Question about Moen Home
Just installed a moen # 5350 a few hours ago - 24 May. #!1 It's hissing a water sound. #2 The water level is lower than the old one. #3 Every minute or so water leaks from under the round (top) part of the valve. The toilet was bought at the Re Store and the water fill valve in it, did the same things as the new one is doing now, except for the water level. It's so fragile looking I'm afraid to play with it too hard. What do I do short of calling in a plumber? -B.
  • wandbwalsh May 25, 2011
    I installed a moen 5350 water fill valve a few hours ago. It is always running water. It hisses water. Every minite it runs water into the top of the float of the valve and into the 1 inch tube running down to the flapper.
    The height (the top)of this water fill valve is just below the top of the inside of the tank. The 1 inch tube attached to the flapper at the bottom of the tank is about 2 and 3/4 inches from the top of the tank. The water level is about an inch and a half below what it was.
    I don't know where (how high) the moen 5350 should be from the top of the tank. How do you move the yellow bar and why. IT came with NO instructions. The old water fill valve was behaving the same way except for the water level, so it was no help!
    Also, now as before, the amount of water in the bowl is A LOT. It measures 10 inches wide and the toilet takes forever to flush.
    HELP
    -B.
    PS- some bargain I got hey?
  • 43,501 Answers
The hissing is pretty normal for these valves...they make them louder intentionally so you know if they are running too often...
The reason it is going on every so often, is because the "flapper" that pulls up to let the water out of the tank is leaking and allowing water to run through into the bowl even when it is down... replace that.. also..
The tank water level can easily be adjusted...
Adjustment instructions
heatman101
Posted on May 25, 2011
  • 710 Answers
Hi wandbwalsh,
There is a yellow tab at the top of the fill valve so you can adjust the water level.
The float arm should be 1" above the overflow pipe. This should have been adjusted during installation. If it is correct, simply adjust the float.
If the 1" above spec is not correct on yours, you would have to remove the moen and adjus it's height. You would do this by turning off the water supply to the toilet, removing the water supply line by removing the two plastic nuts at the bottom of the toilet, and removing moen and adjusting the height of the stem.
After these adjustments are made you should be good to go...
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
Moen Universal Fill Valve Model M5350 problems
Some kind of crud may have goten into the fill line during installation and is blocking shutoff. The new fill valve could be defective. Something may be preventing the float from stopping the flow. The flapper may be allowing slight leakage, preventing the fill valve from shutting off and staying off. The "overflow tube" actually is the fill tube; the tank fills from the bottom up.
Feb 01, 2014 | Home
I have a hissing toilet. My kohler 4708 fills up, and once this happens, the left side of the tank has a constant hissing sound. When I turn off the water it stops.
Your valve inside the tank has worn down and not allowing the water to stop running. Does the water run over the top of the overflow. If so, then adjust your inlet water to a lower level so it will cut off. If that is ok, then likely the flapper is worn out and needs to be replaced.
Feb 19, 2013 | Kohler Home
The toilet does not refill the tank to the water level line, as a result the float is about 20mm below the water line and the toilet is hissing 24/7. How do i adjust to make the toilet fill the tank to the...
The fill valve sounds if it is bad.Go to lowe's and get a fluidmaster fill valve(about $8) instructions included.turn off water and remove water from tank then disconnect supply tube,remove old fill valve install new,follow installation diagram,and the adjustment process to adjust the water level to correct level that should take care of your problem.
Jun 19, 2011 | Caroma toilet - water saving Sydney Low...
Cold water flow is slow and handle is starting to get a little stiff to raise and lower - what is wrong and how can it be fixed? Moen M7800 Kitchen faucet
Not sure whether you are aware or not but most times, if you call moen with your model number and explain the problem your having, they will usually send you (free of charge-lifetime warranty) the part with instructions on repairing it along with it. You may have the 7800 series, but there are 3 or 4 different models if you check their site, and can identify the actual model, they will send you repair parts. Tell them you bought it ? years ago, and don't have the receipt, if they even ask.
try this link, if no luck, get back to me.
http://www.moen.com/replacement-parts
Apr 16, 2010 | Moen 7840 Camerist Single-Handle Kitchen...
When the toilet has been flushed (push button)it makes a hissing noise and then overfills so the water is going away in the overflow pipe. it was fitted 3 years ago. thankyou.
on your ballcock assembly there is an adjustment device (usually a screw) you just need to adjust the water level so it does not go over the overflow and have the "running" sound. there is a reccomended level usually stamped on the tank or the overflow tube.
hope this helps
Jul 07, 2009 | Home
After consulting with Moen re: 2 knob Tub "cartridge" replacement, 12 yrs old, cold water not running, I did what I was told, after receiving the replacement cartridge 1248. (warranty replacement) The...
If the water is off but still coming through, open a tap or two on one of the lower levels.
Basically the old stem does come out thru the top of the valve. Hopefully Moen sent you the tool to do this job. The tool is a 3/4"diameter about 4 inches long. Even on one end and two little tabs on the other.
Take the handle off stem. Remove the upper retaining nut, usually chrome. Pull out the two plastic upper stem pieces. Insert the 2 tabbed end into the stem area. You will feel the tab drop into the retainer ring. Slowly rotate the retainer ring out Counterclockwise. After the retainer ring is out then put the long screw in the stem and pull it out. Sometimes a little leverage helps here.
You will have TWO retainer nuts. The first one is easy just under the handle, the second will require the special insert tool.
Please rate this response and good luck, Phil
Dec 29, 2008 | Moen & Replacement Cartridge
Home Logo
1,203 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
