra air motion shuts it off.
if its elect it could be that one of the fuses are not set shut both fuses down and turn them BOTH back on
Gas clean the elect pilot and be sure it is close to the sensor that looks like a little tube
Apr 22, 2009 | Dryers
DRYER SHUTS OFF ON HIGH SETTING- FINE ON LOW HEAT
lets start simple on this,first check your dryer vent for obstructions(mainly lint build up,)also check the weather flap (where your unit vents to the outside)this should swing open when the unit is in operation.either one of these can cause excessive heat build up in the unit.(this will cause the thermal limit switch to shut the unit down)thus keeping you from setting your clothes on fire.hope this helps,thanx for using fix-ya
Nov 25, 2008 | Dryers
Dryers Logo
29 people viewed this question
Top Dryers Experts
