Question about Maytag CWG3100A Gas Single Oven
Maytag gas oven mgr5770abb Does not light when I try to use oven. Broiler works fine. When I try to turn on the oven, the broiler igniter does not glow. If the bottom igniter was bad, wouldn't the top one at least glow? I have it torn apart and everything looks good, both igniters show resistance on meter not an open circuit.
  • 1 more comment
  • texxasx Aug 16, 2008
    That's it! Bottom igniter is out. It is number 1034629, cost about $44 on the internet. Thanks!
  • jcolwell Nov 10, 2008
    On mine, when in bake it will build up to a loud pop or explosion and then seems to work. Broiler works, but if it is the 'bottom igniter' where can I find that on the oven? Who fixes these things?
    thanks
    Jim
  • jmy1944 Nov 13, 2008
    I have a Maytag MGR5765QDB oven ignitor is out .Maytag and local dealer says 74007498 is the replacement .but the connector is different # .1034629 looks identical to the one I have . and cut and porcelain wire nut together?? Helpdo i use the 74007498
  • 725 Answers
First I would check to see if you have power (120v) at the bake igniter..when you set in to bake...use a multmeter..(when you turn on the oven to bake only the bottom igniter will come )
good luck be safe
let me know if I can help
Posted on Aug 16, 2008
I have a maytag model # mgr5775qdw and the oven will not ignite. I know it is not the gas line as the burners all light, and the broiler lights as well. It is only the oven that does not heat. . .what...
This could be two possible problems. The igniter maybe bad, but doubt it. The igniter works both the oven and broiler, I believe on this model. The first thing I suspect is the switch in your wiring harness. The harness has a switch attached to it for each manifold. The switch for your oven maybe out.
Go to this site for diagram of parts: https://www.maytag.com/digitalassets/MLPDF/Repair%20Part%20List%20-%20W10282172.pdf
Jun 18, 2011 | Maytag Ovens
MY MAYTAG OVEN WILL NOT TURN ON WHEN I SET THE ELECTRONIC DIGITAL THERMOSTSTAT LIKE SAY I PROGRAM IT TO 350 DEGREES,,, NOTHING HAPPENS,,, BUT WHEN I GO TO SET THE BROILER THE BROILER WORKS JUST FINE,,, I...
First I want to commend you for your giving us good information to start with!
So-- we know we have gas, and we know the Broiler Valve and ignitor works-- Good observation!
However-- we have no ignitor (No bright red/Yellow glow)-- like you go for the Broiler-- right?
Well, we can NOT get ignition on the main burner-- unless we have the ignitor for the main burner getting hot, and then the gas valve to that burner can light, and give you heat...
Soo-- Likely we have an ignitor failure for the Main burner---
Do you have a warranty on the stove?
Do you have a service person qualified to tackle this job?
There will be electrical work, and parts obtainment issues to deal with now---
I suggest you call the local service people for this stove, and tell that that you need to have the main gas burner ignotor replaced for this stove model number-- and see what they tell you.
Let me know if I can help more--
Mack B
Dec 30, 2010 | Maytag Ovens
SET DIGITAL THERMOSTAT TO SAY 350 DEGREES WILL NOT TURN ON OVEN,,, ? IF I SET TO BROIL BROIL WORKS BUT OVEN WILL NOT TURN ON ?
Possibly the ignitor for the main oven burner has failed--
An observation question:
When the Broiler 'lights' and comes on, do you notice the ignitor glowing bright, before the gas valve (to the Broiler) opens, and you get the Broiler lighting---
Now-- for the main burner to come on, -- there has to be a similar bright glow from the MAIN BURNER ignitor, before its main burner gas valve can open-- No Ignitor?-- No ignition, and not Main Oven burner!
Let me know what you need from this point on --
Mack B
Dec 30, 2010 | Maytag CWG3100A Gas Single Oven
I have a maytag pilotless ignition gas oven. the top burners work fine the broiler ignites fine. we just tried clean mode and its working too. the problem is we cannot get the oven to heat up. we turn bake...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 13, 2010 | Maytag Ovens
Oven Stopped Working..
It sounds like the igniter. The oven is not getting a spark to turn on, and heat up. We had the same problem, but changed the igniter, and it works fine. Good luck!
Jun 02, 2010 | Maytag CWG3100A Gas Single Oven
Oven won't light.
Localwonder gave a more comprehensive answer, but I wanted to share my recent related experience too:
Same model: MGR5750BDW
Oven was not heating up, or would sometimes and not others. Broiler worked fine. The nice thing is that the broiler igniter and the oven igniter are the same part. So I swapped them until I could get a replacement part.
Before I did anything, I turned off the gas!
To take out the broiler igniter: there's one screw right near the front of the oven that holds the burner assembly in place. Remove that, gently pull the assembly off the gas nozzle off to the left. Then where the wires from the igniter go into the back wall, remove the screw that holds the little door, remove that little door, and then gently pull the wires through until the connector comes through the opening. I also found you can go behind the stove, remove the back panel (which is easy) and see the igniter's connector.
The oven one: remove the floor of the oven by lifting it at the back, and then lift it out towards the back of the oven. Then you can see the igniter at the back of the floor of the oven. remove the two mounting screws, and then gently pull the wires until the connector comes through the insulation.
The bad igniter looked like it had burned down to bare metal in a big patch...not sure if that's the actual problem, but in any event, I installed the good igniter in the bottom (gently pushing the reconnected connector through the insulation, and feeding as much of the wires down in there as well), and the bad igniter in the broiler position (since that was the easiest one to access and replace, it'll be easy enough to replace when I get the parts). Tested, and everything worked great. And I could watch the bad igniter light up, and never light, confirming that it was the igniter itself that was the problem.
The best part, for this stove anyway, -- the ONLY tool needed was a #2 phillips screwdriver. Really. All told, maybe an hour of work, nothing intense. And free -- so if they both worked, it would have spared me ordering a part that didn't need to be replaced!
Jul 22, 2009 | Maytag Amana 30 in. Electric Double Wall...
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
Maytag CWG3100A Gas Single Oven Logo
254 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
