The remote is not working only the power key is working, new batteries and all.
  • 104 Answers
Hi mpcc_mac,
The cause could be alot of dust could have accumulated inside the remote.
try opening it up clean the board with contact cleaner but be careful not to spray the keypad with the contact cleaner or it will shrink.
thanks,
George Y
Posted on May 25, 2011
Remote works with on and off and volume but stopped all other functions.
1 Remove the batteries form the remote and blow hot air by hair drier about 5 seconds . replace the older/ used batteries with new one of same kind. Does it solve your problem ?
2. Remove the batteries and unscrew the remote and then open the case of remote , clean the PCB's key pad area with soft and dry cloth , put small amount of carbon ink (purchase from electronics parts shop- cost $0.5 approx) on key pad's back side round dots, let it be dry for 30-45 min , assemble the remote and fit batteries and enjoy.
May 27, 2016 | Universal Remote Universal Genesis Remote...
Focus remote lock
Is your key paired with your ECU?
Mar 20, 2014 | 2004 Ford Focus
Change battery keyless remote
Replace battery very expensive to get new one they are button batterys get hi power ones
Nov 03, 2013 | Chevrolet Equinox Cars & Trucks
I think my key remote is dead and my key won't open the door. what can i do?
put a new battery in remote,try key in other door," are you sure the car battery is not dead," !!!! If it is then remote wont work, if you are locked out of car call wrecker or lock smith and they can slim jim the door to get you inside. then unlock doors USING THE POWER LOCK button PROVIDING CAR BATTERY IS NOT DEAD!!!!
Jan 14, 2011 | 1999 Lincoln Continental
Have a Phillips flatscreen tv. I can't turn it on with the remote but can turn it on by pushing power button onthe side of tv. Batteries are new.
Hello, you could still have a worn out power key. Turn on the power manually(power key on the TV) then select channels/adjust volume/press the number keys.If all these work on your TV, then you know another remote is needed.
Nov 19, 2010 | Philips Televison & Video
My key fob on my suzuki xl works part of the time then stops. how can i check it. thanks
Change the Battery!~! Thats how they act when the battery starts going south!
Mar 09, 2010 | 2002 Suzuki XL-7
2001 ml320, remotes quit working. new batteries,
Synchronization
Turn ignition switch to position II. Turn ignition switch to position 0 and remove key. Within 1 minute: Press and hold key lock button. Press unlock button 5 times. Remote control should now operate system. If not: Repeat procedure.
Programming
When
Key remote control added or replaced. System malfunction.
How
Keys can only be programmed using diagnostic equipment
Jan 09, 2010 | 2002 Mercedes-Benz C-Class
Power door lock remote won't work
Sounds like the remote is failing..
Jul 10, 2009 | 1998 GMC Safari
Remote not working after disconnecting battery
If car Convenience Control Module(module that control key remote) lose power- remote adaptation to the car will be lost. This apply to some Audi models.
What you can try to do is:
1. Disarm alarm manually by opening door lock with the key
2. Put key into ignition and turn to on position (don't start the car)
3. Press few times remote button (with the ignition in on position)
Depends on your year model it my work (works on the newer models), if not you have to go to the dealership to program your keys.
Grzesiek
May 11, 2009 | 2003 Audi A4 Cabriolet
My Sharp Remote Control Is Suddenly Stop Working
Ok I just dealt with the Sharp customer support for this problem.
1) You need to unplug the TV for 1 full minute and remove the batteries from your remote aswell (this will reset the system)
2) Hold the power button on the remote for 30 seconds with the batteries still out of the remote and the TV still unplugged
3) After the 30 seconds replace batteries then press every button on the remote beginning with the power button in order from left to right and top to bottom (same way you read)
4) Then plug your tv back in and try the remote again.... and the remote and TV should be back in sync.
Aug 03, 2008 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
Electro Med Services...
